Love the body english and manually pumping the oil. I think cornering in one of those must be very special.
Correction: a comment in the video said:
That's the air pump. Methanol is fed to the carbs by air pressure displacing the fuel out of the tank. I pressurise the tank using that air pump - generally trying to maintain 1-2PSI. Anymore than that and the fuel tank wants to split! In my next race that day, the fuel pressure gauge failed and was happily spraying fuel over my leg whilst I pumped.
Also, it was noted that the throttle stuck and he was switching ignition on and off. I don't care how slow he's going, it looks like an absolute blast, so much driver involvement.
In reply to kb58 :
I doubt he's pumping oil. Most of those hand pumps are to pressurize the fuel tank. (No fuel pump due to using motorcycle engines which are gravity fed)
In reply to frenchyd :
You got it. The driver said that in the comments. Also in the description he says the gauge broke, which is mechanical, so that pressure leaked on to his leg.
Great video! I'll have to watch the whole thing, when I can.
For the short bit I did, I was watching the driver, so I missed a lot. Is that 4 wheel versions, and 3 wheelers in the same race? Would love more info on the tadpoles, as I plan to use one as a commuter one day.
How much HP does one of those make? Cause you can get a vacuum operated fuel pump for pretty cheap.
Gives me the same feel as a cycle-cart
In reply to Mr_Asa :
The class rules must forbid such a modernization. This is in the "prior to 1930" run group. He probably gets about 60 BHP at about 4000 RPM on methanol along with good torque from under 800 RPM. Given the low weight and low CG it should run close to the front.
In reply to TurnerX19 :
That looks like a J.A.P. Nope, not a Racial slur. It stands for J.A.Prestwich it's a motorcycle engine. That typically ran on Alcohol because back then it was half the price of Gasoline.
Class rules don't forbid such modernization. In that group originality is paramount. It's pride that prevents updates and modernization.
Bentley is the same way. They take great pleasure in originality even if there is only the faintest hint of original paint they leave it as a badge of honor.
Patina is sadly abused, occasionally faked but real patina, real originality is more important than speed.
You'll need to log in to post. Log in
