Spearfishin
Spearfishin HalfDork
11/14/24 7:16 a.m.
Recently acquired this 2007 GMC C4500 shuttle bus. Goals, somewhat in order:
  • Fix some obvious leaks, figure out where it is on deferred maintenance items, etc. make sure it's worth keeping, essentially.
  • Add hitch capable of at least my current 24ft enclosed, ideally a little headroom in case buddy and I can stumble onto a suitable two car rig.
  • Interior "upfit". Somewhere between RV conversion and still a bus. Would like to be able to sleep 2 people in it at the track, nap some kids at a music festival, etc. But need to retain enough roadworthy seating to get a brood of cousins and grandparents to an annual musical festival or two that we have historically attended in our current c3500 short bus (which I'll be selling, ideally somewhere near the top bullet point up there).
  • Tires. Two of them have plain to see lumps/flat spots and hard for me to tell which part of the ride quality is tires vs something else worn out vs it's just a medium duty chassis, but eventually I'll bite the bullet on some new rubber.
Some background: https://grassrootsmotorsports.com/forum/off-topic-discussion/there-a-class-c-or-short-bus-option-that-can-tow-an-enclosed-trailer/272288/page1/
So at present, it didn't make it home from the sellers. Seller appeared to just be flipping it or maybe selling it for the church that owned it, but he had no background on it other than saying a church had owned it since 2017 and used it sparingly (so it mostly sat). Based on stickers and such, it was a bus for Fairfax Co VA prior to that, and since the odometer is at 389k, I think they used her pretty regular. Hopefully that means regular fleet maintenance routines.
Have ordered a belt, two idler pulleys and a few other bits from Rock Auto, be here next week. In the meanwhile it's been towed from side of I-64 to my job site where I shall enact repairs and complete the last hour and a piece of its journey home, hopefully next week.
wyndscreen
wyndscreen New Reader
11/14/24 10:19 a.m.
Following!
golfduke
golfduke Dork
11/14/24 10:26 a.m.
In for this as well... What motor is in this one?
John Welsh
John Welsh Mod Squad
11/14/24 11:19 a.m.
Do you have a proper passenger side front door?
Do you have a passenger seat? If no seat and the floor pan hasn't been modified, standard Silverado should fit.
Spearfishin
11/14/24 11:38 a.m.
6.6 Duramax. Which three letter version, I honestly don't know. Seems they used differing versions with different year breaks than the "light duty" pickups. They also detuned them to 300hp.
Spearfishin
11/14/24 11:41 a.m.
It's got a 2 panel bus door. Electric!
buzzboy
buzzboy UltraDork
11/14/24 2:06 p.m.
For our 22 passenger bus we found a few pull out RV couches to sleep on and retained the front 2 rows of bus seating. That way we could seat the whole race team and sleep part of it(or more if they're willing to share beds).
Spearfishin
11/20/24 2:49 p.m.
Got new belt. Label says 139.58" for belt. That's the label from Carrier, that's affixed under the hood after they add the rear-AC compressor. A co-worker and I both got greasy during lunch (hopefully these pants and this shirt can be salvaged) and tried installing the 140.125" belt I ordered. Still too short. By inches. I could wrestle it directly onto the last pulley if I skipped the tensioner altogether, but skipping the tensioner, beyond being generally ill-advised, changes the path enough that it created multiple fouls and wouldn't have worked more than 30 seconds before shredding the belt.
I've reached out to the bus manufacturer who pointed me to Carrier, now "MCC". Haven't heard back from them.
I have two thoughts: 1.) the tensioner looks like it's not clocked correctly for where the add-on compressor is mounted next to it, and there are grooves in the tensioner from the bottom of the belt that confirm my suspicion that something is amiss. 2.) A local YMCA is currently auctioning a bus that is same year, same manufacturer, same motor. I'm going to see if I can sneak a peak under the hood to look at their tensioner relative to add-on AC compressor as well as maybe get lucky and be able to read a part number on their belt.
So, bus ownership week #1, the bus is winning.
golfduke
golfduke SuperDork
11/20/24 2:58 p.m.
