Story by Ben France
[Editor's Note: This article originally appeared in the May 2008 issue of Grassroots Motorsports.]
Nissan’s legendary Z-car has managed to survive a roller-coaster ride through its long history—one that has included several shifts in design focus as well as fluctuating production numbers—throwing the car-nut community for the occasional loop along the way. The Z has been Nissan’s top sporty car for North American consumers for more than 35 years, and during that time it has been met with praise from the automotive press as well as strong interest from the car-buying public. Those are about the only constants, though.
The Z has done well by evolving to meet the market’s needs. In just its first 15 years of existence, the model’s identity shifted from the 240Z, which was a lightweight two-seat sports car, to the 280ZX, which was a heavily optioned cruiser. The purists may have cried, but the model stayed afloat. When the third generation debuted with the 300ZX, the model’s focus moved even further into the grand touring realm, but back in the mid-’80s that seemed to be what the masses wanted, and sales were still brisk.
By the end of that decade, however, sales had begun to slow as contemporaries like the Toyota Supra and Mazda RX-7 started to beat the Z in the marketplace. Nissan desperately needed something to resurrect its standing as the top dog of the Japanese sports car segment. They responded by debuting the all-new-for-1990 Nissan 300ZX. It carried the Z32 chassis designation.
When the Z32 hit the public in the spring of 1989, it was met with universal praise. Heralded as a world-beater, the new Z-car was sleek, sexy, sporty and more. This was the first model change in the Z-car’s history that could legitimately be termed revolutionary, as opposed to merely evolutionary. (The earlier, Z31-chassis 300ZX had, despite its totally different appearance, shared some suspension architecture with the original models.)
The automotive press loved the new car—Road & Track magazine even called it “the class of its class.” Motor Trend named it their 1990 Import Car Of The Year, and Car and Driver practically reserved a permanent spot for it on their annual “10Best” list. In fact, the Z32-chassis 300ZX made that magazine’s top-10 list every year it was sold in North America.
The Z32-chassis 300ZX was a real sports car with a shape that immediately attracted the eye, but the sex appeal here was more Marilyn Monroe than Audrey Hepburn. In other words, it was a robust, heavy car. Curb weights varied depending on options, but ranged from about 3200 pounds for a cloth interior, base-model car to almost 3500 pounds for a loaded Turbo model. The 2+2 coupes fell somewhere in between.
While the new car’s styling got the blood stirring, the real thriller could be found under the hood. Although the engine’s VG30 designation was carried over from the previous 300ZX, this was actually a completely redesigned 3.0-liter V6. Designated the VG30DE, it featured dual overhead camshafts, an iron block with aluminum heads, four valves per cylinder, and cam timing that could vary based on engine rpm and throttle input. This engine also featured coil-on-plug direct fire ignition, dual throttle bodies, separate inlet tracts for each cylinder bank, a 7200 rpm redline and a 10.0:1 compression ratio.
All of this added up to 222 horsepower at 6400 rpm and 198 lb.-ft. of torque at 4800 rpm. When coupled with a 4.08:1 final drive ratio, this normally aspirated engine propelled the Z from zero to 60 in a respectable 7.1 seconds.
The suspension was also an all-new design, with an independent multi-link setup front and rear, that delivered excellent road handling for its day. The base 300ZX was able to pull .88g of lateral acceleration on a 200-foot skidpad and could get through a 700-foot slalom at 65 mph with relatively neutral balance.
The regular 300ZX was spiffy, sure, but Nissan had something special up their sleeve: In the fall of 1989, they released the 300ZX Turbo. This was the manufacturer’s own version of a supercar, and it was pretty darned super thanks to 300 horsepower from its twin-turbo engine.
Stepping up to the Turbo model brought many upgrades to the drivetrain, suspension and braking systems. Starting under the hood, the Turbo Z featured dual Garrett hybrid turbochargers, each one using a T-25 compressor housing mated to a T-2 turbine. These were both oil- and water-cooled, which was just becoming standard OEM practice in the late 1980s.
Twin intercoolers were mounted low in the front sides of the bumper, necessitating three horizontal vents cut into the bumper cover. Those slots are one of the visual clues that differentiate the Turbo cars from their naturally aspirated brethren.
