Nov 6, 2012 update on P71's 1973 AMC Javelin
Adjustments Part 2
update image
I started with the squeaky belts. They stretched as they wore in, so I had to adjust them a bit. Alternator was still charging and the battery checked out fine. The power steering developed some nasty weeps, but after cleaning the lines, I found the fittings and hose clamps all loose. I tightened everything up and topped off the fluid, not a drip since!
atvC4LicIbDdir8g5qTyGcZ641oEpP4LEv7ut6aUhQ6CtHNNcdVMXM7ZGt0hhLFy
