Started on May 9 by drtalon123
1993 Honda Civic SI Hatchback
“The HPDE Tool” Engine (B or D Series Options) B16A Engine -Blueprinted and balanced -450whp tuned, 250-300whp tracked -RAC Turbo GT2860RS, externally gated -11.5:1 CR, Wiseco Forged Pistons -Speedfactory B16 Rods -B18C5 Type R oil pump -IJ B16 teflon crank scraper -E85 B16A Transmission -Integra GSR Transmission -Stock GSR gear ratios -Synchrotech carbon master kit -Synchrotech GSR diff tapered-to-ball bearing conversion kit -mFactory 1.0 way plate style LSD -mFactory 4.9 final drive D16Y8 Engine -Blueprinted and balanced -375whp tuned, 300whp tracked -Garrett GT3271, externally gated -Colt Cams custom grind Tri-Flow V2 VTEC cam -CNCWerx Cylinder Support System (closed deck) -9.8:1 CR, Wiseco forged pistons -P2P0 I-Beam rods -D16Z6 crankshaft -ARP SRT4 11mm head studs -Bad Guys ported OEM oil pump -E85 D16Y8 Transmission -D16Y5 (CX/HX) gear ratios -0.848 5th gear -D16Y8 final drive -Synchrotech carbon master kit -mFactory helical LSD Chassis/Aero -Home Depot Racing front splitter (a.k.a The Ron Burgundy; it smells of rich mahogany) -PCI Racing 5” aluminum side skirts -PCI Racing swan mount rear wing -Autopower Bolt-In NASA CCR reg. cage -Momo/OMP FIA bucket seats -Momo wheel/NRG carbon quick release -PCI Racing seat mounts -RJS Racing 5 point harnesses -Rear battery relocate -Aluminum dashboard -Lifeline Fire Suppression -K-Tuned B/D Shifter X -Oil-To-Water Oil Cooler setup (chassis integrated, engine independent) Suspension -K-Tuned K1 shocks -Swift Springs 14k front, 10k rear -Energy suspension polyurethane full chassis bushing kit -PCI racing RTA solid spherical bushings -PCI racing rear solid spherical upper control arms -PCI racking rear solid toe links -Whiteline knock-off rear sway bar with spherical end links -Honed front and rear Roll Center correction Brakes -Wilwood BBK 6 Piston front kit -BP40 front pads -Stock SI rear disc brakes -Stainless caliper hoses -Honed brake booster delete kit -Home Depot Racing brake ducts Wheels and Tires -Konig Backbone 16x7” -The cheapest 100 or 200TW tires I can get my hands on
Join Free Join our community to easily find more reader's rides.
Add your comment
See more
5ILGgaMk8e2WsjCjZBXhDYk3Tnx4p2hiefojBXsWeUWTJZpcxQK4BVXGFTCyKpuF