In order for this VG30DETT powerplant to survive at an elevated breathing rate—maximum boost from the factory was about 8.5 psi—the compression ratio was lowered from 10.5:1 to a more manageable 8.5:1. Other modifications included oil-cooled pistons, stronger rod bearings and higher-grade exhaust valves that could better handle the increased temperatures. All of this added up to an impressive 300 horsepower at 6400 rpm and 283 lb.-ft. of torque at a rather low 3600 rpm. This gave the new Z-car enormous bragging rights, since back in those days 300 horsepower was seen as the magic number.
The seating position in a 300ZX is low and laid-back, just as a sports car should be. Under the hood, the VG30DETT engine in the Twin Turbo models cranks out 300 horsepower in stock trim. Owners love to upgrade these cars; shiny turbo plumbing like this is a sure sign of tinkering. Photography Credits: David S. Wallens
The Turbo’s drivetrain was beefed up to handle the added power with stronger drive shaft U-joints, strengthened gears in the already strong five-speed transmission, and a stronger clutch with 38 percent more clamping force plus a vacuum assist. As final insurance, the rear end was upgraded to a larger unit featuring a 230mm ring gear—a 50mm increase over the standard car. (The Twin Turbo’s ring gear dwarfed even the one found in Ford’s legendary 9-inch unit.)
This car did more than just look good in person and on paper. The 300ZX Turbo rocketed to 60 mph in just 6.0 seconds, and could eclipse the quarter-mile mark in 14.4 seconds at a trap speed of more than 102 mph. (For comparison, the 1990 Toyota Supra Turbo could only muster a 7.1-second zero-to-60 mph time and a 15.6-second quarter-mile run.)
To handle the extra momentum, the Turbo also received upgraded brakes: Where the standard car’s rotors were 28mm thick, the turbo model’s were 30mm. Although the 60-to-zero mph stopping distance decreased by only a scant two feet, braking feel was rated by contemporary testers as “excellent” as opposed to “good” on the naturally aspirated car.
The Turbo’s suspension featured an electronics package that allowed the driver to select between sport and touring settings, although few drivers found this feature to be useful—the touring setting was firm and the sport could be best described as bone-jarring. The final drive ratio was also lengthened to 3.69:1, and the rear wheels were widened an inch (to 16x8.5 inches) and fitted with 245/45R16 rear tires.
The biggest change to the Turbo’s suspension also proved to be the most controversial: Nissan used this car to introduce the American market to their Super HICAS (High Capacity Actively Controlled Steering) four-wheel steering system. Unlike the rear-steer systems that had been used in the past by other manufacturers, Nissan’s did not provide input at lower speeds. It was designed to operate at moderate to higher speeds, starting with a short dose of rear-wheel countersteer against the fronts before transitioning to in-phase steering. At higher speeds, the rear wheels are steered exclusively in-phase with the fronts. While magazine tests initially praised this system as being “nearly invisible,” enthusiasts would eventually decide that it could be unnerving in some instances. As a result, a market grew for HICAS-eliminating kits—which you can still buy today.
While most of the Turbo Z’s upgrades were contained under the skin, one little difference was visible to all bystanders: Nissan added a small decklid spoiler and an even smaller “Twin Turbo” badge to the tail of the car.
Nissan released the 300ZX during some tough times. Economically, the yen’s falling value made Japanese cars not such a hot bargain as the 1990s marched on, and starting in the middle of that decade American consumers began deserting smaller, sportier cars in favor of large SUVs. On top of that, the 300ZX had some serious competition for the sports car buyers who remained. There were definitely faster machines available, like the Camaro, Firebird or Corvette, as well as more responsive machines such as the final iteration of the Mazda RX-7. There were even more comfortable daily cruisers, including the Mitsubishi 3000GT and Dodge Stealth. It all added up to a premature death for the 300ZX in the American marketplace in 1996, although the car was continued in Japan for a few more years.
Although the Z-car lost out to other models, none of those cars offered such a well-rounded package of solid handling, reasonable comfort, fade-resistant brakes and more than enough power to break every major traffic law. Throw in looks that still garner admiration in today’s traffic, and you have a car that remains an excellent choice today.
Photography Credit: David S. Wallens
Even though the 300ZX could hardly be considered inexpensive when it was new, it was viewed as a great value and that trait has only increased with the passage of time. Actual asking prices can vary greatly depending on the condition, options and model year, with low-mileage private party cars selling for significantly more than Blue Book prices.
