docwyte
docwyte UltimaDork
9/13/24 6:28 p.m.
Berotec Cumpan showed up a few days ago and it looked complete, nothing missing.  Time to install it, first things first, make sure it powers on.  Since it's a used purchase, I don't want to spend a ton of time installing it only to find out its dead and I need to return it.  So Brittannia Composites mask off and get to the switched power that I'm using for my GPS.
Yep, it works!
Time to install it.  I want to use the same unswitched power that I've got my GPS on, but unlike the GPS, I can't turn this off separately.  I hit up my basement stash and found a switch, which perfectly fit into the switch pop outs on the Brittannia tower.  Ok, perfect, since I've been wanting to get my GPS on switched power too.
Wired it in, which was pretty easy
Wires tidied up
Decision made to use the Cumpan handle bar mount, I thought about sticking to the dash on the tower, but on the bars it lines up perfectly with the factory dash
Berotec suggests running the wires down the right side of the frame, but I went down the left side instead, seems cleaner this way
You grab the oil temperature, tach signal and gear position signal from the left side of the bike.  The oil temp was kind of a PITA to get to, you need to pull out a plug that's above the front sprocket and behind the header pipe.  A bunch of people recommend taking the header/exhaust off, but I managed to get it out with a long ball end 5mm allen.  Putting the sensor in was harder, to be honest.  After that I put 3M body tape on the Cumpan and mounted it to the bars.
Success!  You can see the black switch to the right of the factory dash, that controls the power for the GPS and Cumpan.
My Seat Concepts seat should show up by the end of the month, that's really the last thing I'm going to do to the bike.  In the offseason I'll replace the fuel filters, then it's ready to go.  Hopefully I can talk my friend into riding this Sunday, otherwise I'll go on a shorter, morning ride solo.
docwyte
docwyte UltimaDork
10/14/24 9:51 a.m.
Typically my riding partner and I go out for at least a long weekend ride each season.  We'd talked about hitting the Alpine Loop this year but it never happened.  We finally managed to link up and at least do a day ride yesterday.  250 miles, 4 passes, 2 paved, 2 dirt.  Bike did great!  I'm still figuring out the range with the Rade Garage auxiliary tank, it's nowhere near as much as the Safari tank I had on my old 690, but should be adequate.
docwyte
docwyte UltimaDork
10/29/24 9:44 a.m.
So after waiting forever for it to get made I got the Seat Concepts comfort XL seat, I had it for the ride I posted above.  I was really torn between choosing the comfort vs comfort xl, got the xl to see.  It's a comfortable seat, but made it almost impossible for me to put a foot down, since it was so wide.  I couldn't really scoot forward on it, to the more narrow part due to my tank bag.  I did like how it felt off road, I was able to hook my thighs into the part where it got wide and really shove the bike around with my feet.
Then a used Renazco saddle popped up on eBay.  I've run Renazco saddles on all my previous bikes and really like them.  Decision made, I returned the Seat Concepts seat and bought the Renzaco.  Won't be able to test it out on a long ride until next season though.  Next up for this bike, during winter storage is going to be replacing the fuel filters.
Professor_Brap (Forum Supporter) UberDork
11/10/24 5:12 p.m.
Yep, it works!
Wires tidied up
I have been on the hunt for one of these for mine. I think I'm gonna pull the trigger soon.
docwyte
docwyte UltimaDork
11/10/24 5:54 p.m.
In reply to Professor_Brap (Forum Supporter) :
I've been really pleased with it.  I've had to calibrate the gear position a few times, as it gets confused sometimes but seems solid now.  Really wish KTM had just stuck with the earlier dashs for these with the large analog tach etc.  Supposedly people heard at EICMA that the next gen 690/701 will have the TFT dash, so if that happens it'll be a big upgrade.
11/10/24 9:25 p.m.
In reply to docwyte :
I agree with the dash being sparce. I think I plan on grabbing one this winter.
docwyte
docwyte UltimaDork
11/12/24 9:35 a.m.
Some off season work done.  On my last ride I struggled with getting the stock kick stand back up, especially with the wider seat.  Doesn't help that there isn't anything on the kick stand to grab with your boot and plastic motocross boots just slip on the metal stand.  I'd pulled my Swiftkicker off my old 690, so tossed that onto the 701.
Next up was cleaning the air filter.  The filter skin was really dirty, the filter itself was fairly clean, but I decided to clean it anyways.  Currently waiting for it to dry out, then I'll oil it tonight, let it sit overnight and install it tomorrow.
Bike came with this nice Mosko bag, which has tons of pockets and isn't all that tall.  However it's longer than my Wolfman bag, so eats up seat space
Decision made to install the Wolfman and see how I like it.
I also centered the Berotec Cumpan display on my bars, it really bugged me to see it off center.  Cleaned and lubed the chain too.  Last task is to replace the in tank fuel filter and install the filter sock onto the fuel pump.  Might wait until Spring because the tank is fairly full of fuel and I'd rather not dump it all over my garage floor.
