Indy - Guy said:In reply to DIYCustoms :
This is a BRILLIANT solution.
I'm totally stealing this concept when I get around to building my trans tunnel.
I said the same thing. Brilliant.
Thanks for the update. Kinda slipped off my radar for a while and its good to know that the project is not dead.
DIYCustoms said:
Looks familiar! Your headers look WAY nicer than the ones I made for my 3900. However, that collector looks awfully familiar!
If that steering rack is mounted in position, then that is an interesting approach angle for the steering column.
What is going on with your shop? Seriously can you at least throw a misplaced coffee cup or random tool out there, you're making me feel bad.
I'm adding more lights to my shop and was concerned about adding too many fixtures, based on what I see here it will be fine.
Great project, carry on.
You'll definitely want to check the steering geometry before going too far down that road.
Flaming River sells a 90 deg device that might actually make that rack input angle work reasonably well with the OE Volvo column shaft.
Engine bay painted with a single stage system because its much easier to repair a scratch if needed.
Baking in the booth at 80 degrees
Regatta Blue is the choice of color. Used Sprint H79 clear. Sprayed 2 coats....cured 24 hours...wet sand 600 .... applied 2 more wet coats of clear.
Engine bay shown in Champion White and front grill snorkel area completed
