1 2 3 4
papamilad
papamilad New Reader
7/19/22 10:42 p.m.
In reply to classicJackets (FS) :
I just bought the STL from him and printed it myself, well worth it but if you have a motor out of the car already I'd just take some measurements and make my own
papamilad
7/19/22 10:43 p.m.
In reply to dcreech0 :
Sorry man I hadn't looked at this thread in a while, I'll shoot ya a text in a sec
papamilad
papamilad Reader
1/29/23 9:59 p.m.
Oh man its been a while since I updated this thread, guess its time to dust it off a bit. I've been a good bit busy with both this car, life, other projects, new job, new place, etc etc. But that doesn't mean I haven't been touching the Datsun! While I spent quite a bit of my time just enjoying the car (from Feb to around October I put almost 7000 miles on the car!), I've been doing some big things to the car recently (spoiler alert the engine has been out and the stock EFI is in the garbage).
In July after putting in the 5 speed I took the Datsun up to Nashville to visit some friends and hit some fun mountain roads. The car did pretty well minus some minor mishaps involving getting stuck in the rain while a windshield wiper flew off and having no headlights due to the wiring overheating from a build up of corrosion on the switch contacts and causing the wires to desolder themselves lol. But luckily a quick fix with some solder and zipties.
After this trip I decided my exhaust was a bit too janky and completely re-did it with 6-1 headers, v-band flanges, an O2 sensor bung for future plans, and just a single vibrant resonator. The straight pipes sounded sweeeeet but was a bit too obnoxious for me to drive regularly so I eventually ended up throwing a magnaflow straight thru muffler on which helped make it a much more plesant car to drive.
The fat exhaust tip was to try and help with the fumes (it didn't)
OSHA approved welding gear
Some noises: https://youtu.be/4ESiMRcylsM
After all that I hit another road trip in the car again in August this time to NC to hit the tail of the dragon! Some friends and I made a weekend cabin trip out there for a fellow GRMer's (mgfoster) bachelor party. Was an excellent time rockin straight pipes all through the mountains.
After that it was mostly just more riding around and enjoying the car.
Did some small things here and there like trying out a few different steering wheels or designing some small gauge plates
But eventually the disease struck and I couldn't just leave this car alone. I might have mentioned it before but this thing burns a LOT of oil (you can see it in the videos pretty well lol), like a quart every gas tank or so. I did a compression test and it was about 120psi across the board. Oil catch can didn't help, nor did a fresh PCV valve. My guess here is some worn oil control rings or worn valve stem seals or some combination of both who knows. Either way, to me it was time to pull the motor and give it a refresh. I've never done a bare block rebuild before so I also figured this is a great motor to learn on before rebuilding some more complex motors like I plan to.
papamilad
papamilad Reader
1/29/23 10:08 p.m.
DISASSEMBLY
So a little bit of fast forwarding here but this is basically the easiest engine ever to pull minus maybe the carb'd versions so boom here it is outside the car.
Suprisingly little grime for a 45 year old nissan engine. Tearing it down I didn't see anything obvious wrong with the motor, minus quite a lot of carbon build up on the pistons/valves. It does appear like someone has been in here before though as the Felpro head gasket on there was definitely not OEM.
And fully apart! Not too bad honestly for how old the thing is. Bearings weren't showing crazy signs of wear either minus some scoring on a few of the main bearings.
papamilad
papamilad Reader
1/29/23 10:15 p.m.
INTERMISSION
So obvious first step gotta paint the block. Can't be working on a busted lookin motor. I wanted to match the OEM baby blue but didn't feel like dropping 35$ on a pint of the paint from some seller on the internet. So instead I found out the VHT Pontiac Blue is a pretty close match so I drove around to 2 different NAPAs to pick up 2 cans and paid 24$. Snazzy stuff
In the meantime I basically spent all my time cleaning and cleaning some more and spending lots of money lol. Got the heads cleaned, decked, valve job'd, new stem seals locally for ~300$ which wasn't too bad imo. Very shiny.
Also did some inhouse machine work with a little dingus ball action to the cylinder walls. I haven't been measuring anything but there weren't any crazy lips and the bearings were standard size so we're doing this the sloppy way because its a tractor motor anyways.
papamilad
papamilad Reader
1/29/23 10:21 p.m.
REASSEMBLY
Basically just following the "How to Rebuild Your Datsun L series" book thats all over the place (except I'm ignoring the parts where he throws out the word 'measure'). Fairly straight forward stuff. I'm running standard size Hastings piston rings, Clevite mains, Tahno rods. The Hastings rings were a little funky, ring gap was measuring somewhere between 0.018 and 0.024 for everything which is beyond what the book calls for. Personally I have it on some decent authority that ring gaps for this application don't matter too much but I was a little amped up to be filing some rings. Guess we're just gonna run it.
While I was at it I also took some time to clean up my engine bay. Pretty nice paint under all the dirt in there! Also threw some rust converter on some parts of the rails that we're starting to see some surface rust.
EZ part was done lol
papamilad
papamilad Reader
1/29/23 10:42 p.m.
FANCY EFI
As I mentioned previously the stock EFI was now in the garbage (well actually I'm selling it off on facebook but whatever). I'm running a RusEFI Proteus, a full-featured open source standalone ECU developed by also a fellow GRMer! Will hopefully allow for some future power mods and much nicer running, economy, emissions etc.
