1 ... 20 21 22 23
8/17/17 10:06 a.m.
Haven't been doing much with the car, a little tuning here and there, and recently I took it to get the crank sensor bracket modified again because the alternator & water pump belt is bowing outward at high RPMs and shaving itself away on it. But it looks like the next autocross which was originally scheduled for this weekend will be postponed to a date when I'm out of the country. The only upside is that it's being done because the track's being partially repaved, and a smooth surface would be a massive advantage for my car. I was starting to consider going for a more rally-oriented suspension because of how bumpy this track is.
10/10/17 10:24 a.m.
So there was a track day on Sunday. Only work I'd done since the crank sensor bracket mod was some tuning, mostly on the accel enrich settings. This setting works well, it's almost impossible to get burst knock now:
But on the warmup lap (warmup for brakes and tires anyway, the engine was already warmed up and I was running it hard from the start) I started to hear a faint scraping/whistling noise. My wrecked-engine PTSD sprung into action and told me to get back to the pits ASAP. As I drove back in I could hardly guess what it might be, it seemed to have something to do with engine RPMs, but maybe a rear sway bar tab came loose again. When I popped the hood I saw some smoke coming from the pulley side of the engine. I had a look around and soon saw the problem:
Half the timing belt had been chewed off by something. No idea what. The crank sensor bracket might be an immediate suspect but it's not that close to the timing belt. You'll also notice the fresh streaks on the alternator belt, indicating that the sensor bracket is still making contact with that belt at the very highest RPMs, so it needs some more clearancing. One suggestion I got is that the stock timing indicator bracket might've been bent close enough to the timing belt to slice it apart when it bows out at high RPMs, apparently it doesn't take much. I don't know where the oil on the timing wheels came from. Oil has spewed from the dipstick tube before, but I had the dipstick velcro-strapped down and didn't see any oil around the top of the tube. Might've been a spill from an oil change the day before.
Anyway I got permission to leave the car at the track for a couple days, I'll take it to the shop that did the crank sensor bracket mods this evening.
10/10/17 10:42 a.m.
Some bonus track day pics. It was a pretty ballin' track day, I think I had the plainest car there:
The famous "RX3" with the front clamshell off:
oldeskewltoy
oldeskewltoy UltraDork
10/10/17 12:17 p.m.
not saying this is your belt shredding issue....
I've seen the tensioner spring fall off before....
10/27/17 6:36 p.m.
Turns out a backed-out bolt is what shredded the belt, also the cam and crank seals were both leaking on the front of the engine, which is odd because they're fairly new. Maybe too much crankcase pressure? I'm thinking I should add a PCV valve to the crank vent system to be safe.
10/31/17 9:19 p.m.
Got the car back tonight, on top of the timing belt and crank sensor bracket problems, the car also had a backed-out alternator bolt, dirty alternator output connector, and a coolant hard line with a tiny leak. Also it seems that my WB02 controller has failed, possibly from getting too close to the exhaust, I'll have to take a closer look tomorrow evening.
11/2/17 8:57 a.m.
There were no physical signs of damage to the WB02 controller, but electronically it looks very FUBARed. It isn't outputting calibration values on startup as it should and outputs noisy nonsense readings of 9.7:1 (below the normal minimum output value)~15:1 while driving. So it's disabled for now, luckily I got plenty of tuning in before this happened. After the autocross I'll get the wiring checked just in case there's a bad connection somewhere, if not I'll get a replacement smuggled in around March next year.
I might be able to bring home a trophy for the first time in quite a few years at the end of this season. I'm one of 4 competitors tied for 4th in 2wd class, behind my navigator who's just 2 points ahead. One guy who just bought a Toyobaru and took the 2WD class win at the last event is just 2 points behind. I've beaten Toyobarus before, but with drivers of questionable skill, this guy I used to see at track days when I was a teenager so I know he has experience.
