I want this text to be normal
Are Wheels a Wear Item? Yes, They Are
When I cut and paste some text from elsewhere (example above), presumably from areas where the text has a header tag, it shows up here with a header tag. The remove formatting button does not remove this. Also, if I then hit enter and type text above it, it inherits the same header tag (h5 in this case). How do I fix this in posts?
Is there a way to force text to be body text? Markup doesn't seem to list a way to force paragrapp formatting?
