A 91 should be an LA 360, but with a roller cam. A whole Magnum engine should swap in with a little work if needed and might be easier to find in a junkyard at this point. Externally, the Magnum will still accept the LA style motor mounts and your distributor should swap in as well.
Intake manifold mounting is different between an LA and Magnum, but there are 4bbl intakes with the Magnum bolt pattern that would let you keep the existing TBI setup (assuming that's what your truck has).
Internally, the Magnum has some differences. There's no mechanical fuel pump drive, the valvetrain is different (oiling to the heads is handled differently and Magnums have paired pedestal rockers instead of the LA style shaft rocker setup). All Magnums are roller cam. The factory heads don't flow great, but they're better than just about all of the factory LA heads. Most factory Magnum heads are cracked between the valve seats on one or more cylinders, but most never crack deep enough to leak anything (so you'd never know until you pull them).
Bellhousing pattern is the same, so you can run the same trans behind an LA or Magnum. In both generations the 360 is externally balanced, but be aware that the external balance is different for an LA vs a Magnum 360. Magnum 318s are internally balanced, can't remember for the LA 318 (or 340).
If you decide to up the power any, magnum blocks and internals are fairly strong. Weakest link is the stock pistons, but even those will take a good bit if you keep it from detonating. Somewhere in the 700 - 800hp range supposedly the blocks split down the middle like a Ford 302 with the theory being that the vertical intake manifold bolts make the setup weaker (as the manifold is basically wedging the head apart). There's some merit to that theory, as I have seen a case of someone over tightening the intake bolts on a Magnum, at which point the head gaskets promptly stopped sealing and required the heads to come off.
The info in the quote below is all solid, although IIRC it is possible to drill the oiling holes in the block deck to run LA heads on a Magnum block. And I've heard mention that some early year Magnums had them drilled from the factory.
Russian Warship, Go Berkeley Yourself said:
In reply to Pete. (l33t FS) :
The 5.2 Magnum came out in '92. The 5.9 Magnum in '93. The last model year of the Dodge Diplomat was 1988. It was also the last MoPar V8 passenger car until the LX platform cars came out.
LA oils the rockers through the block into the rocker shaft, while the Magnum oils through the push rods. The heads are not interchangable. Likewise the intake manifolds are drilled at different angles when they bolt to the heads. The rockers were based on the AMC architecture, as many of the AMC engineers after the buyout ended up in the Magnum engine development.
