Started cleaning up the engine for install. At this stage there is a huge potential for scope creep. On one hand, I would love to get it running N/A so I can start driving it soonest. On the other hand, this build is far beyond "half-ass" at this point. Kind of at a fork in the road.
As you may recall, this is a non-VVTI 2JZ-GE engine with a W58 5-speed manual. Clutch has already been upgraded to a 6-puck. These early non-VVTi -GE engines share the same "bullet-proof" bottom end - block, crank, rods etc - with the GTE turbo engine. Compression ratio is 10:1 vs the turbo engine's 8.5:1, due to different head gasket and dished pistons. This engine came from the same donor car as the front suspension parts.
Goals:
- 350-400 honest-to-goodness dead-nuts-reliable wheel HP
- Broad power curve, especially in low-end
- Responsive throttle, minimal lag
- Something unconventional for a such a unique build
How will I get there?
- Triple CT12a (1JZ-GTE) turbos
- ITB's from a BMW M3 S54
- Standalone ECU, probably MS2 or Microsquirt
Now I know what you're thinking. That sounds crazy. But you made it this far into the build thread, so you're probably into that sort of thing. Some history: I bought 2 sets of 1JZ turbos for $100 a few years ago. The 1JZ-GTE made 280 hp stock with two of them and only 2.5L of displacement. I have 3.0L and 3 of them (1 as backup), so my stupid naive math says 1.5 x 280hp = 420hp which would be more than plenty for me. I scored the BMW ITB's for $43 at my local pull-a-part, a Black Friday junkyard miracle. Folks seem to turbo the S54 all the time, which means these ITB's should work with boost, so it's kinda like having a turbo S54 with a 2JZ bottom end. Right? Right. The S54 ITB's have a very slick-looking vacuum manifold and fuel rail, both made from stainless, so that helps the style points of this build. And style is very important to this build.
Oh and the best part - the port spacing appears to be very similar once you remove the lower intake runners.
This is truly as far as I have thought this out. I don't really know what I'm doing, so I am open to input, advice, referrals to psych's, etc. Some big questions I have:
How much power are S54 injectors good to? Specs say 260cc/min. That's probably not enough. What will fit in their place?
Will MS2 or Microsquirt support turbo + ITBs aka "blend mode"? I'm ready to buy and I'd love to support DIYautotune since they're local to me. I do have some MS tuning experience and I'm not afraid of wiring.
How berkeleyed is that W58?
