Cooper_Tired
Cooper_Tired Reader
3/1/15 8:00 p.m.
Incredible
java230
java230 New Reader
3/2/15 7:10 p.m.
Thanks for the comments everyone! If anyone is thinking about it, try it! It's way easier than I thought it would be. I'll post an update when we do the next one.
java230
java230 New Reader
3/5/15 11:28 a.m.
OK finished the shelf up.
Flat bar across the legs for the supports.
20150303_172426
Cut and finished a few pieces of mahogany. Flat bar across the bottom to hold them together and keep the spacing. 20150304_102756
My legs weren't perfectly located, so I had to measure a milion times to make sure my cut was going to be in the right spot to drop over the flat bar supports. Not square to the shelf... Used a router with a fly cutter to cut the slot.
20150304_112531
Wet sanded the finish into the top with 400 grit. Works awesome using the oil to sand with. And done! Slots were in the right spots! I used a 1/4" fly cutter, with 3/16 flat bar, so I had a wiggle room but it fit perfect. Bad picture... 20150304_181412
bluej
bluej SuperDork
3/5/15 11:49 a.m.
love that, well done!
java230
java230 New Reader
3/13/15 4:31 p.m.
Number 2 in the works. For a coworker, Its a fire table, we built a burner to go in the center, and it will be on his patio. propane firepit built into table... 40x40 table.
Much thinner this time, and we did our own mix. Its 1.25" thick, lots of fibermesh, no steel, and 50/50 mix of sand and portland.
20150313_140142
jgrewe
jgrewe Reader
3/14/15 12:43 a.m.
Um, couple things. When designing your mixes any amount of rock will lower the amount of Portland you need for a certain strength. Each small particle of sand or rock needs to be coated with Portland. The more "fines" you have, the more Portland you need. Also, different limestones out there will have different hardness. Harder rock, stronger concrete.
You can easily get a smooth finish on thin concrete using "89" rock. "89" being rocks that fall through the screening process through the 8 and 9 sizes mixed together. About 3/8" to 3/4". The other popular mix for concrete is "57", 5 to 7 on the screening. 3/4" to 1 1/4" IIRC.
Be careful with the burner location, direct flame on concrete and it can explode.
java230
java230 New Reader
3/15/15 2:05 p.m.
jgrewe wrote: Um, couple things. When designing your mixes any amount of rock will lower the amount of Portland you need for a certain strength. Each small particle of sand or rock needs to be coated with Portland. The more "fines" you have, the more Portland you need. Also, different limestones out there will have different hardness. Harder rock, stronger concrete. You can easily get a smooth finish on thin concrete using "89" rock. "89" being rocks that fall through the screening process through the 8 and 9 sizes mixed together. About 3/8" to 3/4". The other popular mix for concrete is "57", 5 to 7 on the screening. 3/4" to 1 1/4" IIRC. Be careful with the burner location, direct flame on concrete and it can explode.
Dualy noted. We used a mix that was common in concrete tables. They did use csa when the temp was lower, but we tried without. If it doesn't work we will try again.
I stood on my table that used bagged mix, no breakage yet! We are trying to go thin though.
java230
java230 New Reader
3/16/15 10:36 a.m.
Stripped it this morning. Seems strong, but time will tell. Definately lighter than my top. I can pick it up by myself. Probably ~150lbs for a 40x40 top.
20150316_082647
java230
java230 New Reader
3/23/15 12:53 p.m.
Stood on #2 after 5 days cure time. Did Not break!
20150316_152759
Practicing making lips. I need an overhang on my counter top. It was a pain in the ass to do. #3 is 1" thick, with 1" lips on the edges. Same mix as #2. I will do an enclosed form next time I think, too hard to keep the mud in the lip and vibrate it.
20150323_074719
anW4l0vP7T9gvLmkjfnD2AX9vmfshlPqPhx4FKoXhAfd8haoARNat2sBzJsHpZ2j
