Started on Dec. 21 by Moving_Target
1986 Ford Mustang LX Coupe
Originally a 2.3L LX that I’ve done a 5.0L conversion to. -Koni sport Struts and shocks -MM front and rear control arms -MM C/C plates -8.8 rear axle w/Detroit TruTrac diff and 3.55 gears -Infloor Subframe connectors -DIY Torque Arm and panhard bar -Modified stock k-member (raised control arm pickups) - MM bumpsteer kit due to the above mod -5 lug Cobra Brake kit using SN95 spindles -Magnaflow 2.5” catback - WC T5 transmission It had a 351W with Weiand Stealth 4bbl but I kind of destroyed it through my stupidity. Currently running a low compression (8.4 to 1) 302 w/factory 4bbl intake, 600cfm Holley w/vacuum secondaries and factory ‘84 iron heads aka a gutless turd (it’s not that bad but there’s never enough power, right?) The plan is to repair the rust damage, build a proper replacement 351W engine for it and convert it to EFI via Megasquirt. Behold, a wimpy C/P Car!
Latest updates
Sept. 29
Junkyard 351W for buildup
Spied an E250 with a 351W at the local pull-a-part and removed it yesterday as …
Aug. 22
Old Trunklid
An undershot of what the old one looks like right now. I may attempt to …
Aug. 22
Repairing Rusty Trunklid
I bought a trunklid to replace the rust damaged original on my ‘86 but it …
July 31
New shoes for the Rustang
Bought some Cooper Zeon RS3-S tires to replace the worn out Kumho 712s.
Join Free Join our community to easily find more reader's rides.
Add your comment
See more
CjsTVXNNVrIFGoHeyxThiAVM6stdiqW3spXD0ln8zOwfpvsX73Bx4lILB9jz64YR
