Rotary Miata: Fitting a Triangle in a Round Hole
Ed
Update by Ed Higginbotham to the Mazda Rotary Miata project car
Jul 5, 2016
Sponsored by
At the end of the day we had a rolling Miata with a properly fitted 13B drivetrain.
The firewall had to be modified quite a bit.
But the finished product looked great.
As for the subframe, we had to completely cut the middle section out and replace it with an very strong angled piece of steel.
Viola. A properly fitted rotary engine.
After transporting this rotary Miata to Asheville, North Carolina, it was time to really get the project moving. After unloading, the first step was to remove the engine, transmission and subframe that we had just spent so much time and effort installing.
But there was no doubt about it. The engine had to be removed so that we could modify both the subframe and firewall to better accommodate the turbocharged, rotary engine. The drivetrain has to sit very far back in the engine bay.
After lots of more cutting, welding and painting, we finally had the space needed in the firewall to install the drivetrain without trouble.
As for the subframe, we had to completely cut the middle section out and replace it with an very strong angled piece of steel. That gave us the clearance on the oil pan we needed to smoothly slide the drivetrain into place.
Comments
Sponsored by
Treasure Coast Miata
uGHN45AquZJC79mfIYztDl8DOfPwquS8Q9QMhS69TIQm1JL0RC2NA0dauF1qLmgW
