One more task for the night: figuring out an adjustable pulley system for the alternator. The solution involved an old Triumph Spitfire bumper bracket. Seriously.
Time to install the fuel cell. Following SCCA guidelines, we’ll wind up with at least 6 inches between the bottom of the cell and the ground. We’re also going to support the cell with a tough, gusseted cage.
First, we needed to determine the cell’s mounting point. We figured we’d bias it slightly to the right to offset the driver’s weight. Then we cut a hole in the floor with a plasma cutter and stared fabricating our mounting apparatus.
We also spent some time on our seat brackets. We found some factory Mustang sliders that looked close. Turns out they needed some fabrication, as they positioned the seat too high inside the car.
We chopped off the feet and rewelded them to lower the seat. The floor also needed some notching to yield more clearance.
Displaying 1-2 of 2 commentsView all comments on the GRM forums