My car is the 2nd least powerful of any of the potential contenders for 3rd (after my navigator's rally car), one of which is the electric sevenesque - I dread the day when the driver figures out that if he were to artificially limit the car's power output for autocross to 1/4~1/3 of full power, it would give his right foot a sporting chance at controlling wheelspin (and the related gratuitous spinouts) and make the car nearly as dominant in autocross as it is in drag racing.
11/15/17 7:15 p.m.
Finally have some time to recap the autocross on the weekend before last. Took the car on the day before to get the alignment checked, at a different shop this time. The guy did a good job, and this is a shop with a laser alignment machine I can get the car to on my own without taking a day off work. I still think my usual alignment shop was trying to give me a right-turn-biased setup to be faster around the bigger track here, even though that's not a course I'll ever compete on.
The morning of the event, my offroad rally navigator wanted to share since he was between cars, and he'd shared his rally car with me once before, so it's only fair. I figured the car was pretty well sorted out by now. On the first run I went out and one of the sway bar link tabs slipped again, so I had to abandon the run and fix that. At the end of my second run I got a decent time but heard that all of the course workers were smelling coolant from my car, and now I could smell it too. I popped the hood and saw that one of the caps over the ports that would've gone to the heater had burst open and was sprinkling coolant onto the gearbox. I called a nearby parts shop to reserve a cap and called my dad to bring it to me with some coolant from home. He got there just before the end of run 3 so I actually didn't miss a run. I rushed out there, forgetting to start the data logger or roll down my windows, and surprisingly cut 4 seconds off my previous run. I didn't think I could cut off more than 2.
My 4th run wasn't as fast as the 3rd. So I got 5th in 2wd for the event (behind the guy in his new Toyobaru, a top rally driver in an e36 rallycross car, and two guys in an R33) and 4th in 2wd for the season. If the previous event hadn't been rescheduled to when I wasn't here, I easily could've got 3rd or even 2nd. But, it's clear now that this car can't be a championship contender anymore. The guy with the new Toyobaru beat me by about 9 seconds, and the guy in the electric Sevenesque almost took an even faster time before he plowed past the finish gate. Before I swapped in the 4AGE I was usually within 2 seconds of FTD. So I've started spreading the word that I'm thinking about selling the car. I don't know what I could afford to replace it with that would be competitive, but the best platforms to start with around here would probably be an IS200 or late RX8.
12/22/17 2:12 p.m.
Now to recap the track day I did a couple weeks ago.
To prevent any more coolant caps from blowing out, I changed them for a looped line. I couldn't find any shaped lines to make the sharp ~270deg bend, but the hydraulics specialty shop recommended a silicone line and assured me that coolant wouldn't seep through it:
These are the two ports where the caps were:
I also added a PCV valve connecting before the throttle body to give blowby gases another path in case the catch can was too restrictive:
This time at the track, I was focusing more on lines and less on finding the car's limits, so the times weren't as quick. I was worried the looped heater line might not be good for coolant flow, but there were no heat problems, the needle stayed centered and the data logger shows that engine temps never went above 203F. The only problems I had are first that the engine felt weak above 6500rpm, I'd just added 1deg of advance at 6krpm+  trying to address a fall-off in power at high RPMs, thinking that overly conservative timing could be the cause, but that seemed to make it worse. I'll undo that and try retarding cam timing next. Second, the alternator belt is still scraping on the crank sensor bracket at high revs, so I'll have to get that modified again. For this data log, I also added in the megasquirt's log file for engine data:
1/9/18 7:54 p.m.
So recently I've been thinking about what to do with the car this year and looking very closely at the wheels. Since the car can't be competitive anymore, there's no point in rushing for more performance, I might as well take my time and do things properly the first time. Even 15x8s are a tight fit, spacers would most likely be needed in the rear. So I'll work toward a rear pushrod conversion to make ample room for 15x8s without spacers, or ideally even 15x9s with 245-wide tires. This will also give me room to go back to the old progressive springs which I think performed a little better, the rear is a bit jittery with linear springs. I could then move the springs currently in the rear to the front with tender springs for better tire clearance and droop travel.
