TR7 said:In reply to throttlegrotto :
Why try to match up the ABZ with the 928 bell, clutch, PP, flywheel? That seems like extra work. Use as much of the ABZ as possible and just adapt the 928 TT and DS to fit. Dont even make a spline adapter, just cut off the splines from the 928 TT and weld on what you need from an ABZ trans input shaft or something.
There never was an ABZ manual trans equipped car in the states. Even ROW, it's a pretty rare bird. Think Audi D2 S8 and the take rate on a manual on those. I think some of the C6 RS6 cars came ABZ equipped too, but not stateside.
And the 928 setup is unique in that it goes in and out of the car from underneath, not pre attached to the flywheel. You can remove a whole 928 clutch setup in a half-hour. The party trick is the 2 piece sliding spline adapter that goes down the torque tube for removal, and then slides into the clutch discs and bolts in place for engagement. The lower bellhousing unbolts as well to allow to access to about 40% of the pressure plate, and gives room for the intermediate plate/2x discs/pressure plate/release arm/ T-O bearing / and guide tube to drop straight down out of the bellhousing. Only the flywheel stays attached to the engine.
the splined shaft that engages the 2x clutch discs
And the coupler that joins it to the torque tube.
So deviating from this setup would take a lot more ingenuity than I have ,and also make engine removal potentially more difficult later.
Cams and tune....
The nice thing about a 928, its already good. The down side not so easy to improve.
Some have added a supercharger, and there are a few examples of other mods, but not as simple or as cheap as updating some chevy V8.
Something as simple as exhaust headers, normally a cheap and simple update, while headers are available, they are fairly expensive.
The easy update seems like some sort of chevy V8 that could be updated, basically just use the engine block, the rest could be after market improved parts, there is so much available
But I do admire anyone being creative. I wonder what it would be like to put 4 weber carbs on a 928. Instead of sorting out the old fuel injection.
The 928 is a older design, but it doesn't look like a old car, engines have been greatly updated since then. So many other engines could be a update. There seems to be a fair supply of old / fairly cheap 928's to work with, most need a engine.
Not really much in the way of cam options. For the 16v engine about the only option that I'm aware of currently is to get a set of euro cams, which would be a nice upgrade over the stock US sticks, but still we aren't talking about a whole ton of power. Likewise there isn't a whole ton of tuning to be done for more power with the stock L-Jet.
If you could have found a 01-03 S8 that was wrecked it would have been a bit easier. They have 360hp and are pretty rev happy. Only thing is getting the ecm tuned to have the emobilizer removed from it. Sometimes getting the ignition and instrument panel works as well. Thing with those motors is that when they are uncorked they sound like a nascar. Now if that's what you are going for then good luck.
I do have access to a machine shop that could do an adapter plate easily, but not the flywheel.
Some thoughts: The ABZ was a popular swap into older Audis. VW/Audi gear boxes used to use either the 4/6 cylinder bolt pattern, the 5/8 cylinder bolt pattern, or both (this is up until the mid 2000s). I do not know what flywheels were being used. Motorgeek.com has forums that probably have some answers on how those swaps worked.
Here are some flywheel options, you will have to inquire for price.
The real key is whether you can get the engine into the right position by adapting to the 928 bellhousing, of if you'd have to have a new bellhousing made. Clutch clearance inside the bellhousing also effects this, followed by whether there's space in the tunnel. I'd expect the ABZ to have the starter on the engine side, which would make things slightly easier, since it shouldn't require any modification to engage any off the shelf flywheel product for that engine. If it's transmission side, that means modifying or making a new bellhousing I expect.
The other good news is that with the weird coupler adapter to the torque tube shaft, you could conceivable have a new adapter shaft made to whatever length you need. Since the splines are external, they should be able to be cut on a 4th axis mill, though the cutter may have to be ground to get the right profile. This would be easier than having a bellhousing made, and would let you correct for whatever depth adapter plate you end up with. Additionally, it would also let you use whatever clutch disk you want, ideally the one that matches the pressure plate you use, which then has to fit the flywheel and inside the bellhousing.