Keep fighting the good fight.  Maybe she's just playing hard to get and you need to woo her a little bit, haha.
SEADave
SEADave Dork
11/20/24 3:52 p.m.
Could you install a standard belt, bypassing the entire add-on compressor, just to get it running and driving?    Are all the other belt-drive components in the same position they would be in a Duramax 6.6 if it wasn't in a bus with the secondary air?  Is there a straight shot from the pass side alternator to the crank pulley - assuming that's how it would be routed in a non-bus application?  Just throwing out ideas.
Spearfishin
11/20/24 8:02 p.m.
Sadly, no. At least not "simply". The second compressor is mounted to a plate that's mounted to the motor. That plate holds the tensioner (in an "other than factory" location), the AC compressor and an additional idler. The position and orientation of the newly rearranged tensioner is such that it's kinda all or nothing. There's really no reasonable routing that skips anything.
Hoping the YMCA bus sheds light on things. If not I reckon I'll try routing a little piece of rope and taking a measurement.
Spearfishin
11/25/24 8:56 a.m.
Stopped and checked out YMCA auction bus, which appears to be a very close sibling of my bus.  All of the markings had worn off of the belt on it, and everything *looked* to be identical as far as accessories, idlers, etc. I didn't feel comfortable removing that bus's belt. It also had the same label from Carrier calling for the same length belt.
I took a ton of pictures, few of which seemed to be focused on the right thing, and I think I'm going to try installing the belt I have, one more time, just to make sure I didn't monkey up the routing. I feel reasonably sure I had it. But it is going around more twist and turns than your average serpentine belt.
Fun aside, I worked on the assembly line at a Ford plant for a summer. My job for 8 weeks was installing serpentine belt, mating fan to fan clutch, and spinning said assembly onto motors. While walking backwards. New one every 62 seconds. 6 choices for belts depending on motor and with or without AC.
So, this belt install feels easy in comparison.
sevenracer
sevenracer HalfDork
11/25/24 2:18 p.m.
I love this, I'm sure you'll get it sorted.
I've long dreamt of doing this as a way to have a cheap "rv" to take to the track,  but never gonna happen for me.
Spearfishin
11/27/24 4:33 p.m.
Attempt 3 (and 4 and 5) at belt. Got a belt that was 142in (effective length). Routed it once, this time alone, and it was loose enough that the tensioner was applying pressure, but just barely. Double checked it was around every pulley and said "okay, turns out the belt that matches the label IS the right belt, I must have routed it wrong last time."
Pulled 142" off, put 140" back on. When tensioning it, noticed it was slipping off of the fan pulley, but it just rides down the taper of the pulley and ends up on the shaft of the fan. Realized that wasn't in my "double check" with the 142" version, and also realized that I was again never going to get the 140" belt to go on the last pulley once I routed it back up on the fan pulley.
Off with the 140", back on with the 142". This time with special care paid to fan pulley, I could pull the tensioner to its max and maybe with another set of hands, and some pry tools, maybe I could have gotten the belt on. Devised a sketchy way of holding tensioner maxed and tried working belt onto two different pulleys thinking maybe I could sneak it on a smaller one or larger one more easily. No dice.
So, I'm sneaking up on it, but also running out of belt choices. Things start jumping pretty quickly at this length. Don't see a 143" in a quick Google search. Think I saw a 145", but if 142" would *almost* squeak on, 145" feels like way too big. Also, why the delta between the sticker and my belt? Could one changed pulley be to blame? The alternators both look "special". Maybe they have larger diameter pulleys? Idlers? I don't know.
Will spend some quality time searching the Internet over the holiday weekend and see what I can find for one more attempt at a longer belt.
Spearfishin
12/27/24 7:06 p.m.
142.xx inch belt successfully installed (with help of wife). But still not home thanks to dead batteries.
Wife's repeated comment today (first time she'd seen it in person) was "that thing is huge".
Datsun240ZGuy
Datsun240ZGuy MegaDork
12/27/24 11:34 p.m.
Floating Doc (Forum Supporter) GRM+ Memberand MegaDork
12/28/24 7:08 a.m.
