OK, this morning was it! Time to swap the exhausts. I'd hit the nuts that hold the cats to the turbos with PB Blaster last night. Car up in the air, 13mm clamps hold my tips on, which I need to reuse. Then 13mm clamps that hold the X section of the Soul exhaust to the bracket.
Time to get to the nuts on the cats. Luckily I was able to get to all pretty easily, needed a 1/4" drive 13mm for one and a 13mm wrench for another, last two 3/8" drive 13mm. Don't forget about the small 10mm bolt holding the heat shield on!
Ok, pull the exhaust down some so you have access to the oxygen sensors and pop them out with either a O2 socket or a 22mm wrench.
Pull the exhaust off.
Here's where I stop taking pictures because I was getting frustrated. The AWE Tuning install instructions are available on their website, which is sweet. What isn't sweet is the instructions are flat out GARBAGE. They're basically a picture showing you how to assemble the bracket that holds the muffler to the car. What they need to do is map out the order of how the parts are supposed to go onto the car.
IE: First install muffler, then put primary O2 sensor in, rotate cat pipe in with heat shield in place, etc, etc. Nope, none of that.
I'm not sure I put it together in the proper order, I put the cat pipes on, then put the muffler on as I couldn't seem to get the cat pipes lined up into the muffler with the muffler in place first. However I do think the muffler is supposed to go on first, then torque that muffler to the car bracket, THEN put on the cat pipes.
Anyways, after much cursing and struggling, I got it done. Thank god I found the offset box end wrench my Pops gave me! A long 13mm gear wrench would be really helpful for this job and of course I didn't have one.
Exhaust is on the car!
Initial impressions, WOW! MUCH quieter! I took it out for a drive and it seems much more quiet too. Unfortunately right as I left my neighborhood my check engine light popped on. Car was still running well, I figured one of the O2 sensor plugs in the engine bay had gotten popped out since I dropped the exhaust and then removed the O2 sensors.
Yup, that needs to go there...
Cleared the codes and the car is happy.
Here's a cold start idle with the air pump turned off.
