I need to know the side to side distance between the rear subframe mounting bolts on a C5. I know the front pair is not the same as the rear pair. Should have measured that before chopping it in half. :-(
Does this show what you need?
https://www.clevelandpap.com/corvette-rolling-chassis-measurements/
DeadSkunk (Warren) said:http://www.supermotors.net/getfile/1015374/original/c5-framedimstitched1.jpg
Perfect!!! That drawing shows exactly what I needed!!! Thank you!!!
Looking at the side view....it appears that the mount points aren't the same distance above the road. The sub-frame tips forward.
