You probably spend a lot of time in your garage, but there’s no reason why the space has to be an uncomfortable, disorganized hovel. Likewise, turning it into a clean, efficient work area shouldn’t drain your checking account.
The name of the game is shopping smartly and effectively. Sure, you might really want that newfangled gizmo, but what about first attacking the basics? After all, storage, light and comfort are nothing to scoff at—and when you do want to splurge on extras, you’ll be able to enjoy them.
We have been at the magazine game for a quarter of a century, and much of that time has been spent in the shop. Since we like you guys so much, here are 25 of our favorite low-buck shop tips. You can thank us by continuing to build cool cars.
Kitchen remodeling is an American tradition, and a lot of that old cabinetry and hardware is simply heaved into the landfill. Sure, the decor might be mid-’70s Americana, but it should be fine for your shop. We once spied 8-plus feet of old kitchen cupboards sitting by the side of the road. The look was a bit dated, but the units would have been perfect for keeping car care products, cleaning supplies and other garage stuff.
There is no need to work in a cave. A dark garage is a tiring and unsafe work environment. Have a contractor add some outlets to the ceiling of your garage, then hang a bunch of four-foot, twin-tube fluorescent light fixtures. Paint the walls and ceiling white to maximize the effectiveness of the lights.
Concrete is cold and hard, and creepers tend to get hung up on every little crack and pebble. Our low-buck solution: carpet. Old carpet makes a great shop floor, and it often can be found for free. Ask the local installers to keep you in mind the next time they’re redoing someone’s home—they might be glad to unload the unwanted stuff. When it gets dirty, throw it away and repeat the process.
We learned this one from Carl Heideman: Grease is the solution to many of the world’s problems. Sure, a thin coating of the stuff can lubricate just about anything, but it also makes a great anti-seize compound. Apply grease to gaskets as well as the insides of hoses to aid later disassembly. A tube of grease and an inexpensive acid brush go a long way.
The answers to many automotive problems can be found on the internet, and more than once we have found ourselves bringing a laptop out to the garage. Adding a simple wireless router to your home network makes cruising helpful forums from the garage a breeze.
If you need a particular socket for a project, grab the entire set. This Craftsman 10mm, six-point deep socket set, for example, even includes a storage tray–which means you won’t have to stop work and enlist a search party the next time you need a deep-well socket.
We built this movable table years ago, and it’s been a great companion. After all, it’s strong enough to support a car body and features enough real estate for almost any project. It also has 4-inch casters at one end to make it mobile. The frame is made from 2x6-inch lumber, while a piece of 3/4-inch plywood forms the top. You’re free to make one in any size that you prefer, but ours is 30 inches high, 96 inches long and 48 inches deep. An old solid-core door also works well for the top, which would then dictate the other measurements. For extra convenience, we attached an outlet strip to the side of our table.
Air compressors are amazing pieces of equipment. They also take up valuable garage space and suck down copious amounts of electricity. If you mainly need compressed air to run your impact wrench, consider the new generation of electric impact guns.
Amazon is more than just books and music, as they also offer a huge selection of tools. The prices are more than competitive, we’re also big fans of the Amazon wish list, as it clues in our relatives to the fact that we prefer car stuff over socks and shirts.
Most of those little 12-volt electric compressors are a joke, but a bicycle air pump is an efficient, inexpensive piece of equipment. Yes, it can be used to air up your car tires. As a bonus, you’ll get some exercise out of the deal.
We all wish we could have a huge garage, but sometimes reality dictates otherwise. How about constructing a shed out back? Stick your bulky items and garden equipment in the shed to free up valuable garage space.
Batteries are expensive. They’re also clogging up our landfills. In this day and age, there’s no reason not to own a quality rechargeable flashlight.
Those plastic mail bins are an awesome storage solution. They’re sturdy, nestable and just the right size. Unfortunately, it’s illegal to employ them for personal use: In theory there’s a $1000 fine and three years in the slammer if you’re caught with them. As a more pleasant alternative, you can purchase nearly identical bins from companies like Uline.
Quality tools have a long service life, and we have seen some amazing deals on secondhand merchandise. We favor face-to-face transactions for used tool sales so we can inspect the merchandise ourselves. Buying in person also eliminates the need for expensive shipping. Some of our favorite haunts for used shop equipment are swap meets, pawn shops, garage sales and auctions. And don’t forget about the big pieces of equipment, as a preowned welder, lift, hydraulic press or bead blast cabinet can be a great deal.
Some things just don’t want to stack neatly: bungie cords, jumper cables, clean rags and the like. Storage containers like this one from Rubbermaid come in many different shapes and sizes, and they’re a perfect solution for keeping things organized, clean and out of sight.
Billions of plastic drink bottles are unceremoniously tossed every year, but they can lead a second life. We have made oil dry scoops out of the gallon-sized jugs, while bottles of nearly any size can be reconfigured into funnels. The thicker ones are also good for transporting used fluids to the recycling center.
Invest in good, solid shelves—either build them yourself or buy some quality units. We have had excellent luck with heavy-duty wire metal shelves, as they’re tough, strong and deep. You can also access your stuff from all four sides. If you have the space and need to store really big items, shop around for preowned pallet racks—there’s an entire industry dedicated to them. And a little safety tip: Secure the shelves to the wall so they don’t tip over when loaded.
