Joe Gearin
6/2/15 11:53 a.m.
Need to change brake fluid, but you are a one-man operation? Here's an easy solution from Motive Products--- as described by the nice folks at Mueller Motorwerks.
0-60 Review Motive Power Bleeder System: https://youtu.be/ix2Vundb888
oldeskewltoy
oldeskewltoy SuperDork
6/2/15 6:33 p.m.
Good product! I've owned one for about 7 years now... lent it out a 1/2 dozen times too. Works well, but some tricks must be observed to keep the operation clean (vent pressure from bleeder before releasing pressure at M/C topper) Also the M/C toppers(caps) are domestic sized... fitting the round topper on a Toyota M/C is a bit tricky..
edit - The chain they supply to secure the caps are a bit bulky so care must be used setting it up on the much smaller M/C on the import cars.
wbjones
wbjones MegaDork
6/2/15 6:37 p.m.
it's probably a great product … at least for those vehicles that it fits … I know for Honda's it's a PITA to get it to work …
problem ? no "easy" way to airtight seal the thing to the MC … mine is in a box somewhere gathering dust and spiders, somewhere in the back corner of the storage building
Joe Gearin
6/3/15 9:52 a.m.
I'd bet that a few sections of this self-binding tape would create an air-tight seal for your MC. This may work until Motive comes out with new MC caps.
This tape really is magic. Everyone should have a roll in their glovebox. It's not just marketed by DEI--it's available from other vendors as well.
https://www.designengineering.com//category/catalog/design-engineering-inc/heat-sound-barrier/quick-fix-tape
bravenrace
bravenrace MegaDork
6/3/15 10:31 a.m.
In reply to wbjones:
Same here. In fact I couldn't get it to work decently on any of my cars, so I sold it.
Woody
Woody GRM+ Memberand MegaDork
6/3/15 10:35 a.m.
It worked great on my Mustang and Porsches. I've used on three Miatas and even at 5 psi, it blows brake fluid out everywhere and makes a huge mess.
wbjones
wbjones MegaDork
6/3/15 1:56 p.m.
if I worked hard enough at it I could get the chain to tighten enough to make it work … but I found that I wasted way too much fluid, and that gravity bleed worked just as well, and in the long run did the job quicker and/or with less aggravation
they told me that there weren't any plans to try to make a cap that would work on the Honda MC
when I talked with them, they did (begrudgingly) offer me my money back … attitude problem … I said it wasn't worth the effort to box it up and send it to them
ProDarwin
ProDarwin UberDork
6/3/15 2:04 p.m.
Can't you get a spare MC cap and install a hose fitting on it? I haven't done this yet, but it has been my plan for a while.
I tried using the chain thing before on the Miata and had the same experience Woody did.
xEZmQdMGc5izDQxjtdie2lr3M1p6aa9UzhRA3dZisjgwcF5GsVE60DEEm3ZVr2DK