In reply to Datsun240ZGuy :
Well, there you go. Someone had to do it. laugh
Spearfishin
12/28/24 7:52 a.m.
Yes yes, it was teed up. But the bus was certainly the target of that comment, unfortunately. I promise.
AhBNormal
AhBNormal Reader
12/29/24 11:31 a.m.
Your Carrier sticker shows an adjustable alternator bracket? (Curious to me but I only worked on the 8.1 versions of this chassis, alt is solid mount.) I suspect the carrier idler pulley is wrong/small. Carrier diagram also seems to show the Carrier idler is mounted in an adjustment slot? That tag also shows the tensioner with the belt running through the tensioner and very near the tensioner pivot point? or the tensioner is not correct or out of clock?(That tensioner position w/ belt behind tensioner arm {per Carrier drawing} doesn't look right to me. )
See if you can visit the Y bus again and take lots of pictures with your phone. Or maybe ask C5500 site for other pix. Too many times someone has reassembled a piece incorrectly, more likely to happen with add ons like Carrier air.
The OEM idler pulleys may be oversized? Wrong part that is similar enough to work sort of. Pictures to compare to your sticker may just jog someone's memory!
Spearfishin
12/29/24 11:53 a.m.
In reply to AhBNormal :
My best guess is that the two aftermarket/high output alternators have ever so slightly larger pulleys than stock. The alternator on the sticker shows old school manual tensioner. It doesn't have that in real life, but it did have a tiny bit of slot (like 1/2", at most) and it was already pulled towards the "short" dimension.
The tensioner works as installed, it's just installed in a different orientation to account for the add on compressor, so if you skip the add on compressor, it will no longer be clocked to tension the belt.
The issue initially is that the sticker with the diagram called for a belt 3" shorter than the sticker right next to it (just out of frame on the pic I posted). The 3" longer belt ultimately worked, though I did replace one idler with one that's 5/16" smaller diameter. Also, the idler down by the add on compressor is adjustable side to side, but via a seized bolt, so I wasn't able to move that at all. That may have also helped.
Now I just have to put fresh batteries in it, make sure it didn't shuck the belt for a reason I haven't addressed (fingers crossed) and then get it home (work is a little more than an hour from home, so I'll need a willing participant to drive me in one day...the pool of possibilities is down to my retired parents and my less than willing wife).
AhBNormal
AhBNormal Reader
12/29/24 10:56 p.m.
In reply to Spearfishin :
fingers crossed!
Spearfishin
12/31/24 6:19 p.m.
Ran today. But these lights all came on after the belt broke (which made sense), but I sure thought they'd have gone off once the alternators worked again. No proper test drive due to work/time constraints. But it runs again.
Also, reason for the dead batteries is likely some sort of parasitic drain, because there was a definite spark when I put the negative terminal on, with key off, doors shut.
buzzboy
buzzboy UltraDork
12/31/24 9:51 p.m.
We never could find the parasitic drain on our Starcraft. We diagnosed the issue as being the bus conversion, not the chassis cab. Every one of these I've seen has scary looking wiring. Lots of same colored wire and sketchy connections.
Our final decision was to leave it on the charger. I hope you find a better solution than we did.
Spearfishin
12/31/24 10:50 p.m.
I'll give a try at running it down, but this is my second short bus, and I agree, the wiring is...something.
Of greater concern, presently, is the plethora of dash warning lights. Maybe they'll cure themselves on the hour and twenty ride home.
Spearfishin
1/2/25 5:16 p.m.
After driving a short distance, all the lights cleared themselves except check engine, and battery/alternator light. Gauge showed 14v+/-, so after a half a mile trip to get more diesel and another peak under the hood not showing anything obviously wrong, I decided to go for it on the hour plus ride home.
And made it home. Alternator light never went out, but voltage gauge never dipped. That light was not on before all this, and I didn't do anything to the alternators, so other than wrestling a belt on and off twenty times and replacing the batteries with a brand new pair, I'm not sure what's up. But now it's home, so a lot easier to troubleshoot.
mJGuS4BqG1Cc1hr2WSPfHKh28CQFQU4nTapTGVf4Dkgh6j3MmLtJ9CnGQcowBnBt
