Presented by Nine Lives Racing
1 2 3 4
nocones
7/12/22 12:57 p.m.
So the rear wing is much simpler design.   To make it I took 1" conduit at the leading edge and a piece of 1*1 about 9" behind it.  I welded a center piece in and then welded some end pieces on.   Over this I bent a piece of .040 aluminum.   I riveted the aluminum down to the 1" tube on top and on bottom.  I then deflected the aluminum up to make a banana shape and clamped and riveted the trailing edge.
 This was surprisingly effective.  It creates and airfoil shape, and was strong enough to get towed backwards at 75 MPH with no apparent vibrations.
The wing is 69.5" wide with a 1.5" thickness and a 16" depth (8 sq-ft EMod/BMod limit).
I'm somewhat concerned with the unattached nature of the surface sheets that there may be vibration induced boundary layer separation.
The height above the car is way to high.  I was in a hurry and the center stantion started at the height of the roll bar (for the eventual shark fin).  I then didn't lower it enough so if needs to be lower.
The angle of attack similarly was guestimated and it is to steep.  I plan to make adjustable mounts.
The stanchion is a 3/4" tube with triangulation by 1/2" tubes.  I can hang on it, push the car around with it etc.  The end supports are 1/2 tube and the endplates are just 1/4" plywood.  Again they survived driving backwards at 70 so I know they will be good for the challenge and the design will be kept they will just lower with the wing when it adjusts.
I am somewhat concerned about torsional stiffness relative to the car as well as lateral.  I'm worried it will rotate relative to the car.  Before I go crazy with more mounts I'm going to try adding triangular wires.   I have a old bontrager bike wheel with Aero spokes that is radially cracked and can't be used.  I will asign an FMV to it and use the spokes to make some bracing wires to see if that stiffens it.  It's not bad now but I think it could be improved.
I will get some more pictures of the mounts Tonight as I don't have them.  I can hang from the wing so it at least can handle 240 lbs of Downforce.   It's not to heavy either at ~10lbs.   This one likely will stay.
sleepyhead the buffalo
sleepyhead the buffalo GRM+ Memberand PowerDork
7/12/22 1:53 p.m.
So, one initial clarification is: are the "spars" for the front main element biased "up" or "down", to share a plane?
also, I suspect you're 15"  chord estimate might be off.
*drawing only to scale-ish (and scaled wrong... hang on)
nocones
7/12/22 2:00 p.m.
In reply to sleepyhead the buffalo :
B is almost exactly right.   It is 15" from the leading edge to the trailing edge
7/12/22 2:03 p.m.
I'd think, though, that the front 24guage that was bent around 1" conduit would project forward from the spar.. ~0.6" ?
nocones
7/12/22 2:10 p.m.
I'll measure the exact dimensions of the rear and angle that will answer the locations of the spars for an accurate representation of the current part.   I think the rough design works and If there is some slightly better geometry I could adjust it when I replace the bottom surface with another sheet of 24gauge that could remove the flat 9" part and result in a curvature.  It would also drop a hilarious amoubt of weight as the ~15"*54" 1/2" ply isn't light.
7/12/22 2:21 p.m.
nocones said:
Outside of the main wing is a bit of a throwaway.  I really wanted to get the fog lights on so I made some flat splinter pieces then put endplates and a set of diveplains on.   I'm not sure if it would be better to let the air go around the flight under the diveplains or block it off.
honestly... for the upcoming AutoX test, I'd just leave the fog lights there and not worry about fairing them in.  Yes, leave it open to allow flow to attach to the underside of the upper diveplane.  Eventually you'll want to add a smoothening panel there, which will take lots of high pressure air from the front outside of the car and compress it into a sheet that will help block the wheels from drag producing interaction with the 'normal' flow.  Go around the parking lot, looking forward through the front wheel well of many cars made after ~2018 and you'll see a similar element in the bumper.
one benefit will be that the compression here will mean that you can potentially really crank up the aft-end of the diveplane (and corresponding outer-splitter) and keep the flow attached.  Although, that will also lead to a trade-off between rear downforce balance and drag creation.
7/12/22 2:34 p.m.
the parallax isn't doing us any favors... but this, after all, is less about 100% accuracy.  Instead, being more about "getting inside the ballpark":
7/12/22 2:37 p.m.
aside...
