Real Carbon-Based Fiber Splitter
Per
Update by Per Schroeder to the LeGrand Mk 18 project car
Nov 17, 2008
Sponsored by
Our woodworking begins.
The splitter extends forward about 2 inches from the edge of the fiberglass.
We're fitting the splitter prior to painting it black.
Some head-scratching here. We'll have to work out some longer ramps.
Why plywood? Two reasons: It’s strong and it’s cheap. Besides, wood is a carbon-based fiber, so we’ve got that joke going for us.
A splitter is an aerodynamic device that extends horizontally from the leading bottom edge of a car. As its name implies, it cleanly splits the air traveling over or under the car, increasing front downforce or front grip at speed.
We made a splitter out of half-inch hardwood plywood and installed it on the nose of our LeGrand. Aside from the aerodynamic benefits, it also will strengthen the nose against pylon-inflicted bangs and bruises. Why plywood? Two reasons: It’s strong and it’s cheap. Besides, wood is a carbon-based fiber, so we’ve got that joke going for us.
Since the installation, we’ve run into one problem: The low and long nose is creating clearance problems when we try to load the car onto our new enclosed trailer. We bought a 7x14 tandem axle Pace Trailer from The Car Shop that is a good size for a sports racer like the LeGrand. We’re going to have to work out a setup that will block up the back of the door ramp. We’ll also need additional ramps to get the car safely into the trailer without damaging the splitter.
Comments
Capt Slow
Capt Slow Dork
11/17/08 12:08 p.m.
Whats the car look like with the bodywork off?
Per Schroeder
Per Schroeder PowerDork
11/17/08 12:45 p.m.
It's an aluminum monocoque.
Here's a guy that's restoring a LeGrand here in Florida.
http://www.caseyhaddock.blogspot.com/
turboswede
turboswede GRM+ Memberand UltimaDork
11/17/08 3:26 p.m.
Nice! Slather it in some resin and shoot it with some semi-gloss black and you'll be Mad Tyte YO!
Personally, I would look at making the nose quick release and just pop it off before loading.
Also, a Formula Ford buddy of mine had the same problem with his FF and vowed to never buy another trailer with a ramp tailgate. He said next time he'd build longer, collapsible ramps or have a liftgate (keep in mind the FF only weighs 1200lbs) Another thought was to put air shocks in the back of the tow vehicle and to raise the front of the trailer slightly.
David_Chong
David_Chong New Reader
11/18/08 11:13 a.m.
For some reason, pics #3 and #4 no workie for me.
chknhwk
chknhwk HalfDork
11/18/08 5:39 p.m.
3 and #4 no workie for me, either.
Per Schroeder
11/18/08 5:43 p.m.
That's weird, workie here. Baxter?
Gonzo_Bmod
Gonzo_Bmod Reader
11/18/08 6:25 p.m.
Per,
You may want to look at either recessing those splitter bolts a bit or maybe using a carriage bolt. I took my old splitter off the Legrand and had to cut my bolts off as the heads were all worn beyond recognition or use. Price you pay for low cars.....
Tim Baxter
Tim Baxter PowerDork
11/19/08 9:39 p.m.
David, chicknhwk, what happens if you go straight to the image: http://grassrootsmotorsports.com/media/img/projectcars/legrandsplitback_t105.jpg
what about here: http://grassrootsmotorsports.com/media/img/projectcars/legrandsplitback.jpg
Sponsored by
GRM Ad Dept
tvps36LWLWRfoQvih8ZmPWjtPsR4bWjDkpjHXyb68IiUD9Pr9N4PJBdGcs5hX9st
