Say goodbye to extra-large body gaps and hello to the ultimate budget *ANYTHING (cars,houses, boats)* filler combo: bubble wrap and spray foam.
*fixed it for ya*
Spray the bubblewrap, or garbage bags, with water before foam cos the foam needs to absorb moisture from the air to cure.
Reason being that the plastic prevents moisture absorption, lessening the depth of cured foam. The core will remain soggy forever and eventually collapse when u cut/sand it.
If you cover the foam with plastic or plywood to maintain (mold) a particular shape, then spray that covering panel with water as well.
Depending on atmospherics, 3" per day of foam build-up is max.
Garbage bag plastic will release from the cured foam.
NOTHING WILL RELEASE FROM UNCURED FOAM!!! Your skin will be case-hardened for several days and your fingernails will be puffy for the next 5 weeks. Ask me how I know.