I don't know if I'll be able to do it (my being out there is still tentative), but I should probably figure out a way to "meet up" with this thing around the GridLife Mid-Ohio event.
7/12/22 8:04 p.m.
I'm going to start with some analysis of the rear foil first.  I used the above outline, and a version where the outline was 'filled in' and sucked them into JavaFoil to generate two sets of coordinates.  I brought those both into XFoil and used the "interpolate" command to 'average' the data between them, to try and smooth out some of the 'roughness' that tends to creep in from tracing the outline with three-segment, four-node curved line segments in paint.net.  This 'combined' foil was then expanded to 200 points via XFoil's PANE command.
I ran a viscous polar on it at Reynolds Number {RE} 7e5 (700,000) from AoA -5 to 20, in 0.1deg steps.  Then I took the foil into the 'MDES' design menu and used its FILT command to try and smooth out some of the roughness... with limited success.  Then I ran a second polar, which showed minimal (mostly in the drag curve) changes.  Please keep in mind, these results are 2D, only... and don't account for GroundEffect, or 3D Wing-Plan Effect:
I used the same 'filtered' 200 point file to pull into JavaFoil, and then went through setting up the coordinates in the 'format' that JavaFoil prefers.  With these JavaFoil-specific coordinates, I performed 3 Polars sweeps with JavaFoil from RE 600,000 to 1,000,000 and "-7" to "20" deg AoA.  The three setups were: 2D (infinite AspectRatio, AR), AR = 5*, and AR=5 and 250%chord above the ground:
*a word on AspectRatio = (b^2) / S  = ( wing span squared ) / ( wing planform area ) = ( 69.5^2 ) / ( 69.5 * 16 ) = 4.34
   but, there's EndPlates... so using the linked endplate effect estimate, and guess that the endplates are 6" tall/deep:  4.34*(1+1.9(6/69.5)) = 5
**a word on Reynold's Number (RE)
    this helps 'us' account for the nature of the flow (laminar regime vs. turbulent regime; or 'Low Reynolds Number' {e.g. less than ~500,000} vs. 'High Reynolds Number' {e.g. 1,000,000 and above}).  Calculated by:  RE = rho * V * L / mu   (where I'll be using 1976 NASA standard atmosphere values for Sea Level for rho (air density) and mu (air viscosity))
RE = 0.002377 * (88) * (16/12) / (3.737e-7) = 746,000
which is reasonable to round down to 700,000 for now.
I'm not real sure what the effect of the 'unsupported' low-pressure side of the skin will have on things.  The foil clearly has a pretty sizeable nose-radius... which in this case is good.  Plus, the conduit isn't too far off the skin, if drag at the stagnation point 'pushes' the skin back, and the low pressure suction trying to pull the skin "down".  For challenge... I'd guess it's not a big deal... especially if you shallow out the rear foil for the drag passes.
I think Cl.max of 1.75 is a reasonable estimate of this foil's capability, including 3D/Ground/Endplate Effects.
Rear Downforce, 60mph {88fps}, 1,112sqin = 0.5*0.002377*(88^2)*(7.72)*(1.75) = 124#s
Rear Drag,            60mph                               = 0.5*0.002377*(88^2)*(7.72)*(0.06+(0.0637*(1.75^2)) = 18#s
for ballpark sake... there's some public data for a cat-ish foil that's 70" long (9.25" chord) with 8" endplates.  At 60mph and 10deg AoA it pumps out a Cl ~1.76 for 76#s of downforce, with 7#s of drag.  So, you've got 2.5x the drag for 60% more downforce... mainly due to the longer chord and 'get it done' foil shape.  On the other hand, it's what... $5 out of pocket?
I've been thinking about the C.G. / Aero-Balance thing I brought up back a page.  I think it'll be better/easier to reference these to the 'engine side' of the firewall.  So, when you get a chance: can I get a distance from the nose of the foil to the backside of the firewall.  And, similar distance to the 3/4" square tube on the front main element?
edit:
I should note, when I pulled the sections and popped it into XFoil, it was estimating a maximum thickness that was 12% of the chord, at a point 20% back from the nose... or a 2" maximum thickness 3.25" back from the nose.  Looking at that a bit more, with squares scaled off the front conduit...