First though, I want to get the rust fixed and get some fresh paint on the car. Since performance mods aren't priority #1 for the first time ever, now's the perfect time. I may also reduce the depth of the spare tire well to make more room for a diffuser later on. And I figure the car would be a lot more pleasant to drive with working AC. Probably next weekend I'll get the problems I found at the last track day looked at.
And here's a little bonus, the full-length video from that last track day where I chase down a Toyobaru. I'm sure I could get even closer with my last thousand revs of useful powerband back.
3/23/18 9:05 a.m.
I have an huge backlog of stuff to post for this thread and on my Samurai, it's the busiest part of the racing season and the busiest time of year at work, but I just saw loosecannon say that he's jealous of people who don't have to wait for snow to melt, so it's time to make living in the Caribbean pay for itself cheeky
First, here's a quick vid of a track day back in February. The day before I got an alignment and the battery was drained in the process again, and it failed on the track that day, causing the car to go into limp mode and later, voltage-induced sync losses. And then the starter motor finally died completely. Here are the only good laps I got in (no data due to voltage problems):
Reducing ignition advance eliminated the high-RPM power loss problems. Had to get a push-start to leave the track after this, drove it straight to the electrician to look at these problems, I'll give the rest of that story in a later post...
4/8/18 8:30 p.m.
The backlog continues, now I have 2 events to cover.
So the autocross was soon after the track day back in February, I had both a dead battery and a bad starter. The starter couldn't be fixed so a replacement was found. But the gear wasn't moving far enough outward on that one, so I had to get it exchanged, so I had a dud starter for the autocross and had to get push-starts.
First run was decent, second run I had a brainfart at the turnaround point near the start, went around one too many cones and DNF'd. 3rd run was an improvement, then I got the suggestion to try handbraking instead of driving around the far side turnaround which was full of rubble. That shaved off nearly 4 seconds on my final run, good enough for 5th in class behind the electric sevenesque, a Toyobaru and 2 top drivers in a 3-litre BMW rally car.
After this it needed some more time at the electrician for a second starter replacement, a troublesome gauge wire and a replacement Spartan Lambda 2.
4/23/18 10:50 a.m.
OK so now it's time to update on April's autocross. I got the starter replaced (again), got the gauge fixed and the new WBO2 system installed, so the car was working well. Weather wasn't great, it was hot and sunny but there were occasional bursts of moderate to heavy rain, it fell pretty heavily during the course walk in fact, plus there was a thick layer of dirt on the track in the middle of the course. Bernie Ecclestone's dream! We also had electronic timing for the first time ever.
On the first run I went out and...set a pretty good first run. The turnaround in the box could've been faster, and the turnaround at the tires could've used some handbrake to reduce the wide plowing, but it was good otherwise. Heading toward the turnaround by the tires was the first time I had a reason to bounce off my rev limiter, it was pretty violent with retard from 8000-8200 leading to fuel & spark cut, so after this run I changed it to retard from 7800-8300 leading to fuel & spark cut.
The trouble is that when I tried to make my later runs faster, I messed up on the dirt in the middle of the course. In retrospect, even though the rain never fell close enough to one of my runs that I had to drive on a wet course, I think the rain was changing the condition of the dirt and making it more slippery over time. On my last official run, I was extra careful to take it slow over the dirt and got into a big 180-degree spin, rather than just plowing wide or getting too sideways as on previous runs.
So my first run ended up being my fastest official run of the day.
On my fun run I think I showed that there was room for a run in the 1:46s with better driving, I got a 1:47-something plus one cone down, even though I had a brainfart and almost went the wrong way around a cone.
So I ended up 5th in class behind the two drivers in the 3.0 BMW rally car, the Toyobaru and a new competitor in a Nissan March-based SR20-powered race car. If I'd driven better I might've been able to move up one position ahead of the "March." A former champion who was working the course said that my car seemed to be the fastest in the tight part of the course and that softer rear damping might help on the dirt. I'd increased rear rebound damping to get more rotation in track driving, but softer rear settings did work well in autocross, so I might try a softer rear setting next time.