For the clutch actuation, using an internal slave cylinder is a popular and relatively easy way out if you have the longitudinal space. Flipping and modifiying or making a new clutch fork would be necessary for an external slave. I know flipping and modifying the 944 clutch fork has worked in the past.
I think if the 034 flywheel insert plate gets released soon, that will solve the engine to flywheel part of the swap. I think that there is a way to have it drilled to accept the twin disc clutch. Then it all bolts to the ABZ flexplate and it needs an adapter plate between the engine and bellhousing.
I had an offer to trade the 928 for another car, and I should be hearing on that soon. If that doesn't happen, it's probably game on-ish for this swap. I just spent another wad of cash to have the intermediate plate pinned and de-warped, so that should fix the previous clutch issues. I may end up trying to enjoy the car a little bit over the summer and get a little use out of it before I tear into it.
If it doesn't, I also have a rough-ish 944 hanging out in the shop that is just worthless enough to be a project for this engine. I think with a 924 turbo (931) bellhousing, it gets things pretty close from what I've read. So I'm in limbo for a bit. It would be fun to have a 944 empty bay and play around with the ABZ and the F136 to see what is possible with the 944 chassis, but I also may just get that car back together and have a driver for a while too.
Also have a supra coming to the shop for some work and a 2j conversion soon, so I'm going to have a busy spring.
Just a quick update:
After a long few days swapping the g28/05 that was in the 928 for a g28/13 that I got an okay deal on from a junkyard, I have 5 gears both up and down the shift pattern. Still waiting for the trade guy to come and see if he's still interested. Got the IP back in after de-warping and it seems the clutch is healed.
It was a lot more work than I thought it would be.
https://www.youtube.com/watch?v=GdR3zXVZNX0
I also found a company that makes an adaptor and clutch solution for the f136. Uses a cd009 transmission, but it at least solves the hardest part of the swap. I need to figure out if the engine will fit into the bay of a 944, or sell the 944 and find another platform to put it into. Smart sense says the 944 is the worst idea, but I could sell the drivetrain parts and come out ok and pay for some swap parts. I wouldn't feel bad about cutting up the 944 to make the swap happen since the car is already a but rough. I'd say goodbye to 50/50 weight, but that isn't always the most important thing.
What would you put that combo into? I think the f136/cd009 fits better (on paper, mental math) in the 944 than the euro E30 I have.
yupididit said:So you traded the 928?
Not yet. I should find out tomorrow morning if the deal will happen.
Well, good news if you are planning on an F136 swap - there's a solution now that uses a CD009 transmission and custom flywheel. Speed Gems now makes a kit for this engine and trans to mate up. If you use code 'throttlegrotto" you can save %10 on the kit. My kit is still in the mail, but should be here soon, and I'll do a video on putting it all togther.
Which means that there is now a push to find a car to put this setup into. Requirements are:
good road presence.
large engine bay
drives well with 400hp
decent aftermarket supplies
Leading the list are Z32 300zx cars right now - Some of the other cars I've considered don't quite have the whole package.
A few big updates here while stuck on nights. First off, the 928 trade deal fell through. He got a 'better deal' elsewhere at the 11th hour, so I'm stuck with the car for the near future. The prospect of a trade got me to get a few things done on the car that had been annoying me, so that is a positive. I'm still going to look into the ABZ parts as they come available and I think once 034 re-releases their flywheel insert, I will be able to make some moves on that stuff.
The F136 adapter kit showed up and it's a nice setup. Should have a detailed video of the parts and the install soon. I'll have a complete engine/trans by the end of the week, bolted to a CD009 ready for a project car to show up. I'm still waiting on confirmation of an offer I made, so I won't speculate on the z32 recipient yet.
My datsun roadster took over some spare time with an incident involving a Honda Pilot. So I've been negotiating all that and starting the work on the body repairs. Minor damages, but major time to fix them in an already sparse amount of time I have for garage stuff recently.
Not the greatest set of updates, but it's still some sort of forward progress. Which is terrible for youtube, but average for most humans.