I think I might slim this down to 11% (i.e. 1.75" thick) and give it another go.  I don't think 1.5" thickness is right, though?
as for camber... the codes were evaluating it around 6%... which, eh.  I'll have to dig around a bit, and see if I can get you a 'height' above the 'flat-ish' "top" skin back at the 1" square tube 'rear spar', to check against.
7/13/22 12:39 p.m.
Alright, lets get the Front Aero estimate out of the way...
I took the information gleaned from the last couple of days and made some modifications to the "flat board foil development" algorithms(?)... spreadsheet wonkery?  Anyways, I took what I'd built for stuff on the last page and used it to generate relatively reasonable approximations for the front foils nocones had built:
You'll notice that these foils are open at the TrailingEdge... which I found that JavaFoil really didn't like... especially at these TE thicknesses (it was giving me Cl  estimates of 0.14).  After adjusting the coordinate spacing to JavaFoil's preferred spread, I then added in two points to close up these foils with a 90deg corner, and then spaced the main foil up to GroundEffect for a 4in minimum spacing (iirc, that's the current working height between the front plywood fences?).  It's a ~15" chord, so again RE = 700,000:
Let's remember our 60% rule... 1.479*0.6 ~= 0.887
which, I think is pretty reasonable.
I then went through and added the second foil, spaced it's coordinates, resized it to 33% of the main chord (5" element compared to 15" main element), closed it's trailing edge and then moved it to a 0.5" overlap (i.e. 96.7%c) and 1" gap (which I took to mean from the top of the main element and bottom of the 2nd element, or 48.4%c from the ground... or aka 7.26inches.  I might have to go back and recheck that value).  Then I did FlowField analysis for the 2nd element deflected at 10deg, 20deg, 30deg, and 45deg.  I applied the 60% lift reduction, and summarized the results in this table:
There's two pretty important assumptions to this data, which go in-hand with nocones request for "simple things to do" for the current build.  The following two things I think are fairly important for making this data reasonable.  The first is to round over the front edge of the 2nd element with a 1/4" round-over bit, top and bottom.  This will help the flow over the top of the main foil follow the 2nd element (important)... and mean the real-world results more closely match these results (less important).
Second, I strongly suggest that before the autocross you tape the open joint between the two pieces of plywood, as well as the trailing edge of the 24guage "Leading Edge":
7/13/22 12:58 p.m.
That's cool and all, Sleepyhead... but, what's it all mean!?
So, why don't we drop things from these analysis into another worksheet that sums it all up, along with a couple of working guesses / assumptions about the LMP360:
Ax = 15sqft (cross-sectional area, which isn't the same as "frontal area"... although either could be {and often are} used)
Weight = 1800#s + 200# driver
Arm Length from the front element to the back of the firewall:  66inches
Arm Length from the back of the firewall to the quarter-chord of the rear wing:  54inches
Pre-existing span dimensions from the last page
20% across-the-board endplate adjustment to AspectRatios (although, I suspect I need to tweak the front element 'lift-induced drag' valuation on AR up a bit more, maybe?)
I ended up using the 10deg deflection on the 2nd element, based on the moment guesses for front and rear from the 66inch fron arm and 54inch rear arm.
This doesn't include the contribution of the diveplanes, nor the diffuser.
Personally, I think there's a lot of value in "running it as it is" coming up in 2weeks.  Although, I'd suggest that you add a couple of pre-built tension wires (and attachment hardware)... so that you can potentially tweak the rear wing foil trailing edge... "up"?  I.e. bend in more curvature/tension in the aft part of the rear foil section so it has more camber.
Alternatively (or, better yet additionally ), I'd suggest working up building a 4 or 5" chord 2nd element to the rear wing out of 1/2" ply that's supported at the ends and the middle (so the gap stays consistent).  It seems pretty clear to me that the front elements you've built so far can generate quite a bit more downfroce than the rear can (moment arms, depending).
Note:  when/if you add a diffuser, that won't impact this front-rear balance quite as much, because the force of the diffuser will impart its effect very close to the CG; so it's effect will primarily be 'overall downforce' increase; and drag decrease {iirc}.
edit:
That's about all the analysis I can due for the time being with the available information.  If you've got any questions, or you've got a scenario you'd like me to look into, chime in... and I'll see if I can analyze and/or answer them.
nocones
7/13/22 1:10 p.m.
Oh man.  This is so much great information.  I have the background to understand it but don't immediately have the time.   But I will put in the time.
