5, overdrive will help the MPG and cruising
Big, strong and bulky, rated for over 400 hp, not anything like a close ratio box.
Pulled the C4 out, as of now I am going to go through that again and reinstall.
Too many others underway to start something bigger for now.
that is gonna be a real bear to get tucked in, you may end up modding the trans tunnel, on a large scale. but if you do make it fit it will be totally worth it!!
OK quick fix, installing an AOD 4th gear gives me overdrive and it will be mobile quicker, too many projects so no manual swap for now.
Anybody got a 3.55 LSD 9" pig?
Graefin10 wrote: I'm looking forward to hearing what mpg you'll get with the new trans.
FTFY... It's Aussie, so the last part of your post did not compute.
grafmiata wrote:Graefin10 wrote: I'm looking forward to hearing what mpg you'll get with the new trans.FTFY... It's Aussie, so the last part of your post did not compute.
I was wondering what 11 inches had to do with economy of the Ranchero
aussiesmg wrote:grafmiata wrote:I was wondering what 11 inches had to do with economy of the RancheroGraefin10 wrote: I'm looking forward to hearing what mpg you'll get with the new trans.FTFY... It's Aussie, so the last part of your post did not compute.
Uh, wait... What??? I thought we were talking about a right foot...
Otherwise, that would be a REALLY uncomfortable driving-position, unless, ah, never mind...
aussiesmg wrote: No he clearly was talking about a Light foot![]()
What does some guy named Gordon have to do with this???
OK, I will try again:
I am looking forward to hearing how many miles per gallon your car will get with the new transmission. Please let us know.
There, how is that?
Graefin10 wrote:OK, I will try again: I am looking forward to hearing how many miles per gallon your car will get with the new transmission. Please let us know. There, how is that?
I manged to pull down 17-18mpg with some highway runs in my Fairlane with 3.89 gears. The overdrive helps a lot.
I give this one a thumbs up high five
This Ranchero is like a Subaru Brat that grew up to be a man.
Ford needs to see this and build a new one with a Coyote 5.0
300 trouble free miles yesterday, we did find a couple of things to improve, I need a better rear ratio, the Zombiechero wouldn't go into 4th gear until 80 mph and shifted down again at 60.
Ordered a 3.7 ring and pinion to replace the OEM 3.0 as I had already planned on installing a mini spool.
The ugly beast runs down the road like a new car though, seriously
This has made the cut as well
