1 ... 4 5 6
aussiesmg
aussiesmg MegaDork
8/27/14 12:11 p.m.
First the rust repair is done
Nice result too if I may add
aussiesmg
aussiesmg MegaDork
8/27/14 12:13 p.m.
Brokeded 5.0 is out, replaced with Vince power
So far the engine bay has in excess of 150 less wires
and Vince apparently quit...
aussiesmg
aussiesmg MegaDork
9/1/14 8:05 p.m.
Roadtrip to get another short block, drove 850 miles to Massachusetts, and picked up a couple of great deals on short blocks, the one for the RX5.0 is a 306 with forged crank, quality rods and pistons, arp bolts and more.
The gang
Jack called shotgun
This is the 306
Meanwhile Vince buttoned up the engine bay
aussiesmg
aussiesmg MegaDork
9/1/14 8:12 p.m.
Also scored this 331 as well
You have to grab deals like this..
aussiesmg
aussiesmg MegaDork
9/2/14 7:36 p.m.
Found in the pan of the 5.0 before installing it onto the 306
the damage may have tweaked the pan under the balancer, some massaging and fingers crossed
Ordered new pushrods today
aussiesmg
aussiesmg MegaDork
10/28/14 6:55 p.m.
$2014 is completed so we are back on track
Clutch is out to get upgraded by Ft Wayne Clutch and Drivetrain.
Clutch guy said the button clutch was good to go as it is, so we put it all back in and remounted the transmission with a new tail housing to replace the leaking old one.
aussiesmg
aussiesmg MegaDork
11/2/14 11:26 p.m.
Upskirt shot
aussiesmg
aussiesmg MegaDork
11/2/14 11:34 p.m.
185 AFR heads on a 306 short block, a wild cam with 12:1 compression and all the good pieces inside should shake up the RX5.0. I am thinking an additional 50 hp should be available, or more, bringing it up to at least 425 crank hp. A little over the old stock short block with Trick Flow heads
Then we added a bottle of go juice...
The_Jed
The_Jed UltraDork
11/3/14 7:58 a.m.
That's the first time I've seen RTV exhaust gaskets.
aussiesmg
aussiesmg MegaDork
11/4/14 6:58 a.m.
In reply to The_Jed: Rest assured we are going a different route on that.
Discovered the upper intake manifold has a cracked corner, stopped us starting it up yesterday, but we should weld it today, our new Plasma cutter is also a TIG welder
1 ... 4 5 6
AuKOfGtqvHiVRMcZGTHqoxWu8TduHHUJlWDst6KJHeQXBZoJITC6c78dk9jOfy07