I'm building my wiring harness from scratch using a universal harness I had lying around from an old MS3 install. Running all the wires was pretty straight forward as this is gonna be a pretty bare bones install (no idle controller, single crank sensor no cam). I'm trying to use as many modern components as I can. Basically think anything off an LS lol. Running junkyard LS ignition coils, GM MAP sensor, GM IAT. Running the factory CLT sensor because I didn't feel like tapping it for a different sensor and its a pretty simple one anyways. For injectors I was hoping to get away with running some free 5.3 LM7 injectors but unfortunately they do not fit the adapters I bought so I had to nut up and spend coin on some fancy Deatchworks injectors. Oh well it'll be nice having injector data for once.
Send Cut Send coilpack bracket I designed, need to remake out of some thicker material for sure.
So many wires...
Nice little amazon fuse/relay box
Spaghetti monster harness
Also some more custom sensor work: the factory TPS sensor is just an on/off switch. Luckily the key'd shaft fits a more modern Nissan unit, so a $3 send cut send adapter and I now have a 300ZX TPS attached
Also of course since these were dizzy cars factory, there is no crank sensor. Lots of ways I've seen people do it but they all seemed a little convoluted to me or had a few aspects I didn't like (like using a portion of the crank pully thats bonded with rubber to attach a trigger wheel or using a Jeep sensor off the dizzy shaft). I took a scan of the timing cover with my phone and measured up my crank pulley to come up with a solution.
I'll used a 3D printed tube to align the laser cut trigger wheel to the pulley where I can then just weld it on. Ez 5 minute job, sensor gap is designed for 1mm so should be plenty of clearance in case of any small runout.
Also took the opportunity to ship my balancer out to Dale Manufactoring to have it rebuilt as the rear pulley looked like it was ready to fly off lol.
The sensor bracket is 3D printed using an SLA resin printer out of some high temp Formlabs resin with a heat deflection temp of 238 C, should be able to withstand an engine bay environment though I am worried a bit about it being brittle. I plan on eventually making it out of aluminum.
And thats basically where I am right now. I've made some more progress on the harness though I haven't taken pictures. I lost my connectors to the ECU so waiting on those to arrive, also waiting on injectors and new adapters as I am a doofus and bent them during the first install. Fingers crossed I'll hear it run this week!
akylekoz
akylekoz UltraDork
1/30/23 6:56 a.m.
How does one scan from phone and translate to solid software?   I would love to scan a few things and get them into Solidworks.
papamilad
papamilad Reader
1/30/23 8:50 a.m.
I used an app called polycam, gives you an STL you can import
metty
metty Reader
1/30/23 12:16 p.m.
In reply to papamilad :
ive made a lot of parts out of that resin, i would not trust that for long if i were you. Yes, its temp resistant but as you suspected its pretty brittle
papamilad
papamilad Reader
5/6/23 11:35 a.m.
Whoops I am pretty bad about updating GRM threads lol. The long and short of it, I got the car running well and have put ~2000 miles on the new motor since Feb!
As predicted that 3D printed crank sensor mount didnt work very well. Mainly it flexed so much that it caused the motor to loose sync as soon as it fired off. Redesigned it to be made out of some laser cut 0.25" steel and welded together. Worked great and got the car running well.
Surprisingly very few issues with the new motor, only a slight mishap involving a rubber cap for a coolant barb bursting on the highway.
Still working on dialing in the tune, I think my provided injector data is off and I am also getting some weird very occasional intake backfires but apart from that it runs good and most importantly no longer crop dusts everybody on the road.
1st mountain run
2nd mountain run!
Working tach and LED lights
More to come for sure, next big plans are redoing the interior, AC, maybe an LSD...
classicJackets (FS)
classicJackets (FS) SuperDork
5/6/23 3:30 p.m.
Love to see it up and running. Inspiration for sure!
classicJackets (FS)
5/22/24 10:17 a.m.
papamilad said:
Not a picture heavy update but I'm done!*
*I ordered 2 left side tie rod ends so I can't drive it until the right one is here but close enough.
The rear control arms were really a giant pain. Took me hours to get them in but finally figured out the method. The bushings oversized total by about 2.5mm so basically impossible to slide over. What I did was use a flap disc to bevel the leading edge and removed the sleeve prior to install. Start one side of the arm then take a thin putty knife and use it as a ramp to guide the other. A rubber mallet was all I needed here to tap the arm into place. From here you can hammer the sleeves in and pry around with a flat head till they're lined up enough to punch the spindle in with some wood and a hammer. Make sure to use lots of anti seize and remember the pin notch isn't centered.
The rest of the suspension stuff is pretty straightforward. Everything went in without a problem
Pic of it on the ground. Can no longer remove my low pro jack without some wood under the tires so I'm gonna say we turned the needle towards 'dirty nasty low' at the least. I'd prefer a little lower personally but it looks good and hopefully it'll settle a bit lower
Also pic I took of one of the front dampers. Anyone ever seen one so blown the casing collapsed in on itself?
Not sure if there's been any progress, but wanted to quote this and your previous post as thanks for sharing the strategy. I have a spare set of RLCAs/spindles blown apart right now to refresh and knew I'd seen you post suggestions on how to make it easier to assemble!
1 2 3 4
n1d6QkeWYdC4dcO8Gze2oeFM69z6qjEwNkVQFc31LNkuysZxMYDr9sc5RRA1Tngf
