I have a pair of adjustable rear sway bars that were on the rear of an E-prepared class Ford Focus ZX3. $75 each?
The first one is an adjustable19mm, hollow, no markings. Take a look at the pictures. A little less than 28" wide.
Second bar is an adjustable rear bar 26mm, solid. Measures about 29" wide. Eibach numbers on it: O/P 41 35 001 01 HA
Last thing:
Crazy rear trailing arm setup. The rear blade trailing arm on the Focus was cut and replaced with this heim jointed thing (then radiator was moved to the rear, making a change to the rear sway bar setup needed. Bolt diameter on big heim joints is 19mm.
All prices plus shipping.
Contact me: andrewsteere aaaatttt tds dooooottttt net
