Skyline Style: The B15 Sentra SE-R
Robert
By Robert Bowen
Sep 16, 2021 | Nissan, Sentra, SE-R, Spec-V, B15 | Posted in Buyer's Guides | From the May 2012 issue | Never miss an article
Photography Courtesy Nissan
[Editor's Note: This article originally rain in the May 2012 issue of Grassroots Motorsports]
Small, sporty sleepers have been enthusiast favorites for decades, and for years Nissan’s entry into this category has been the Sentra SE-R. That original 1991 Sentra SE-R added plenty of punch to Nissan’s economy car platform, including more power, stiffer suspension and even a factory limited-slip differential. The result was simply amazing performance for a base price south of $11,000. Unfortunately, the follow-up SE-Rs lost much of that first car’s panache.
Weight went up, redlines went down, and enthusiasts were no longer enamored with the twist-beam rear suspension used in the late ’90s. The SE-R badge wasn’t one to be confined to the ages, however. Nissan released their all-new, B15-chassis Sentra for 2000. Reviewers liked the new car’s increased interior room and solid construction. In response to the tuner market, Nissan PR teased us with another hotrod Sentra. Dubbed the Disco Potato thanks to its wild, iridescent brown paint job, this one-off machine featured a turbo engine, stiffer suspension and giant wheels and tires.
The Disco Potato showed that there was still a place on the market for a performance-tuned Sentra. In 2002, Nissan responded to consumer demand with the Sentra SE-R and its edgier brother, the SE-R Spec V. These cars occupy a sweet price point today. Values are depreciated, performance is still strong by today’s standards, and good cars abound on the secondhand market.
Monster Meats and Torque
That 2002 Sentra SE-R followed a path blazed a decade earlier: more power and more stick. The Disco Potato’s turbocharged engine didn’t make it into production, but the car did get more grunt. Thanks to similarities with the maker’s larger cars, the SE-R received a 2.5-liter four-cylinder from the Altima.
This new QR25DE engine made plenty of power, even if it didn’t like to rev to the stratosphere. In SE-R tune, it was rated at 165 horsepower. The 180 lb.-ft. of torque made up for some of the loss of revvability and helped make the heavy cars feel faster than they were.
The real star of the show was the SE-R Spec V. In place of the SE-R’s five-speed manual or four-speed automatic transmission was a six-speed transaxle fitted with a helical limited-slip differential. Performance rubber on 17-inch alloys replaced 16-inch wheels. Horsepower went up to 175.
Suspension tuning was firmer than on the SE-R, too, with more aggressive rear roll stiffness. Larger front brakes round out the major mechanical differences. As before, Nissan offered a lot of performance for the price. For around $17,000, buyers could drive off the lot with a new Spec V.
Inside, the Spec V had unique red and black upholstery on a more aggressive seat design. Both versions received the same distinctive exterior bits: blacked-out headlight trim, a rear spoiler and an aggressive front bumper.
Half-Baked Potatoes
Reviews of the new SE-R and Spec V were mixed. Most testers loved its engine’s torque and the grip offered by the helical limited-slip differential. Big tires and stiffer suspension gave the car impressive road holding: A few testers measured peak lateral acceleration around the .85g mark.
Its seats were noted as comfortable and supportive, but that’s about where the praise stopped. The Spec V was given very short gearing to make the most of the QR engine’s torque, and the buff books frequently faulted this since the car required third gear to reach 60 mph.
The second issue was the car’s inconsistent real-world performance. While it felt fast, timed data revealed an engine that didn’t always deliver the same performance run after run.
Other nitpicking revolved around the overall fit and finish of the interior. It didn’t seem as nice as the rest of the field, but remember: The SE-R was priced below its competition.
Unfortunately, after the launch a few more issues started to surface. One was a tendency for the engine to consume excessive oil. A few engines even failed catastrophically. Numerous TSBs tried to head off the problem; Nissan developed several software updates for the ECU in an attempt to address the root issue. Many early QR25 engines were replaced under warranty.
The cause? Bits of catalyst got sucked into the engine during overlap.
Another issue took a few more engines out of service: The tiny screws that secured the secondary throttle valves would occasionally vibrate loose and go into the combustion chamber.
These problems are less common today. Upgrades eliminated those issues for 2003, and many 2002 engines were replaced under warranty long ago. Transmission gearing was revised for 2003 so the Spec V could reach 60 mph in second gear.
The B15-chassis SE-R continued through the 2006 model year, and while they may not enjoy the cult status of the original, these cars now make comfortable, practical daily drivers and track toys.
Things to Know
The B15-chassis Nissan Sentra SE-R and Spec V make fun, inexpensive daily drivers. Since we like to row our own gears, we’d have to go with a Spec V model or an early SE-R.
Engine and Drivetrain
“We’ve found that the stock motors, even from 2002 to 2003, last for a long time if you change the oil often,” says Joe Ippolito of B15 Sentra specialists 2J Racing.
“For a street car, the catalytic converter is the one weak point because it’s known to break up and destroy the engine,” says Kyle Millen of longtime Nissan tuning house Stillen Motorsports. “Other than that, some heads have trouble since the combustion chamber has a thin wall and tends to crack around the top.”
