MadScientistMatt
MadScientistMatt UltimaDork
4/13/25 6:35 p.m.
Most motorcycle helmets have a washable liner. Is there a reason you almost never see this in racing helmets?
theruleslawyer
theruleslawyer HalfDork
4/13/25 8:17 p.m.
probably because most people use a balaclava, or that's really the intended use with a S helmet.
Floating Doc (Forum Supporter) GRM+ Memberand MegaDork
4/13/25 8:22 p.m.
There are motorsport helmets with removable and washable liners. When I started autocross, I bought the cheapest full face Zamp helmet on the big auction site that had a removable liner.
Bluebayou22
Bluebayou22 New Reader
4/13/25 9:14 p.m.
Helmets are mandatory and that makes sense. Some organizations allow you to wear shorts and short sleeve T-shirts and others require long pants. No big deal. I think the focus should be on the safety and the preparedness of the vehicle. The primary purpose of a tech inspection should be to protect other drivers on the track . For example if you attend a track day with a 65 Mustang with Factory seat belts you will pass Tech inspection however if your Simpson or schroth 5 point harness is 6 years old you fail Tech inspection.
codrus (Forum Supporter)
codrus (Forum Supporter) GRM+ Memberand UltimaDork
4/13/25 10:42 p.m.
Also consider that motorcycle helmets are used on the street and are thus likely to average a lot more hours of use per month than auto racing ones.
TbnD0cLN347PtkNMYIEtAzBo9v9HwVeHiOMQ0Vq6bznY2gqV19r1TfW6qZ7i7M98