The electric Sevenesque wasn't competing because its battery pack burned down in a drag race a couple of weeks before and the new batteries hadn't arrived yet. I did plan to beat some cars with reliability, but that's the last one I would've expected! So in class points I could have a shot at 3rd this year. Right now I'm 4th in class and overall.
10/7/18 1:48 p.m.
I've got quite a backlog of updates and videos to post. Before August's autocross, I had to get the engine internals looked at after it started to make some frightening knocky noises, luckily no meaningful damage this time.
August's autocross happened after the track was used for some event that had wooden stages built on the track, so we were on the lookout for nails on the track walk, many had already been swept off. The course required tight 180deg spins around the end points plus 360deg spins around a cone in the middle, so the handbrake sure came in handy.
On the first couple runs I didn't get all the turnarounds right. On the 3rd run I had everything figured out and the run was going well...until I saw a course worker running toward me doing the Team America Secret Signal. Turns out I got a flat on the left-rear early in the run.
So I had to get the factory spare brought to me to use on the last run. The car was now sidewaystastic in right-hand turns, which wasn't all bad on this course. No good data logs unfortunately:
This run was good enough for 5th fastest in class, 6th fastest overall, and puts me in 3rd in championship points. Looks like the next event in November will be at the bigger smoother track which definitely suits my car better, it's just a shame I'll have to do it on what's now a very ragged tire setup (ancient Z1SS, half bald on the front, and now an even older Ecsta SPT on the left-rear).
10/26/18 9:59 a.m.
Working to clear out the backlog some more, here's a session from a track day back in August. I uploaded the whole thing, this session shows some interesting cars and good 1:27ish laps.
This day was pleasantly uneventful in terms of breaking stuff, but I was still trying to work out the high-RPM power loss. The next day I entered a dexterity and sprung another gearbox leak from the axle. Had the axle polished this time so hopefully the axle seal will last longer now.
10/29/18 3:16 p.m.
And now a video from the track day in September. Featuring a battle with two 4AGE 20v-powered cars (Corolla FX and Charmant)! Around the 7-minute mark, EUROBEAT INTENSIFIES
During this track day I was trying again to diagnose the low power at high RPMs. When the problem struck the engine sounded like it was on a spark retard limiter, but I knew that more advance didn't help and possibly even made it worse. On the first lap or two of a session I didn't have the problem, so I tried a tiny bit more spark dwell thinking that the coils might be losing power due to heat - this would cause more heat buildup but might temporarily alleviate the problem and point to a solution. No luck there.
After studying the data logs afterward, I figured out that the IAT retard was pulling timing during these early laps, and then when the engine bay cooled down the slightly more advanced spark brought the problem back. So it seems the problem was actually too much spark advance, I think the base timing is off a few degrees. So I pulled another degree from the whole table and will test again with these settings, less than two degrees pulled based on IAT seemed to do the trick. At least I know to try pulling more if I have the same problem...hopefully this much advance hasn't done anything bad to the internals.
On this track day I also found that a scraping noise I could sometimes hear in hard turns was the axles rubbing on the brake lines. Good thing those steel braided brake lines were sleeved with fuel lines for protection so no real damage was done before I found the problem. In retrospect the packaging difficulties of steel braided brake lines aren't worth the tiny morsel of reduced pedal squishiness, I'll stick to rubber lines in the future.
Final autocross for the year is this weekend, back on the same old rough track as usual.
11/6/18 12:55 p.m.
Here's a little bonus, a feature on that surprisingly fast white Honda Fit you see in many of the track day videos:
https://www.sleeperforest.com/articles/2018/10/27/qlyoje295bq1hxhvfko81rr9xdwfqb
Pete Gossett
11/6/18 3:15 p.m.
In reply to GameboyRMH :
Ooh, that’s pretty sweet.
12/28/18 12:17 p.m.