What was true in high school is true today: Good notes are a good practice. In addition to our dry erase board on the wall, we dedicate a notebook to each car in our fleet. It’s a simple, cheap procedure that frees up brainpower for other things in life.
We love our interlocking foam floor pads. They’re light, inexpensive and portable, making them perfect for the shop as well as the track. We’ve even used them to cover the floors in enclosed trailers. Basically, we put them wherever we want an insulated, non-fatiguing surface.
We like big, expansive work benches, and there’s no reason you can’t build one yourself out of used base cabinets and a bunch of 2x4s. A cordless drill will be your best friend for this project. To optimize the work surface, cruise the scrap metal yards for a piece of 18-gauge stainless or hot-rolled steel.
Seems like all of us have modified screwdrivers for different purposes, but usually it’s the standard ones that get sacrificed. Ever need to reach a Phillips screw that’s buried? Remove the handle from a spare Phillips screwdriver and fit the tail end in your electric drill. We used a Dremel to free this one.
Hang a retractable extension cord reel right in the middle of the garage ceiling and you’ll always have power at your fingertips. Many garages have a plug up there for the door opener, so generally no extra wiring is needed.
There’s no reason why your garage has be devoid of all comforts and conveniences. Shop classifieds and local yard sales for an old stereo system, bar stool and micro fridge.
Ever lose a tool? It stinks, right? It’s a time-consuming process, but fitting foam organizers to your tool box makes it easy to determine when something has gone AWOL. We have also found that this setup helps keep tools in place when traveling—it’s quieter, too. The DIY kits take a while to cut, but they allow you to customize your setup.
Don’t have it and don’t want to own it? How about borrowing it? Many of the national auto parts chains lend specialized tools—steering wheel pullers, ball joint separators, spring compressors, coolant pressure testers and air-conditioning clutch pulley pullers. Some also rent out engine hoists and diagnostic equipment. Expect to leave a deposit, but in the end your budget won’t get dinged.
Few more ideas. 1) Wipe board with different color pens.. great "in your face" reminders, and you can cross things off as you go., 2) old bike tubes for padding and to prevent scratches, 3) old bearing race halves for use in a press,
In reply to das86turbo :
You mention a wipe board - I have some shelving units, one of which is creating a 'wall' in the garage. I put dry erase board on the back of it to
A) conceal what's on the rack from prying eyes
B) use as a dry erase board for my ideas/checklist.
It's a great 'tool' that was cheap and multi-purpose
We have an expansive patio; I use a small deck box to store bigger items for the Datsun (doors bell housings etc).
I didn't want more than one shed in the back so this was a really good solution; it creates additional seating and frees up garage space.
The only other thing I'll add is put as much as possible on wheels: most of my F500 engines and spares are in storage bins (snowmobile engines are small). They are stacked against the wall in the 3rd car bay of the garage. Having them on wheels lets me move them if I need more work space for the Datsun.
Hallways are good places to store hardware so you can see them and get what you want quickly! Added the light fixtures years ago so I could see.
Update on the lights:
Instead of 4' fluorescent strips, get 4' LEDs instead.
IIRC enough to brightly light a 2-car garage were about $80 on Amazon. I have an extra pair over my workbench as task lighting.
I appreciate the workmanship on Trucke's hallway shelves. The downside of rabbeted shelves is lack of adjustability. An easy alternate is to drill a series of holes and use the little "L with a pin" shelf holders. The 1" spacing of pegboard scrap makes a good drilling jig, although it doesn't last very long. Then, when you want a different arrangement, just move the shelf holders to the new spacing.
I didn't see any mention of sinks. If you can keep the pipes from freezing, a laundry sink is a very useful addition to a garage.
My tip is to buy clear storage totes. It's much easier to look and see what's in them then trying to constantly label and relabel. Home Depot has smoked see-through totes that are pretty strong
Garage Journal is the place to go if you really want to geek out. They tend to have much larger spaces than most, though. I'd strongly suggest a LOT more light than you think you need. I went with relatively cheap dual 4 foot housings and high CRI led bulbs and it's been the single best addition to the garage. If I recall I have something like 20 of them in my 3 car garage and its great. There's a while lighting forum over at GJ with links to lighting simulators/tools, and you can do it fairly cheap as you'll need enough you can get a doscount at lighting supply sites if you call.
I do all 3 of those things! So much that I just scrapped some excess bearing halves that I had several duplicates of. The 4x5 white board in my shop is priceless. If I can't even find a 10mm how am supposed to remember what's next on the list
A more recent tip from my fabrication of a ramp truck to haul the Exocet with: welding curtains.
I'm doing a lot of welding, grinding, painting, etc, on this project. As we have a dual purpose parking / project garage, I'd like to avoid getting the other cars dirty and certainly don't want weld slag flying toward them. So, I hung a large tarp I had from another project of sorts, from the ceiling. So far so good, though if I were doing it again, I would probably have hung it a bit differently.
I swear that no matter how big your garage is, you will always find scenarios in which it could definitely be larger. =P
Displaying 1-10 of 37 commentsView all comments on the GRM forums
