Feb 22, 2013 update on P71's 1973 AMC Javelin
The fronts, not so much...
update image
That same wheel is horribly sized for the front, however. The 285 is the absolute max you can get on a stock front suspension and fender. This is with a 3.5” spacer. The 2.5” didn’t fit inwards enough. Honestly, this particular wheel needed a 3” spacer, but that’s so not the right way to do it. I would go with a wheel that has 3” less offset and maybe 1/2” less width and run a 275.
PxUY4a06lXOhSop8M0IgjwJdorOEM8GMXCVSEwKOoSUkkwjFCki5zznX1dU48qDm
