Finally-the Cage Match
David S.
Update by David S. Wallens to the Lincoln Mark VII project car
Dec 8, 2010
Sponsored by
First step for this session: Yank all of the glass for better access to the roll cage.
We also cut off the driver's-side door.
To provide a bit more room for our drivers, we also slightly tweaked the A-pillar bars.
Geoff helped with tonight's cage fitting.
We're making some progress, as the main cage is mostly attached to the chassis.
We’d love to go with 16-inch wheels, but we don’t really have the budget for that.
Time to finish welding in the cage, and tonight we got some help: Geoff Thompson, setter-upper of many GRM project cars, came over to lend some assistance. Geoff has been involved in many race car builds, from local roundy-round machines to ones bound for the Rolex 24 At Daytona.
His first suggestion: Yank all of the glass for better access to the interior. Our Lincoln’s doors had been welded shut (think “Dukes of Hazzard”), so we cut open the driver’s-side one—also for better access. The hinges were still present, too.
We also made a few tweaks to our cage. We used our Eastwood tubing bender to open up the A-pillar bars. Since we don’t have to clear a dashboard or any interior panels, we can take advantage of the open space and give our drivers a bit more room.
We used a hydraulic porta-power to spread the rear cage legs. That will cure the fact that our cage was a tiny bit too narrow for our mounting pads.
We also investigated tires. Right now we have some ancient 215/70R15 Kendas on some 15x7-inch steel wheels. Looks like a 225/60R15 Kumho Ecsta ASX may be the hot setup: only 4.5 percent shorter and slightly wider. We’d love to go with 16-inch wheels, but we don’t really have the budget for that.
Comments
Sponsored by
GRM Ad Dept
h4OJD3QsauAynfaDOLMKazO5te1VvHcpfgLoN1Z4scp1wPk9vg14eTTOnHuy10Oh
