Feb 4, 2012 update on P71's 1973 AMC Javelin
Primer bomb!
update image
After hand sanding or wire brushing in the channels, using compressed air to spray all of the sanding dust away, and then wiping everything down with cloths, it was time to prime. I used some high-build primer on the quarter panel joins, but otherwise everything got a coat of plain light gray primer. This is not a permanent situation, this is just an attempt to slow down any corrosion and protect the good metal that’s left.
nqFwap32rCFoTlksDFntHTAoy5ymOOcPne38MtxTyCwMa48SeAVuXnvSMeOsdAz0
