Tech Tip: This is how you can use zip ties to keep wiring tidy.
Paris
By Paris Van Gorder
May 2, 2025 | Wiring, Tech Tips, Project car
Photography by Paris Van Gorder
Tired of your engine bay looking like a bowl of spaghetti? Or losing track of one wire while working? Try this simple cable management trick.
What will you need? Zip ties. That’s it–no special tool or material, just good old dependable zip ties.
Step 1: Gather all the wires you want to manage within your work area and loop them together with a single zip tie. Leave it loose.
Step 2: Around that original zip tie and in between each wire, loop another zip tie at a right angle–kind of like you’re making a tic-tac-toe board. Repeat as many times as needed and tighten as desired.
Now, admire your work because you’re done.
That’s right–in just two easy steps, your wires are now separated and secured. And if you want to change something, all you have to do is loosen or cut the zip ties. No hassle–you can even reuse them.
Join Free Join our community to easily find more Wiring, Tech Tips and Project car news.
Comments
J.A. Ackley
J.A. Ackley Senior Editor
5/2/25 4:20 p.m.
Zip ties are a wonderful tool. I've used my fair share over the years.
californiamilleghia
californiamilleghia PowerDork
5/2/25 4:47 p.m.
I ordered these ,  right now they are only $5.99 for 400 zipties (4 sizes-100pc)
https://www.amazon.com/dp/B0C2Z4L3S6?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
ShawnG
ShawnG MegaDork
5/2/25 6:32 p.m.
Zip ties are incredible.
They can either make a project look very professional or very amateur, depending on their use.
porschenut
porschenut Dork
5/2/25 7:30 p.m.
Was on a roadkill episode years ago.  They did it for plug wires.
GT
GT New Reader
5/3/25 1:06 a.m.
Loosen zip ties?!? What black magic voodoo is this?? Or are they some fancy option 74x more expensive than regular ones?
Paris Van Gorder
Paris Van Gorder Associate editor
5/5/25 9:13 a.m.
In reply to GT :
Hahaha, I use a small flat head screw driver to loosen mine.
yjHYlMEKZfftGR2cqqmvuIkoXByEJijPMztWEpWSdYcZlfYNUv47fi04AmdwiPDO
