On my perpetual S10 project, I took a detour and decided to test the stereo I bought for it. The underhood wiring is not fully run, so I am powering the two battery wires that go into the cab directly with a car battery. The stereo would not work, so I started checking voltages. I used the stereo harness for this, and then switched over to the cigarette lighter as it was easier to test. Here's what I was seeing.
In the cab, orange is usually battery power, and pink is ignition power:
Battery connected, key off:
Orange - 12.5V
Pink - 0V
Battery connected, key on:
Orange - 8-9V
Pink - 8-9V
I started pulling fuses. Two were of note:
Battery connected, key off, IGN/DM fuse pulled. I think this may kill power to the cigarette lighter
Orange - 0V
Pink - 0V
Battery connected, key on, IGN/DM fuse pulled.
Orange - -3.7 to -3.9V
Pink (can't remember if I checked it)
Switched to a different fuse pulled.
Battery connected, key on, IGN/GAU fuse pulled.
Orange - ~12V
Pink - ~12V (However, my radio will power up, then immediately power down, like it is not getting enough to keep running)
So, with the fuse that may kill power to the cigarette lighter, I am getting negative voltage to it, when the ignition is on. When the fuse that powers the gauge cluster is removed, suddenly, I am getting the voltage level I am expecting. I have tried this with two different batteries.
Questions:
- Does this indicate there is something in the gauge cluster that is causing a reversed polarity signal? If so, what could it be? There is some wiring that goes to the cluster from the now non-existent original computer. Is it possible I need to track down and ground some of them?
- Do I need to just finish the underhood wiring, and see if the problem still exists? As far as I know, the two red wires I have connected the battery to are the only ones that send power to the cabin.
Happy to answer questions about the configuration as best as I can.
