How old is the battery? Call me crazy, but that's always the first place I look when I get weird sensor codes on a modern car. Computers can be super sensitive to voltage issues.
Photography by J.G. Pasterjak
This one felt like it should have been easy to solve. In the end, maybe it was, and maybe it wasn’t.
“I feel like the problem is gone but I don’t feel that satisfying feeling that we ‘solved’ it,” says BimmerWorld’s Phil Wurz after we seemingly rectified a recent electronic situation.
So, what actually happened? Let’s back up a little and …
You can read it for free in 134 days or subscribe to GRM+ to read right now.
Already a member?
Tom Suddard said:How old is the battery? Call me crazy, but that's always the first place I look when I get weird sensor codes on a modern car. Computers can be super sensitive to voltage issues.
We put a brand new Optima in it in August and it sits on a battery maintainer mostly. But, yeah, I hear you. Flaky BMW batteries are known to do some weird, haunting-level stuff when they start to go south.
This happens on my Volvo once or twice a year.
Thankfully you can recalibrate TPMS from inside the car with a few buttons, but I'm left with the same feeling. It's fixed, but it's not "fixed"
Do you still have the old sensors, can you check the voltage on their batteries? If they all have the same crap-quality batteries, were all from the same batch perhaps they all popped around the same time? You said that this mostly sits on a maintainer which tells me that it may have failed over a few weeks/month and you wouldn't have noticed?
I one time experienced a temporary TPMS failure driving on an interstate by a military base. The only thing I could chock that up to was to interference. Odd occurrence.
Look at the complete system. Sensors- unlikely fault. New antenna module- kinda sorta works but no confidence. What about the wiring and connectors? Corrosion? Connector not making complete contact? Insulation chafed through?
You know the rules; of you don't KNOW that you've found the problem, then you haven't found the problem.
In reply to J.A. Ackley :
You should try replicating the result, but this time, you should wear a tinfoil hat.
Displaying 1-10 of 26 commentsView all comments on the GRM forums
