1 ... 7 8 9 10 11 ... 23
2K4Kcsq
2K4Kcsq HalfDork
4/7/16 11:33 a.m.
Hahaha it takes a bit of wiggling but a nice tight fit once in there
mountainben
mountainben New Reader
4/7/16 11:45 a.m.
Might consider some blue lock-tite.
2K4Kcsq
2K4Kcsq HalfDork
4/7/16 4:52 p.m.
In reply to mountainben: That was a rough mockup, sorry about that. I am using nylocs on everything so I hope that holds it all together.
Had to spend most of the day doing yard work but I made it this far and stopped, thinking I better treat the wood with a water sealer before assembly.
nocones
nocones GRM+ Memberand UltraDork
4/7/16 5:27 p.m.
That's amazing. I would validate drive hub tooth track engagement prior to to much more work.
mountainben
4/8/16 12:21 p.m.
Just wondering what the roller looking part is in between the inner track belts, centered on the track guide. Optical dillusion?
2K4Kcsq
2K4Kcsq HalfDork
4/9/16 2:10 p.m.
In reply to mountainben: it is the stainless cup that rides on the drive cog. You can see it better in the pics before powder coating on page 4.
2K4Kcsq
2K4Kcsq HalfDork
4/12/16 8:30 a.m.
The instructions said don't over apply. Sounded like more of a guideline than a rule so I dipped them in Thompsons water sealer. Made a mess but they look good now that it's dry.
2K4Kcsq
2K4Kcsq HalfDork
4/15/16 9:41 a.m.
A bit of a set-back. On nocones advice I decided to check track/drive engagement once everything was tight on the first 4. . . . Berk. My plan to use the shorter belts has backfired. I only lost 3/8 between each guide in an attempt to use what I had but that has proven to be too tight. I even attempted to check this after I drilled 2 of the belts. It looked good then but once all parts are together and tight they are a little too close. Not sure what I will do here. I'd love to order precut & drilled belts but that will cost me a fortune. I have 2 more rolls of belting but it's the same length as the other stuff. I guess I could run 2 splices to make up the length. . . Kind of a halfass solution but then again, so was my shorten everything plan
java230
java230 Dork
7/28/16 3:13 p.m.
Any updates? I hope its on the snow this winter!!
2K4Kcsq
2K4Kcsq HalfDork
10/28/16 9:52 a.m.
In reply to java230:
busy summer but did a couple small things like blast & paint the battery tray and I found a new 6v starter bushing for it.
started round two on the track belts yesterday. going to cut 8 new belts drilled to the correct spacing, then use a 2 or 3 foot section of my previous belting, re-drilled of course.
I have gone back and fourth on this decision all summer. I dont really care for the thought of 2 splices but with a budget this tight, its the only option to put it on the snow this year.
also need to find a cheap heat shielding solution for the fire wall. factory used a fiberglass type with aluminium foil backing both sides.
java230
java230 Dork
10/28/16 10:30 a.m.
WOOHOO! Glad to see your working on it again. Im itching for snow.
Would this type work? Amazon link
2K4Kcsq
2K4Kcsq HalfDork
10/28/16 10:39 a.m.
that looks quite good for the money. plus its not very thick and has a high temp rating. thanks man!
BrokenYugo
BrokenYugo UltimaDork
10/28/16 11:55 a.m.
That insulation sounds like something from the HVAC section of LoweDepot.
2K4Kcsq
2K4Kcsq HalfDork
10/29/16 12:02 p.m.
decided to mock up 2 drive belts to test the spacing for track/gear engagement before drilling all 8 belts again.
looks good this time.
finished drilling one last night. only 7 more to go
Flight Service
Flight Service MegaDork
10/29/16 12:07 p.m.
Better hurry, winter is coming
2K4Kcsq
2K4Kcsq HalfDork
10/29/16 2:01 p.m.
no idea what the story of this conveyer belting is but I bet its older than me
java230
java230 Dork
10/29/16 7:43 p.m.
Awesome, engagement looks great. I'm still jealous. I want a cat!
Petrolburner
Petrolburner Dork
10/31/16 1:24 p.m.
Cool!
2K4Kcsq
2K4Kcsq HalfDork
10/31/16 8:57 p.m.
these tracks have been a ton of work. but it is satisfying to finally see everything fitting together.
2K4Kcsq
2K4Kcsq HalfDork
10/31/16 9:07 p.m.
java230
java230 Dork
11/1/16 10:25 a.m.
Looking awesome, just wait till its chugging up the hill for freshies!
2K4Kcsq
2K4Kcsq HalfDork
11/1/16 5:17 p.m.
one done minus splicing cant get it all in frame when its laid flat out
2K4Kcsq
2K4Kcsq HalfDork
11/6/16 10:09 a.m.
thursday night we had plans to get the engine in. that shifted into a fiberglass repair on the front.
atleast now there will be something to sand into when we do body work. one of the previous owners did a patch job on the outside years ago but if you were to try and block it out there wouldnt be anything left. also considering a front skid plate.
java230
java230 Dork
11/6/16 10:34 a.m.
Looking good! So close now
2K4Kcsq
2K4Kcsq HalfDork
11/7/16 7:47 a.m.
thanks man! its getting close for sure.
trying to find the cheapest source for the flexco bolt type lacing. I have a little bit of 375x but need more for the drive belts and cant find the hardware for what I have.
E7KGbNdBox5byN6oTcpSwWYHZgN7xH5VTFedGV3XEcvnzvPMXLRmMD9kEShBEahO
