mr2peak
mr2peak GRM+ Memberand HalfDork
7/18/14 6:07 p.m.
So yeah. About to go on a road trip in my friends car and this needs to be fixed beforehand. Is there a fuse I can pull? Looking for the quick fix for now, the road is calling.
BoxheadTim
BoxheadTim GRM+ Memberand UltimaDork
7/18/14 6:11 p.m.
I would at least check the oil level before pulling anything.
mr2peak
7/18/14 6:33 p.m.
He has ordered an overdrive bypass unit.
Plan now is to take a different car.
Junkyard_Dog
Junkyard_Dog SuperDork
7/18/14 6:35 p.m.
Auto or Manual? Either way it's probably the wiring at the solenoid deteriorating. Crawl underneath with some electrical tape and you will either be able to rig it or it'll crumble to dust. Problem solved regardless.
Junkyard_Dog
7/18/14 6:37 p.m.
mr2peak wrote: He has ordered an overdrive bypass unit. Plan now is to take a different car.
Lame. Anyone who can solder and/or replace the completely external solenoid can fix this in about ten minutes. On my first automatic brick it was actually quicker to fix the wires than to install the block off plate for the bypass.
boulder_dweeb
boulder_dweeb New Reader
7/18/14 6:47 p.m.
The OD switch on the manual shift lever is suspect on these cars. Easy fix. If it isn't leaking fluid, then the problem is in the controls.
Rog
s0K0Dj1OxRpmxFtDqfit7feyQrF7AZagLzQ4xmRfCMHP9jkuOgtxWfakPlOJhNuA
