xci_ed6
xci_ed6 New Reader
3/11/09 12:27 p.m.
Not for sure if I want to sell it just yet, so consider the price firm.
15xK miles, runs & drives well. Currently an automatic, but I swapped in the 5spd pedal set. Interior is mostly clean, has a couple stains in the back that won't come out, and a tear in the d/s carpet. Sony CD, no-name speakers, 8" Bazooka tube. Also swapped in manual steering. Drain plug drips.
Installed
K-sport pro-control coilovers-- full energy suspension bushings-- Si-R/Ex front spindles and brakes-- new ball joints and outer tie rods-- 14in steel wheels w/ newer (80%+) Fusion HRi tires-- new rear brake shoes, hardware, cylinders, oem hardlines
Included, not installed
NEW oem clutch cable-- Si trans w/ Dx final drive & OBX LSD-- Si final drive set-- clutch specialties 6-puk unsprung, slightly used-- fidanza 7.5lb flywheel, slightly used-- Geo Storm GSi alloy wheels (15x6?)-- power lock actuator set (all 4, used, OEM)-- power window regulator set (front, used, oem)-- spare d15B2-- header-- d16y8 intake manifold-- full SS exhaust w/ 'race cat'-- MPFI distributor-- Avid Racing traction bars-- strut bar sets-- Si rear sway bar
$2009 319-329-4680
93celicaGT2
93celicaGT2 HalfDork
3/11/09 12:46 p.m.
Location?
xci_ed6
xci_ed6 New Reader
3/11/09 1:45 p.m.
Cedar Rapids, IA
There are a lot of other spares, from bumper lights to mudflaps, OEM gaskets, rod and main bearings. All included. The current exhaust is newer, OEM style ~1-5/8in.
Photobucket
Photobucket
Photobucket
Photobucket
Photobucket
93celicaGT2
3/11/09 1:57 p.m.
What were your plans with it?
xci_ed6
xci_ed6 New Reader
3/11/09 2:13 p.m.
small turbo, SCCA autocross.
Most of the parts I had from previous cars. I even have a 3/8in mild steel head flange and T3 turbo inlet flange that will be included. Might be getting laid off and want to pay off as much of my student loans as possible now, though.
I just noticed it has the Si gauge cluster installed in that pic, it needs work, so I swapped the stock cluster back in. The Si cluster is included, but the tach is not working. I think I have a 6th gen civic cluster around that I was going to try to salvage the tach servo from.
93celicaGT2
3/11/09 2:16 p.m.
Gotcha.... neat project.
I doubt you'll have any real problem moving it at that price, especially with the spares and suspension..... But just in case, i'll keep an eye on this thread. It's worth the money, i just can't justify the money right now, partially for the same reason you're looking to sell.
ZAnkKKEa2KAnpMWrFgUwC8oViVOKjrNICspB6E7VHqA7v3dh1bWPGnUPEg594zrB
