Carbon
Carbon SuperDork
11/26/17 6:42 p.m.
Cool truck man, maybe when my nutty hilux build is done we can go bombing around, vt aint to far from Northampton ma. :)
thestig99
thestig99 HalfDork
11/26/17 7:57 p.m.
Thanks! Sounds like a good time.
The biggest problem with this thing is I can't seem to take a direct route from point A to point B...
IMG_4901 by Brian, on Flickr
IMG_4910 by Brian, on Flickr
IMG_4904 by Brian, on Flickr
IMG_4922 by Brian, on Flickr
midniteson
midniteson Reader
11/26/17 8:23 p.m.
Very cool to see it out in the hills. That Thule box is awesome! great build.
thestig99
thestig99 HalfDork
11/27/17 5:40 p.m.
Thanks! More on the Thule box later.
For my own memory and organization, this is the list of maintenance and repairs that this truck has seen in the past 2000 miles.
-Head gasket replacement including cleaning and surfacing heads, new head bolts, and replacing every gasket and seal along the way (Intake, valve covers, exhaust manifold and crossover pipe, cam seals, etc
-Timing belt replacement including water pump, tensioner, and all pulleys
-Replaced radiator
-Replaced Alternator, PS, and A/C belts
-Replaced spark plugs, wires, distributor cap and rotor
-Replaced air and fuel filters
-Oil change x2
-Check all driveline fluids, found all to be clean and at appropriate levels
-Replaced harmonic balancer... + t-belt and alt belt again. Whoops.
-Clean and lubricate sliding rear window mechanism
-Wiper blades
Issues still present:
-Still seeing 10-11 MPG. Consulting the internet gave me about a 60/40 mix of "I get 15-16+" and "That's all it'll do". CEL is off but, when I jump the pins in the diagnostics box, flashes code 25 - system lean. That, combined with the amount of moisture that was in the exhaust, makes me suspect a bad O2 sensor.
-Rear shocks leaking, need replacement
-Brake warning light illuminated. Suspect this is related to the fairly seized e-brake.
-No sound from rear speakers
Norma66
Norma66 New Reader
11/29/17 11:59 a.m.
Four runners are tough. My girlfriends was on the wrong end on someone running a red light. T boned the guy at 40. Thing still ran with the front end 9 inches past the frame rail. Had 240k on it and would have done 300k no problem
thestig99
thestig99 HalfDork
12/3/17 5:38 p.m.
Hopefully I don't do that kind of strength test to this one. 2nd gens are a little sparse with safety equipment...
Hope everyone was ok!
More pictures! Needed to disconnect for a while, so I headed into the Green Mountain National Forest for the night.
20171203_081525 by Brian, on Flickr
IMG_4983 by Brian, on Flickr
IMG_4988 by Brian, on Flickr
IMG_4993 by Brian, on Flickr
IMG_5015 by Brian, on Flickr
IMG_5007 by Brian, on Flickr
IMG_5033 by Brian, on Flickr
IMG_5140 by Brian, on Flickr
IMG_5151 by Brian, on Flickr
IMG_5049 by Brian, on Flickr
IMG_5070 by Brian, on Flickr
IMG_5081 by Brian, on Flickr
IMG_5089 by Brian, on Flickr
IMG_5093 by Brian, on Flickr
IMG_5103 by Brian, on Flickr
IMG_5114 by Brian, on Flickr
IMG_5125 by Brian, on Flickr
IMG_5179 by Brian, on Flickr
Needless to say I came back feeling quite restored. The truck never missed a beat, but I fount out my crappy sleeping bag is not up to the task of December in Vermont!
mazdeuce - Seth
mazdeuce - Seth MegaDork
12/3/17 6:38 p.m.
You're good at this picture stuff. Reminds me I need to go stand in the woods again. Thanks for posting them.
I always found I'm most comfortable with a sleeping bag rated about 20-30 degrees below the actual temperatures I'll see. A 20 degree bag will keep me alive at 20 degrees, but I'm sure as hell not sleeping much in that scenario. My favorite bag ever for winter camping was a -40 bag. Nothing like waking up in the snow and complaining to your tent mates that you're too hot. laugh
thestig99
thestig99 HalfDork
12/3/17 6:49 p.m.
