Feb 21, 2011 update on P71's 1973 AMC Javelin
Ignition switch
update image
Still had a no-start situation with the Javelin, so I grabbed a new ignition switch and installed it. This is a common 70’s GM unit (as AMC switched to a GM column in 70). It actually bolts to the bottom of the column, and the key moves a metal rod with a hook that goes inside of this switch.
rgzJ1I6qHlRo2JdMBDlJ12nTxcHFnlyqCzklSDvrt16mgoLPvwcad9byRmNbUN5N
