Oct 30, 2010 update on chknhwk's 2004 Jaguar X-Type
Swaybars 1.1!
update image
So one of the front sway bar brackets broke while at VIR (operator error) so I installed some smaller bushings so I could reuse the stock Jaguar brackets without having to modify them. I’m thinking this may have weakened them a little too much. While in there I found the other bracket had also broken.
Anyway, turns out the setup I have now won’t work as the bushings are too small to locate the sway bar properly.
SteoItAG1Ktd7YmYK7MA8S2VPp8vxkbhfJSGyeTJ9KhATN7ROhTdgI8smO0Ibzh3