My initial reaction after reading is run what I've got, report back with some dimensions and then I can ask better questions when I get some time to digest the immense effort you've graciously put into this.
I will do some reinforcement of the trailing edge of the rear and tape the bottom of the front for sure before next weekend.  I'm hopeful to add the 2nd element as well Is the current angle of the rear estimated as "good" or should Iower the angle when adding the 2nd element?
Just to repeat and be perfectly clear thank you so much for the time/effort you've put in.
nocones
7/13/22 1:18 p.m.
Oh and a question to plant a seed.
I've built the sides of the car to be able to accomodate a 4" deep x up to 8" wide tunnel down each side.  It will be a bit before I get to it but it's probably worth discussing what If any benefit there would be to running tunnels into a diffuser vs a flat floor with a diffuser
7/13/22 2:45 p.m.
Is the current angle of the rear estimated as "good" or should [lower] the angle when adding the 2nd element?
Spaghetti, it's what's for lunch!
so, if the green lines are close to 'flat horizontal in the real world'... then I think that wing is set to 21deg?  And, if you put a digital inclinometer on the flat-ish bit between the mounts, I think it'd read 20deg?
if so, then you're 5deg high from the 'optimum' of 15deg.
of course, we also don't know how much "downwash" the cab/rear body work is going to influence the AoA into the rear element.  So, there's an argument to be made for 10 or 12 deg setting.
Although, if you go back up to the Cl-alpha and Cl-Cd curves from XFoil, you'll see that the big round nose, relatively low camber (i.e. average foil curvature) on your rear foil means that it's holding on producing lift (just at the cost of drag) even at 20deg.
so, if you can, back it off to 15deg... tuft the bottom of the wing, and point a GoPro at it when you're doing 60mph to give us an idea if/how-much separation is going on and where.
The reason to have the wires is partially to aid the rear of the rear foil from 'flattening out' at speed.  But, also, we could crank on it and raise the curvature and try and get more lift out of the existing rear structure.
Final thought for next weekend:
I know you're on 200tw vs Hoosiers, and I think there's been some other minor suspension tweaks 'over the break'.  So, I'd advise you to try and get some runs (whenever possible/practicable) without the Aero installed, just to make sure you're not chasing a mechanical grip imbalance while fidgeting with the aero.
7/17/22 6:33 p.m.
Underbody design is definitely an area that I'm a little less familiar with.  I appreciate a clue about it that Steve gave me a couple years ago.  Additional, since this comment, I've gone back and read the section on rear underbody shapes in Katz.  I've also read Toet's article on his (?) site / RaceTechMag.  I've also combed through a couple of technical papers, and found one by Kevin Peddie & Luis Gonzalez "CFD Study on the Diffuser of a Formula 3 Racecar"... which was helpful for me (search around, there's a couple different links to download the pdf of it).
This big takeaway for me, which is similar to what Steve Stafford has stressed on the pages of GRM:
https://grassrootsmotorsports.com/articles/downforce-sorcery-diffusers-explained/
or, another way to talk about underbody aerodynamics, and rear exits of said underbody flow... is to think of these similar to one thinks about radiator ducts.  They end up being very similar, and heavily influenced by the relationships identified in Bernouli's principle:  That for a particular set of intial flow conditions, changes in area will have deterministic and correlated impacts on flow speed and pressure.  And, similar to radiator flows, putting the exit of the underbody flow in the presence of a low pressure zone, will advantageously improve the flow through the entire underbody.
There's some other details with respect to vortical flows and their ability to keep the underbody flow attached at "higher than normal" exit surface angles/areas.
This is a really long and convoluted approach to answer any aerodynamic engineering question with the classic engineering:
It Depends
Reading through, there's quite a bit of evidence that having a minimum clearance height at the "choke" point of the underbody being around 1" is beneficial (assuming you can keep it relatively consistent {see, Formula1 2022}).  It also looks like having some form of flow acceleration 'forebody' could be helpful in aligning the flow into the choke point.
Eventually, though, the question becomes: "how big can the exit area be?"
Which leads to two further items to consider:  a)  "do you want the underbody flow to intersect the lower a-arm {a flow disruption}?  b) based on the size of the exit area, was is the minimum choke area?   (i.e., you/I/one would probably end up nominally working backwards from the rear of the car to answer your question).