Thanks!
I looked after I got home and my sleeping bag is rated to 40 degrees. Temps were in the 20s last night. I had to start the truck and run the heat for a while a couple times laugh
thestig99
thestig99 HalfDork
12/10/17 7:02 p.m.
Fixed the brake warning light. As it turns out, the e-brake works perfectly fine and it was simply low on fluid. The pedal feels good so I don't think there is a significant leak, but I'll keep an eye on it.
As usual, I am incapable of taking a direct route to anywhere. Took these on my way home from a company holiday party in Manchester, NH today.
IMG_5188 by Brian, on Flickr
IMG_5214 by Brian, on Flickr
IMG_5264 by Brian, on Flickr
Nitroracer
Nitroracer UltraDork
12/10/17 7:40 p.m.
What are you taking your photos with?  They look amazing!
Billy_Bottle_Caps
Billy_Bottle_Caps Dork
12/10/17 8:04 p.m.
Great looking rig, love the blue. Great photos of nature as well, thanks for posting.
thestig99
thestig99 HalfDork
12/12/17 7:48 a.m.
Thanks guys!
Camera is an old Canon Rebel XSI, all of these were with a Canon 50mm 1.8 lens.
ultraclyde
ultraclyde PowerDork
12/12/17 9:04 a.m.
Nice pics and nice build. I still have my old XSi, great little camera. You're going to make me pick up a 50mm lense, lol.  I'm hoping to be doing these same kind of drives in my Grand Cherokee once get the front end rebuilt.
BTW, how are the Grabber ATs doing for general mixed use? That's probably what I'm putting on after the lift.
thestig99
thestig99 HalfDork
12/12/17 6:38 p.m.
Thank you.
As much as I would like to upgrade to a full frame dSLR, the XSI has (and continues to) served me very well. I bought the body used in 2010 with 800 clicks. It's well above 15,000 now and has taught me a lot in that time! Get the nifty fifty. I think I paid $100 brand new for mine, if you're patient you can score a used one for half that. I bought it like a year ago and I think I can count on one hand the number of times I have used my other lenses since.
I like the AT2's overall. They're pretty quiet and un-intrusive on the pavement and seem to work pretty well on the dirt, though I have no real frame of reference there. In the snow I would give them an "okay". I have always had a dedicated snow tire, so I'll decide in the next couple days whether I want to run them or get snows.
Speaking of snow...  we are getting our first real dose of it in the Northeast and I happened to have the day off. You know what that means.. more pictures. Sorry not sorry. laugh
IMG_5420 by Brian, on Flickr
IMG_5330 by Brian, on Flickr
20171212_184552 by Brian, on Flickr
IMG_5464 by Brian, on Flickr
IMG_5378 by Brian, on Flickr
IMG_5354 by Brian, on Flickr
IMG_5281 by Brian, on Flickr
IMG_5308 by Brian, on Flickr
IMG_5285 by Brian, on Flickr
And finally, re-fueled with the ideal cold weather comfort food - a Green Mountain Coffee Maple Supreme and poutine. yes
EastCoastMojo
12/12/17 6:45 p.m.
I freakin' love your pictures. I can't get enough. Got any more? laugh
thestig99
thestig99 HalfDork
12/12/17 7:48 p.m.
Thank you! laugh More can be found on Flickr: https://www.flickr.com/photos/27234164@N07/with/25147225568/
EastCoastMojo
12/12/17 8:05 p.m.
Thanks!yes
thestig99
thestig99 Dork
2/10/18 12:37 p.m.
Sold. sad
It's been a long time since I've been this bummed over a vehicle but something had to give.
It's going to a good home and I have to option to buy it back when I'm ready, but it will be missed.
Being an adult sucks.
Carbon
Carbon SuperDork
2/18/18 10:36 a.m.
Sorry for your loss. What's next?
2OY4JSCpJrMDqeGb6f4Ntf1Yci8eXGCdHUNpCOpPqfd1Yyvi6wwR6R9hnNjyOYIN
