Swank Force One wrote:
You stop that right naow. I seen a green/dark tan topped version of one these this morning and said to myself "I want that."
Obligatory:
Obligatory:
bentwrench wrote:Donebrokeit wrote:Do you know why there is a second set of injectors above the stack inlet? Hint: you need a scale
I give up - why?
Obligatory:
Nick_Comstock wrote:neon4891 wrote:My neighbor had one of those. I got to play on it a couple times before I wasn't allowed in his yard anymore.
Did you play Jabba the Hutt to his sister's Leia?
bgkast wrote:Nick_Comstock wrote:Did you play Jabba the Hutt to his sister's Leia?neon4891 wrote:My neighbor had one of those. I got to play on it a couple times before I wasn't allowed in his yard anymore.
I had to punch that kid in the face
I am going to guess that the initial injectors can't flow enough fuel at WOT to reach the max performance that the engine is capable of, so the secondaries kick in when the throttle plate is wide open.
Sorry, hotlinking on my phone is a PITA. No pix for you!
EastCoastMojo wrote:bentwrench wrote:I am going to guess that the initial injectors can't flow enough fuel at WOT to reach the max performance that the engine is capable of, so the secondaries kick in when the throttle plate is wide open. Sorry, hotlinking on my phone is a PITA. No pix for you!Donebrokeit wrote:Do you know why there is a second set of injectors above the stack inlet? Hint: you need a scale
Not really, the upper injector changes the weight of the air column and effectively changes the tuned length of the runner. Dr Frankenstein and I pondered over many evenings on the dyno about making a sliding intake (trombone) to optimize torque and HP, we weren't thinking outside the box. A few years later this concept came along.
Here's another a 300?hp Honda with a slide throttle, you can see the main lower injectors and the upper 4 hoses go to nozzles in the airbox at the top of the runners.