I suspect that the exit area available, and the angles involved might mean that you can't use the entire volume to feed the tunnels, similar to what's found on a Porsche 962.  But, we should probably start with exit area... and some thinking about how the tunnel 'wants' to interact with the rear suspension (I suspect for challenge, keeping the tunnel out of the suspension has lots of benefits).  Then we can think about ways to use the extra volume, if there is any, beneficially.
8/2/22 11:07 p.m.
so, underbody is in the process and  nocones posted up a couple images in the build thread...
off hand the broad strokes of it look good.  and I agree with the idea of a simplified floor shape that can be built quickly.  The exit looks pretty good, i like that it's expanding vertically and horizontally behind the tires.
I wonder about the ability to poke the exhaust cans exit out through the top of the "engine cover"...
I think this Peugoet picture from Mulsannes Corner 2011 news page explains what I'm suggesting... ish:
as for the planning drawing...
the main thing I'd like you to consider addressing is in "green", and that's to try and change the as drawn shape head of the main frame from a "concave" profile to more of an 's-bend', so the shape more closely follows the expected flow line you've drawn... without detaching from one section of the body to the the next.
The pink question mark, I wonder a little about what's drawn?  Although maybe that's because you're drawing a section that's 'flat' at the ~height of the underbody... and you're just going to have a flat plate that connects from the outboard aft portion of the front tire 'barge board' to the underbody section?  otherwise I'm a little concerned that you're putting an obstruction in there with the green triangle thing there?
so, the next part, I'm having trouble think about how to talk about.  The light blue line, I'll call: 'the inboard fence' for the side-exit flow... probably doesn't need to be a complicated curving shape.  Although, you might build in some ability to move it in/out side to side but holding the "as drawn" angle.
Here's where things get... harder... and I've made two attempts to try and highlight... neither of which I'm happy with:  being the "cross-section" from the yellow arrow.  The point is to encourage you to keep in mind the angle of the 'inboard fence' and the idea that some of the air going through the underbody is inherently not going to follow that fence.  But: that's ok!  In fact, I suspect it's actually really good.  Because, some of the highspeed flow coming into the underbody from between the wheel and the body is going to want to curl up into the main underbody that's going to head back to the diffuser... and in doing so while hopefully roll up into advantageous vortices.  The presences of these vortex-fences are pretty common on the current F1 cars.... and some of the reading I've done indicates that a lot of effort is going into make vortexes in the underbody, because they keep the flow attached and allow steeper than 'rule of thumb' exit area geometries.  So, you might want to build in some ability to angle up the last ~9inches of the diffuser ceiling in case "we"/"you"/"it" manages to roll up some vortex from that fence (or we go crude and fashion some simple bent aluminum vg's?) and use some tufts to figure out that more angle can be pushed.
clear as mud?
nocones
8/3/22 1:25 p.m.
Quick thoughts
I'm going to investigate turning the exhaust up to free up lateral space tonight.
The green outer area is the behind wheel board.  I'm planning to just have the floor be open between that and the "inlet" dividing element for the outwash area.  The floor will tie to the back of the fender so it will have some just flat profile between the outer fence portion and the back of the fender piece.
It sounds overall like my plan is okay to move forward with.  My diffuser growth will be kept under 10⁰ until after the chassis just because there isn't enough space to do more.   After the chassis it can grow as radically as we want to try.
Profiling the underfloor area for the inlet will kinda be a Second piece of this.   So I will make the tunnel inlets and outwash area and then deal with the underfoot after but I understand your recomended shape.  I will post some more pictures as I get to that end of the inlet.
For the outwash area if that fence doesn't have to be curved it will be easier to construct.  I'm thinking I will taper the outer edge of the tunnel for a little more volume.  Or is a hard 90⁰ to the ground important?  If I taper the profiles will wind up nicer.  It would also then look a lot like a modern F1 floor with the "tunnel" volume tapering to the outer floor edge behind a pair of fences that divert some amount of flow to the outside.
8/4/22 2:12 p.m.
you could round/fillet the corners of the fence where it meets the "roof" of the underbody.  Where the fence is being used to created vortices into the 'rear tunnel' volume, you'll want the lower half to be "thin", with "sharp angles" where it juts down towards the road surface... that way the flow will "break" rather than try to 'stick'... and with the difference in pressure front side to back side (high vs low) it'll encourage it to 'roll up'.
if you're asking about 'widening' of the area/volume of the side exit.  It's probably a 50/50 proposition at this point... as is the question of should it have a "hard downstream corner, or a rounded one?"  For challenge it's probably somewhat academic... and the tradeoffs will be more important when you start using it for track work... and figuring out the right tradeoffs will probably involve some testing, imho (which is why you'll notice the large amount of variability in sidepod shapes between F1 and LMP {and different generations of LMP}).
