Started on May 17 by Schump
1973 Porsche 914 2.0 "S"
My daily driver & track mule in the PCA for all days I could afford as a poor college kid @ Virginia Tech who spent too uh time in our Formula SAE car shop. 90k==>~145k in 5.5 yrs + 2 weekends @ Watkins Glen & 12+ days @ Summit Point, WV (my home track, 1 hr W) Best money spent: $145 @ Advance Auto for BMW 320i front calipers, pads, and hard lines. Sleep Fri night/Sat morning after milling them to center up on our Bridgeport & installation in my teammate’s garage before heading 3 hrs up I-81 for a track day: 0.00 hours. Other mods: -Too many sets of Bridgestone RE-71s (Treadwear #=140!!!) -19mm front torsion bars -Poly Graphite front A-arm bushings (HUGE difference vs 22 yr old rubber) -145# progressive rear springs -19mm 911 master cylinder -fresh coat of epoxy sealer primer in a weird olive greenish grey that all our team rednecks were envious of -Rustoration aka purchase of a Lincoln Weld-Pack 100 & the gas conversion kit + a 4’x8’ sheet of 18 gauge steel + WAY too many hours replacing rust w/ metal and removing all the B&B that the original owner had applied when he reshot it metallic silver (Brazed & Bondo’d) -oil pressure gauge in center console to replace das clock -Removal of rr sway bar -gearbox replacement after I made it to my little bro’s house @ UVa w/ 3.5 gears left (I lost 4th w/ a big BANG otw there up I-81 and it was already jumping out of 1st and reverse and occasionally 5th gear). # of functioning gears the next morning: 0.0! {Perhaps the quarter-sized hole in the rr tranny cover made by an exploded speedo drive gear didn’t help, ESP since I only discovered it the night before @ a truck stop while refilling the gear oil completely???} -6 point harnesses -other stuff I can’t remember (She is currently behind my friend’s shop needing to be parted out or rebuilt)
Join Free Join our community to easily find more reader's rides.
Add your comment
See more
fqmEZTdO3hZqTkergw11YgbgFdC0jRTly916X6G1SXnvvsnIIcANR1kmge0O2dVA