Removing the upper plenum and adding a drop of threadlocker to all of the secondary runner butterfly screws is a prudent, 30-minute project, says Ippolito.
“The 2004-and-up ECU runs on a CAN bus system and can be tuned via Uprev tuning software,” Ippolito explains. “The 2006 is the best because it has a factory wideband O2 sensor and can make air/fuel ratios almost perfect, even with a turbocharger.” The 2004-and-up cars also use a much more reliable MAF sensor, he adds.
The 2004 gear ratios are the best of the three variants for performance, Ippolito says.
Both Millen and Ippolito recommend an exhaust header. Figure it’s worth 7 to 12 horsepower, but Ippolito warns that not all are created equal.
Enthusiasts often remove the balance shafts with a Jim Wolf Technology kit. This move adds a quart of oil capacity and, according to Ippolito, frees up some horsepower. Removing the shafts does introduce some annoying harmonic resonances, however.
Kyle Millen recommends the JWT cam set: “We were very surprised when we saw 200 horsepower at the wheels with the cam set, new valve springs and a 7700 rpm redline thanks to the QR-Pro.”
The QR25 engine does take to turbocharging, but consider stronger aftermarket pistons and rods. “Anything over 350 horsepower breaks [the stock] rods,” Ippolito adds.
A V6-powered SE-R? Yes, it’s possible, and 2J Racing can make that swap a reality. The 2002-’06 Nissan Maxima VQ35 is almost a direct bolt-in. The weight gain is about 37 pounds.
Body and Interior
The B15 holds up well to abuse, but don’t be surprised by worn leather on the steering wheel, scratched dash plastic, and snagged seat upholstery.
The Lava interior looks cool—well, to us, anyway—but the fabric stains easily.
Suspension and Brakes
Kyle Millen recommends combining Eibach springs with Koni shocks. It’s what he runs on his street car.
The rear twist beam has a very high roll center, and 2J has found that replacing the Scott Russell link with their Panhard rod can make the front and rear roll centers work better together.
The factory rear alignment often has a ridiculous amount of toe-in—some cars have as much as 1/4 inch built into the beam. A good alignment shop can tweak the beam to give neutral toe, which makes for a more predictable transition to oversteer.
Join Free Join our community to easily find more Nissan, Sentra, SE-R, Spec-V and B15 articles.
Comments
Jordan Rimpela
Jordan Rimpela Digital Editor
6/21/19 1:38 p.m.
When was the last time you saw one of these on the road?
Professor_Brap
Professor_Brap Dork
6/21/19 1:40 p.m.
In reply to Jordan Rimpela :
Every day. there is a local guy who loves these.
spacecadet
spacecadet GRM+ Memberand HalfDork
6/21/19 1:42 p.m.
I have a friend who bought one last fall. They love to destroy cats and cause the motors to fail catastrophicly apparently and that's why my friends are getting rid of their already after 6 months of ownership.
I imagine this is a large part of why you even have to ask this question and they're not all running around with buzzy exhausts and teenagers at the wheel..
Run_Away
Run_Away GRM+ Memberand Dork
6/21/19 1:49 p.m.
Nissan should have put the VQ35 V6 in it factory and created an SRT-4 killer. It would have been very easy.
Streetwiseguy MegaDork
6/21/19 2:06 p.m.
I owned two that I had bought from salvage.  I really enjoyed driving them, especially the one with the Brembo brake package.  Shame about the engine killing cats.  I'd imagine that sent more of them to the wrecking yard than anything else.
Tyler H
Tyler H GRM+ Memberand UberDork
6/21/19 2:18 p.m.
Drove one long ago when they were nearly new.  The Spec V had some mighty torque steer as I recall.
These seem like they would make great LeMons candidates, but I can't recall seeing one.
nutherjrfan
nutherjrfan UltraDork
6/21/19 2:19 p.m.
anyone who didn't know about the cat issue either doesn't have internet or spent all their time watching dumb yt/ig vids.  Heck even being on faceballs you couldn't miss stories about that problem.  But it does make our hobby much cheaper.
Now I'd like to state these kinds of articles impact my ability to get one of these for a song in the next year or so.
There are consistently 2 - 3 different ones popping up on the DC CL every week and for under $3k.
I'll have to read the article to remind myself of the 'Skyline' front bumper cover years. smiley
TurnerX19
TurnerX19 HalfDork
6/21/19 3:42 p.m.
One of the pizza delivery guys in my neighborhood runs one of thesesurprise Also seems to be the only one around too.
6/21/19 3:55 p.m.
If you find one, I went two ways.  First one got rings, second one got an engine from a highway driven automatic transmission Altima.  Both were successful, but I made more money parting out the rest of the Altima.
Both got Chinese headers, too.
irish44j
irish44j MegaDork
6/21/19 4:22 p.m.
I came here to say this. Or at least a VQ30DE-K.
Though I do know a guy who put the VQ35 in, and it was an extremely tight fit and required some customization. Not a drop-in ....
JgQ4aKlEd1mvfvTdcZQlO3pkdxyLixgNhLFZPpfcBnc0vFvS8Ln4MiGXH5XbukK1
