1 ... 29 30 31 32 33 ... 59
DaveEstey
DaveEstey PowerDork
4/30/15 6:24 a.m.
Dusterbd13
Dusterbd13 SuperDork
4/30/15 6:39 a.m.
How do you plan to bleed the cooling system? I've always wondered that about remote radiators.
DaveEstey
DaveEstey PowerDork
4/30/15 7:51 a.m.
Jack up the front and let the air roll out of the filler. The beauty of an electric water pump is that I can run the system without creating any heat.
Dusterbd13
Dusterbd13 UltraDork
4/30/15 7:59 a.m.
Ok. Cool.
Someday ill build a 914 with a remote radiator, so im learning from you.
DaveEstey
DaveEstey PowerDork
4/30/15 8:01 a.m.
We're learning together then haha
DaveEstey
DaveEstey PowerDork
4/30/15 8:55 a.m.
An option is to drill and tap to add an NPT outlet on top of the radiator to let the air out.
DaveEstey
DaveEstey PowerDork
4/30/15 3:07 p.m.
$140 later and I'm ready to get lubed up
DaveEstey
DaveEstey PowerDork
5/5/15 7:29 a.m.
People wonder why people ask for so much money when selling a race car. It's the labor. The builder remembers the 2 hours spent mounting a damn radiator and how that was a simple job:
Fuel cell and radiator are now in. Need to plumb and put in a firewall.
Cool_Hand_Luke
Cool_Hand_Luke Reader
5/5/15 5:29 p.m.
Liking the fuel cell placement
DaveEstey
DaveEstey PowerDork
5/6/15 8:58 a.m.
Trying like hell to consolidate weight toward the middle. The cell only holds 6.2 gallons - 6 with the foam in it, but that's still 50 pounds.
Last night was pretty quiet, but I did drill and tap the radiator for an air bleed, which should solve any issues of air in the radiator. The filler in the front of the car will take care of that end of things. This week is all about plumbing and finalizing wiring. Then it's buttoning up safety gear before Ascutney Hillclimb on the 15th and 16th.
Adrian_Thompson
Adrian_Thompson UltimaDork
5/6/15 9:19 a.m.
Is there vibration isolation for that rad?
DaveEstey
DaveEstey PowerDork
5/6/15 9:23 a.m.
Rubber pads between it and the frame
DaveEstey
DaveEstey PowerDork
5/7/15 5:46 a.m.
Yup, gonna have to cut the hood.
Finalized all the wiring and then tested it out - no smoke (ignore background music?) https://www.youtube.com/watch?v=_SND_x18Fa0
DaveEstey
DaveEstey PowerDork
5/7/15 12:47 p.m.
OK looking for info from other RX7 owners. 3 studs/bolts on the driver's side engine mount. What size are the top 2? Mine are missing.
EDIT: NVM I'm dumb.
wvumtnbkr
wvumtnbkr GRM+ Memberand SuperDork
5/7/15 2:49 p.m.
why only 2 plug wires?
DaveEstey
DaveEstey PowerDork
5/7/15 2:51 p.m.
lead plugs are fired by the MSD box, trailing fire through the dizzy like normal.
Dusterbd13
5/7/15 4:06 p.m.
Been a while since I heard dmx.
DaveEstey
DaveEstey PowerDork
5/7/15 8:11 p.m.
Assembling -16AN hoses SUCKS
Fuel pumps are installed, wired and plumbed - though I want to switch a straight fitting for a 90 bend for a better fit.
DaveEstey
DaveEstey PowerDork
5/8/15 2:10 p.m.
Looking at clearances for exhaust. Two options. I have a muffler serving as my collector, so the exhaust goes Header (1.8id) > Racingbeat road race presilencer > Borla XP Pro muffler > 3" exit
Option one: transition it to ovalized tubing and run a side exit. Pros: less weight Cons: No ability to add more muffler Option two: run it out the back like a normal car. Pros: Can add on muffler as needed. Cons: Heavier. Fuel cell will need heat protection.
Fueled by Caffeine
Fueled by Caffeine MegaDork
5/8/15 3:00 p.m.
beautiful man.
Dusterbd13
5/8/15 4:51 p.m.
Option one. Seems like the best balance. Do you have sound limits?
DaveEstey
DaveEstey PowerDork
5/9/15 2:28 p.m.
Bracket racing?
DaveEstey
DaveEstey PowerDork
5/9/15 2:29 p.m.
Dusterbd13 wrote: Option one. Seems like the best balance. Do you have sound limits?
Must be "reasonable"
DaveEstey
DaveEstey PowerDork
5/9/15 9:15 p.m.
And then I finally ran out of aluminum sheet.
Fuel system is complete. I need better rubber isolators for the fuel pumps. LOUD
DaveEstey
DaveEstey PowerDork
5/9/15 9:27 p.m.
More thoughts. I don't NEED brake lights, but would like some. With the floor mounted pedals I'm not sure how to make that happen. Inline pressure switch? A lot of those don't seem to trigger until you've got 50psi going through the line, which isn't a low enough threshold for my tastes.
1CApC03Nvaj1x8Z95XpLPMS1tgqNQze5cZHUi1SzUbYuMNciIOyNZlBM5yhe4BUq