OK now to report on the last autocross of the year back in November. I've been real busy and I've probably been held up too much by the difficulty of adding datalogs to the videos, since Racerender's data templates just don't seem to work. It completely ignores header rows and fields that are empty in the first data row, and doesn't actually seem to read TSVs even though it says it should, requiring modifications to the log files and setting up field mapping/interpretation from scratch every time. So time to forget about that until I can streamline the process.
So I started the event with 2deg of ignition retard vs. the last track day, on 3 ancient Star Specs (2 nearly bald) and one perhaps dangerously ancient Kumho SPT. This course had two tricky spots, a 360deg spinaround cone close to the edge of the track (which you would have to go through 4x per run!), and a ridiculously gravelly area in a place that would cause terrible corner-entry understeer in both directions.
The first run was just OK, not great.
On the second run I went into the "tunnel" too quick and spun over a few cones. This started a horrendous scraping/squeaking noise that I thought might be something loose in the suspension. It took quite a while to figure out that it was an exhaust heat shield that had been bent onto the exhaust by a cone and was scratching against it.
Heading out to the third run I got a tip that I was losing time by overshooting the turnaround/360 cones too much, and that I should brake down to a lower speed and get into 1st before these cones so I could turn tighter around them. I saved some time in the turnarounds but I locked up and took down the stop cone so it wasn't much faster.
On the 4th run I did better on average on the turnaround/360s - I still messed up one turn and went in the grass - and took down a cone, but it was my fastest. Man I look like a hyper-competitive shiny happy person at the end of the video don't I?
Well it kind of paid off, that run was quick enough for 6th in class for the event, and 4th in class and overall for the championship, behind a couple of drivers in an Escort Cosworth and E36 M3 rally cars (or one in an Evo 10 for overall) and another guy in a Toyobaru.
There's lots more to write about what's being done in the off-season and the future of this project which I'll update with later.
1/2/19 2:13 p.m.
Now, post-season update and plans for the off-season.
I scored some rare and handy parts which I'll post pics of later: A 4AGE 20v AC compressor (the ones I had all needed work, and I found a ran-when-crashed one for a decent price) with plus-sized pulley, a lower AC hardline which will let me simply bolt up a 4AGE compressor to a 4AF AC condenser (Didn't know such lines existed!), an AE101 manual shifter (I can mix parts with an AE92 shifter to make a quick shifter), and some really short 600lb/in springs for the rear.
About those springs, after looking closely into fitting 15x9s and doing a rear pushrod conversion, I've decided that the last inch of width isn't worth it. Wheels of that width will interfere with the existence of a front sway bar plus likely the control arms, which was all the convincing I needed after considering the costs of the rear pushrod conversion and how much cargo space it would take up (a real problem for a mixed street/track car that hauls all its own equipment). So I'm just going to move the springs on the rear above the tires and settle for 15x8s all-around.
So my off-season plans are to get those springs on the rear along with the super-long sway bar links (so that the closest thing to the rear tire will be the coilover shock body itself), get the current rear springs onto the front with tender springs for more front droop travel, get the AC assembled and working, and get a laser alignment done. The off-season is more than half-way done though, the first event is on the 20th. I'm looking for some used tires with more life in them than what I have to hold me over until I can afford to import a new wheel & tire setup. One of the Star Specs delaminated so now I'm running Z1SS on the front and Kumho SPTs on the rear, and I have no full-sized spare tires left.
So to get started on that work I took the car to the electrician to get the AC electronics checked, check on an increase in the occurrence of sync loss, and get the AC compressor bolted up. On the way there I got total and permanent sync loss for some reason, I should find out why soon.
2/21/19 9:47 a.m.
Late off-season and long-term plans update:
So the sync loss was caused by the sensor bracket getting loose and allowing the sensor to move a little too far from the trigger wheel - meaning that I could've got on the ground under the car and fixed it myself when it broke down, but considering that it was only mostly pulled into a gas station off the highway and it was raining at the time, towing it with a strap 5 minutes to the shop was fine too. The bracket was modified again to bring the sensor a bit closer. It's a rock-solid almost OEM-quality piece now, so hopefully that was the end of the trouble with it.
