I had a really strange thing happen the other day with the oil filer in my 924s. About 3 weeks ago I started noticing a buzzing noise while driving my car. It would happen at random times. Random RPM loading temp ect. Eventually I noticed that if I touched the accusump in my car it was vibrating with the buzzing.
The long of it is I eventually tracked it down to the oil filter (using a combination of a mechanics stethoscope and a screwdriver) for sound and feel.
So since I had a new filter on the shelf and a case of oil and the car was due anyway I changed the oil and viola the problem is gone. I decided to see what was going in the filter and was surprised to see that the drain back valve was completely broken up and the spring was bent. I assume that this was what was causing the buzzing noise. I also found a whole bunch of small plastic particles in the oil that I drained. I am assuming that the drain back valve failed and broke up and was vibrating / buzzing in the filter housing.
Anyway this is the first time I have ever had this happen. I have cracked filers. I have had filters explode, seams let go, gaskets blow out, filer media disintegrate but this is a first. The noise it was making I can only describe as horrific. I really thought I had serious engine damage by the sound of it.
Now this got me thinking. The filter was an STP. I had never used their filter before but I was in a pinch. Last fall I was doing an oil change and I thought I had a filter on the shelf. Turned out I was wrong (Ya I know) so I had to get one from the local auto parts store and it was all they had that fit my car. I thought I would just use it and then do a "short change" of the oil after a couple thousand miles.
But, as I am sure everyone can relate to, life got in the way and the next thing you know I realized that I had not changed the oil since last fall making the mileage close to 4K (maybe more!!!!!!). This is not good as I am only running dino based oil. I have found that if I run full synthetic the seals on my motor start to leak. If i run a blend or strait dino juice the leaks go away. This is particularly a problem with the gasket at the back of the cam tower.
Anyway back on topic. This whole thing got me thinking about filters. I have never been a oil filter connoisseur as some people are. Some swear by this and others want that. I just never had really been all that concerned. When we raced Toyota's we only used Toyota filters (people said they were the best) When I tracked the Porsche it got MAHLE but now that it is mostly a street toy It get WIX/NAPA, Bosch, and yes even the bright orange ones on an occasion. I never really have worried about it. And this is why:
When you check your oil do you really check your oil? In other words what does it actually look like? What does it smell like? I usually clean the dipstick with my fingers and then rub them together. Any grit? How "smooth" is it? How slick is it? How about the viscosity? My old man would actually taste it!!!! I have seen so many people check their oil and it is black as tar but as long as it is at the proper level and they have not gone the prescribed millage they are ok with it. Checking your oil to me has always meant you are actually looking at the condition of the oil that is in the motor. My dad taught me to do this. Time and millage should not be the sole determining factor of when to change the oil and more to the point if you oil looks like sludge and feels like water with a touch of grit in it you should change it no matter what the millage/time. So this brings me back to the filter selection. Since I change my oil based on its condition and not millage does the filter matter as much? I have always thought that it did not. If you are changing solely based on a prescribed millage than I guess it would but since don't do this and have actually got away from the synthetic oils is the filter as important? I am not saying use the cheapest one out there. Far from it! Using a good brand name can never hurt but the last filer I got cost almost $20 (for the NAPA/Wix) Where as I can get MAHLE or OE Porsche or Bosch for around $8-$10 and Fram for about $5 . And just to stir the "Fram is bad" pot . I here and see everyone saying bad things about them but I have never actually heard or seen of a motor failure that can be blamed on a Fram filter. I have had them split and explode but that was operator error not the filters fault. Can anyone actually show me a motor that has failed and it can be directly attributed to using a Fram filer?
Over the years I have probably used more Fram filters than all others combined. I have used them on virtually every car I have had and never had an issue but again I actually check my oil so that may be the difference.
Anyway, Thanks for reading my ramblings!!