9/11/23 1:01 p.m.
a year and a month later, it's probably about time to bring this thread back up to the top.  although, reading back through my last couple of posts, I'm cringing a little bit, because I "missed" an important component of my analysis: front/rear balance.
the good news is, nocones found it on his own... ish; and added a second element to the rear foil, and that's helped get LMP360 through winning the 2022 Challenge, and most of a season of GridLife Super Unlimited TimeAttack.  The sub-optimal news, which has been covered in the "main" thread, is that the "AutoX" aero setup is overly aggressive, limiting Vmax to ~110mph, and is non-adjustable, and seems to be rear-biased (causing hard to overcome at-speed understeer).
nocones has voiced an interest in lowering the drag, and lowering the downforce, stating a "goal" of ~1500#s of downforce at 135mph.
I think we've almost exactly a month to get this new setup designed and built; mostly because the start-up to school has been a challenge for me here.  So, I reckon there's another imperative/design-parameter:  easy to build updates. {afterall, nocones is also working on a STI swap, and maybe attending an event at Heartland before UTCC, iirc}.
9/11/23 4:15 p.m.
I've monkeyed around with foil sections, then had to step back... as referenced above... and that gave me time to reconsider my approach based on the stated goals.  So, I went into my balance spreadsheet and plucked in numbers to see what was was required to generate the requested load at 135mph and have a front/rear balance similar to 40front/60rear (which is a working assumption).  I've yanked out 'profile drag' for the moment, and I've detuned the expectation for downforce from the tunnel to a Cl of 0.5... which is conservative.
a couple of big takeaways from this are:
- the reduction in "goal" downforce means that theoretically (and assuming I have the dimensions for the front section correct)... the car can generate enough downforce without resorting to canards/aero-sections outside the front fenders.
- the goal can be met with a reasonable Cl on the front element, potentially with a single element.  although, I'm not going to recommend that, because fine tuning the balance will probably be easier / easier to implement via tweaking the angle on the front second elements.
- the goal can be met with a reasonable Cl on the rear dual element; probably via reducing the chord size of the rear second element.
- the goal can be met even with a very conservative estimate on rear diffuser downforce (a number that comes from Katz' axle-back diffuser... and the LMP360 is considerably larger than that.)
9/26/23 8:06 p.m.
alright, so I ended up getting stuck in my analysis of different foil combinations... and specifically the fact that checking the original 2-element front foil in GroundEffect was giving me wildly too optimistic values... and I was having some trouble reproducing the values I had above in my spreadsheet from 2022.  All of which is somewhat demoralizing, considering it's clear that the front end isn't making as much downforce (or, possibly, that it's making it further back than I'm accounting for).
fortunately, nocones managed to do some tweaking to the rear 2nd element last weekend at Heartland; and importantly it's helped to dial in how much more the rear in the "Challenge" AeroConfiguration was making the car unbalanced (follow the link, and see that it's ~20%).
Here's the plots, keep in mind these are 2D Cl's... and my expectation JavaFoil is over-predicting things.  So, don't go running around the internet claiming LMP360 is Cl'ing out at 3.5:
"Challenge Config, Rear Aero 2D Estimate"
"Heartland Rear Aero Config 2D Estimate"
"A proposed UTCC Rear Aero Config, 2D Estimate"
although, with a couple hours of consideration... it's probably better with the time constraints involved to just leave the Rear Aero like it is... which gives the option to crank in more Rear if I/nocones manage to come up with something to make the front start making more downforce... hopefully while also reducing drag.
so, hopefully later tonight, some thoughts on Front Downforce Tweaks
9/26/23 10:43 p.m.
what's going on in the front?
java foil pictures
Front in Free Air
this is an estimate of what the front dual element section is making, in the free air.  I've circle in violet two areas.  The rear on this foil is showing what almost look like supersonic shock cones.  I don't think this is actually what JavaFoil is predicting (JavaFoil is not a supersonic/compressible analysis code).  I think, instead, this is an affectation/result of JavaFoil not being able to handle the "hard corners" that these foil shapes have in them.  And, I wonder if these discontinuities are what's leading to the difficulties I'm having in GroundEffect, below...