To fit the AC compressor I'd have change the routing of the oil cooler lines a bit, and to do that I'd have to change some fittings and extend some of the lines, and because those fittings and lines are madly expensive locally I decided to put that off until I could get those in by more affordable means.
As for long-term plans, progress will likely speed up in the long term, but it will be more sporadic. I'll be moving to Ontario in May and storing the car - I've sunk so much into it that keeping it for occasional use feels like less of a loss than liquidating it. Since I haven't found any indoor storage options the most urgent work needed is to fix the rust in the roof and rear deck area - these let water in which causes more rust in the spare tire well and door sills.
So a quick list in order of importance:
- Fix roof & rear deck rust
- New shorter spring setup
- Reroute oil lines & Get AC working
- 15x8s with 225/45/15s
- Brake vent system (at least for front)
- Quaife QDF15E diff
- bigger cams
- ITBs + IACV
And here are some of the parts I've scored recently. 20v AC lines and AE101 shifter:
Arr matey, shorty springs and spacers!
Also this tender spring setup from the donor car will be going onto the front:
After some cleanup:
Pete Gossett
2/22/19 5:47 a.m.
Congrats on the upcoming move, I hope it works out well for you!
2/25/19 5:54 p.m.
The backlog is getting large so it's time to post a quick update on January's track day. By this time I was running Z1SS on the front and SPTs on the rear. The car ran almost flawlessly that day - the one flaw being the power loss at higher RPMs. I'd tried more and more retard until I could feel power loss with no further improvement. Looking at the logs afterward, the most likely cause now seemed to be too much fuel at higher RPMs - my fuel map adds fuel all the way up to the right side of the map at 9krpm for safety, while the stock maps reduce fuel as revs increase above 5500rpm. This would also better mesh with the fact that I could get more acceleration by lifting off the gas slightly.
Well there was one other problem that could be considered a flaw, at one point coming onto the lower straight I chucked the car into the last two corners pretty hard, and the front suspension got into a nasty oscillation with the front corners hitting full extension in cycles, which had the car skipping diagonally across the track, going to neutral throttle and countersteering brought it under control but it wasn't good that it started.
Even with the crappier tire setup I managed to reduce my fastest lap down into the 1:26es.
Here's a video of a full session featuring the swapped Fit, a modded AE101 GT and a friend's Porsche 944 Turbo - the only non-rear-engined Porsche sports car in the island. He was having fuel starvation problems which is why he couldn't get away from me cheeky
2/27/19 9:57 a.m.
Now onto the spring swap. New rear setup:
Installed with XV30 Camry extended sway bar links:
Full tire & wheel clearance achieved!
New front setup:
Homemade spring bags from a friend:
Installed:
I also changed the front brake pads all by myself, which led to the biggest wave of regret ever experienced while working on a car the first time I was balancing 50lbs of various metal doodads and hygroscopic fluids on my knee trying to push the piston back in. But that's done now. I really want to get a video with data together for the next update.
3/3/19 9:30 a.m.
Now for the first autocross of the year. I took the car for a laser alignment, and got a set of used Kumho C03 semi-slicks from a friend. Old but with plenty of tread depth still on them. My first run was...pretty good, even though I went too fast on the finish and got loose, and it was clear afterward that I was running too much tire pressure. I took plenty of pressure out of the tires for the next run. That run was great! I took a bit more pressure out on the third run and it wasn't quite as fast, so I think the ideal pressure for these tires is somewhere between my 2nd and 3rd run pressures.
I wanted to get a video with data to see what kind of accelerometer readings I was getting with the new tires, but the RCP had some kind of failure again, so I only got the data logs from the MS3 for my fastest run. After updating RaceRender I was glad to see that at least the RCP log headers were being properly detected and the field mapping files were loading correctly.
The class structure's changed this year so that run was quick enough for a class win:
Next post will be on the track day which started directly afterward.
1 ... 20 21 22 23
XtNneacnO3YzjKamAfFA5e3DKgjd71Qt4obQQFREpEarkTY8LC3s4JBxkAwjGBBp