Photography Credit: Euroimage.us
Engine
Chassis
Drivetrain
Body and Interior
When I started driving way back in the 90's I scrapped together my pennies and bought a clapped out 280zx turbo that was 4 different shades of brown primer and in desperate need of a tune-up but it started a lifetime of happy days spent in the driveway on my back with busted knuckles and stained clothes. Occasional glimpses of a new 300ZX while in a wealthier town would stir a primal feeling inside of me and mutterings of "maybe someday" under my breath...
A few months ago I picked up a '91 Twin Turbo, 2 seater, 5 speed in immaculate condition with about 100k on the clock. Meticulously maintained and only very lightly modified, it is a delightful throwback to the nostalgic days for me when cars still had an analog driving feel while incorporating impressive new technologies. It is a real gem to drive and still turns heads everywhere I go even parked next to todays best offerings.
My personal favorite aspect is the steering feel. It is light and nimble at low speed and easy to maneuver in a east coast city downtown. The Wheel gets progressively heavier at speed and becomes tighter and more precise on the highway making sweepers and switches a surgical action; the 4 wheel steering is almost transparent with smooth inputs. With an electronic limit of 155mph, a relatively wide and low stance, large rubber all around and speed sensitive steering that test one's forearms at the limits is is like a train on rails at triple digit speeds. Confidence abounds as the (underrated?) legendary V6 effortlessly thrusts you forward without a hint of drama.
I plan to keep it very original, or at least easily returned to near original with minimal effort. Not a time capsule, but there is not much that really needs to be fixed to be enjoyed as a fun second car for me. It is the type of car that I can take to the nicest restaurant in the city and just leave it parked out front, then do a track day the next day for fun without changing a thing, and still run errands around town with just enough space for packages in the back even with the t tops secured in their bags and straps.
It isn't perfect: Sport mode is punishingly stiff, there are no cup holders and I dare not calculate my gas mileage... but I really like it overall.
I love these cars so much, they stink to work on (especially the TTs) but other than that they are really phenomenal.
I'm still hunting for the right '93-94 NA to keep as a forever car. I loved the one I had 10 years ago, but it was the wrong car for me at the time.
Definitely noteworthy points:
There is ZERO free space under the hood. Without paper thin arms and seven fingers per hand count on disassembling things to perform any work anything. After spirited driving heat pours off of the drive train in a very noticeable manner.
I feel like I got a very good deal on mine after talking to lots of people about valuations and the market, even though I paid more than I had originally hoped to. It is insured for more than I paid and several industry experts have advised me that it's value will increase quite a bit. Another reason to not modify or abuse it unreasonably.
At cars and coffee type events is really draws a hugely positive response even if it does need a solid week in the detail shop to be in car show condition. A couple weeks ago I was parked between a new BMW and a new Lamborghini and the guys only had eyes for my old Nissan...
In reply to tb :
Even my NA seemed to bake the crap out of everything under the hood, I can only imagine what the TTs are like in that fashion. Seemed like every connector I touched would just turn to dust!
I am not at all ashamed to admit that if something complicated breaks I may very well just drop it off a a trusted local shop and let it be their problem. I am way to old and crippled for that kind of headache!
Until then I'll just do like the rest of my cars... crank up the boost and convince myself it will all be just fine
As you can tell by my name, I love these things. I had a new 1990 NA slicktop (which very few people even knew about), kept for over 12 years before selling to get practical for a while. Fast forward to 2016, after a succession of other "fun" cars, I found a '90 TT with only 35,000 on the clock, looked and smelled like a new car, didn't take long for the wife and I take it home with us. Now after some upgrades to brakes, clutch, trans, wheels and tires, I have a back road beast that really puts the grin on my face. And what's really cool is when some younger gen folks give me the thumbs-up while I drive.
Good practice for all of you Z guys out there, every time I pull back into the garage, I put the hood up and let all that heat dissipate, and I've done a lot to reduce under-hood heat generation, I'm running water wetter in the coolant, upgraded the thermostat and radiator, all of which have helped reduce normal running temp by 10-20 degrees......next step is to try Evans waterless coolant, which is supposed to help even more.
Displaying 1-8 of 8 commentsView all comments on the GRM forums