Front in GroundEffect
so, if we pull the dual element section down into GroundEffect, we find a surprising Cl number.  Even applying my normal 0.6-0.7% "reality" factor... I can tell this isn't correct.  If this was even remotely true... we'd be talking about how LMP360 was "crazy loose" at any speed over 50mph.
Front in Ground Effect, rotate nose up 2deg around 56% chord (i.e. were the diffuser looking section kicks up)
I think the more important use, though is to compare against a likely scenario... that rear downforce / weight shift was pulling the front aero elements up.  In this case, it's a pretty modest 2deg.  And we can see that there's a 6% loss in coefficient.  I think (although, I need to switch computers to run the numbers {edit to add that in a bit}), that the more likely culprit is that as the nose lifts, the moment arm where the lift "maximizes" shift back to around 56% of the "chord"... or 8inches back.
can we "DRS" / low angle the second element in the front?
this is a free air attempt at looking at "can we just lower the angle (15deg) on the existing plywood second element, to reduce drag?"
the answer is yes, but we'll be giving up even more downforce, compared to the existing dual element section setup in free air:
that's a 45% decrease in Cl, which I don't think is the answer; even if we really want the 65% reduction in drag.
text with some calcs from the balance spreadsheet
hobiercr
hobiercr GRM+ Memberand UltraDork
9/26/23 10:50 p.m.
This is so above my pay grade.
9/26/23 11:39 p.m.
I think calculating the balance impact of the nose lifting 2deg is going to have to wait until tomorrow.
where we are right now is this "in free air" (but maybe not actually on the car)...
if we apply our "rational" reductions, that 3.3 comes out darn close to the Cl 2.0 that I thought we needed up the page for the front dual-element section.  but, we've got to do it with better drag... and reusing the plywood rounded nose 2nd Element isn't going to cut it.
well, a section that's easy to generate in JavaFoil... and mightcouldbe easy to generate in real life is a rounded nose foil that tapers to a point.  So, I built one up based on an approximate 1" front tube, and sized to a 6" foil length.  I cranked it to 15deg, which is about the maximum angle most airliners use for "take off" (thus a good short hand L/D {feel free to be pedantic about "actually, the MD-80 uses...", this is just a short-cut.})
Hmm, not quite.  That's short by 45%.  The neat thing is, though, that despite the huge round LE of the 2nd element, Drag is the lowest of any 2-element combination checked recently... and only 0.004-ish above the "base" drag for the main element by itself.
maybe if we crank up the second element?  lets say to 25deg.  nice round number that one....
well, that's about where we want for downforce... maybe a tad low.  and the drag is pretty close to the drag from the plywood plate 2nd Element at 15deg... which means it's still a solid 60% reduction in drag compared to "The Challenge Aero Setup, Free Air Estimate".
I think that foil shape has merit.  Although, maybe it'd be easier to make it kind of like a "clark y", that way you could glue the tube onto the existing plywood panels, slap some foam between them and a quick layer or two of glass and be good.
although, I might should check what a 7" 2nd element could do to bring down the angle on the second element.  Would a 7" second element fit?
I should probably also do some work on making some adjustments to the main front element foil shape, and see if there's a way to try and keep the "choke" point more consistently near the LE of the foil even as the nose picks up.
nocones
9/27/23 12:01 a.m.
I am planning to completely rebuild the front foil shape per whatever your recommendation is.  I'm planning to use foam and wood and can make literally any shape you say is good.   Also same thing for the 2nd elements.  I can attempt to make basically anything "good".  The old rear second element shape is simple and is clark-y ish.
I'm guessing using a fully rounded bottom on the lower foil would make it less susceptible to angle?  I can also make the mounts allow for some angle adjustments so I can give the front element a little downward angle so any lift would not be as dramatic?
We can take some of this into chat tomorrow, I really appreciate your effort here.  I know I don't say much in response but I'm mostly just trying to digest it then I will do what is "best" given what I can make.
1 2 3 4
fbau23WMCiOtDK0I3iq7GzACWlCtmPG0rhrb18CE6a5XZ1vov9jAIcfFnsW37AyR