11/12/24 4:02 p.m.
I also have to do fuel filters on mine soon. Plan on doing the metal wix filter upgrade on mine.
docwyte
docwyte UltimaDork
11/13/24 9:39 a.m.
That's what I got, very affordable at ~$11 from the local auto parts store.  I looked into getting the Golan filter that replaces the little tea bag in the fuel injector line and was shocked to see that it was ~$70.  I don't remember spending that much for it when I got it for my 690.  Think I'll just do the metal WIX and add the Profill pre pump filter and call it good.
11/13/24 6:59 p.m.
I auctally just ordered a profill for my 701 and my 500. I replace the small inline one every oil change on my 500.
docwyte
docwyte UltimaDork
11/14/24 9:43 a.m.
Yeah, I should grab one and just replace it along with the other fuel filters now.  Dealer only item?
docwyte
docwyte UltimaDork
11/29/24 6:27 p.m.
So I've been cruising FB Marketplace looking for Kendon Fold up trailer that'll haul 2 bikes.  A Kendon knock off popped up a few days ago, holds three bikes.  Ok, more is better than less and the price was really attractive.  Went to check it out today, could use new tires but otherwise works fine, although upgrading the tail/turn light to LED's would be a good idea.  The only thing I don't like is it doesn't have casters on it, which the Kendon has and lets you stand it up and move it around.  This also has a "tail" on it that supports the trailer when it's standing up, which makes it stable like that but also complicates matters as far as adding casters to move it around.
In the end the deal was too good to pass up, so I paid the man, got the signed title and hooked it up to the Touareg.
The trailer bounced around a bunch empty, with my 701 loaded it should be pretty smooth.  I was able to put it in the garage for now because my 996 is up on the lift.
It can't stay there long term though, as the 996 won't fit with it there, it eats up too much length.  There's nowhere else to put it in my garage, so I need to figure out a way to move it while it's standing up so I can fit it through the gate to my backyard.  Neighbor had the idea of using the car dollies to move it around, which might work.  Then my plan is to take away some rock and some grass, replace that with pavers and then lay it down next to my AC compressor and deck.
It wont' fit standing up behind the AC compressor, it's too wide to fit there.  I'd rather have it laying down on it's real wheels so it's not visible over my fence, the HOA won't like that.  I need to see how much it's going to cost to do the yard work, then I'll decide whether I keep this trailer sell it.  I'd love to keep it around as it lets me and 2 riding buddies do a drive and ride.  It also lets me easily bring my moto and mtn bike to my parents house in So Cal.
11/29/24 7:33 p.m.
I got a pack of 5 of the small inline filters for like $10 at the dealer.
docwyte
docwyte UltimaDork
11/30/24 10:42 a.m.
That's way cheaper than what my dealer charged me!  They charged me $10 for one filter, not five...
docwyte
docwyte UltimaDork
12/3/24 9:27 a.m.
Got the motivation Sunday to swap out the fuel filters on the bike.  I bought a fluid transfer tool from the Hammer Store, it didn't work all that well.  Ended up draining a TON of fuel into my catch pan.
Bike up on lift
Take the rear wheel and flap off
There's the fuel pump
A couple of allen heads and it's out
Didn't find the Mahle fuel filter I expected but I've been told this is stock too?
Versus the new hotness
Here's where I ran into some trouble.  The stock fuel filter uses the one time crush clamps.  I went into my Quantum fuel pump kit and found it had clamps in it, which I assumed fit my fuel lines.  I went ahead and cut one of the crush clamps, tried to install the metal fuel filter and...
Yeah, that's not going to work.  None of the parts stores had smaller clamps that weren't worm gear, which I don't want to use.  Ordered a set of the crush clamps off Amazon, it arrived last night, missing the pliers it was supposed to have.  They're sending a replacement that'll arrive Friday.  I'll probably grab a few clamps out of the kit now just so I can finish the job, replace them when the new kit arrives and then return the old kit.  Oddly no clamps on the fuel lines on the fuel pump, only the fuel filter?  Thinking I might put clamps on the fuel pump, that seems like a good idea...
I did install the Profill fuel filter onto the fuel pump
On to replacing the tea bag filter, only to find some previous owner had installed a Golan
I need to remove it to clean it, grab the necessary clamps and install the metal in tank fuel filter, then button that up.  I received the larger 701 LR radiator fan, it's a Spal that you can order from Amazon for less than half the dealer price.  Waiting for the fan shroud to come in from my dealer, then I'll install it and all the off season work will be done.
12/3/24 5:33 p.m.
Fuel filter is on my list for next week hopefully!
docwyte
docwyte UltimaDork
12/4/24 9:51 a.m.
Grabbed a few of the clamps and installed the metal fuel filter...
Carefully tucked everything back into the tank, installed the 4 allens, installed the splash cover, went to put the rear wheel back on.  This is where being lazy bit me on the butt.  I hadn't mounted the front wheel chock, or supported the bike from the skid plate.  I just had the forward straps and the rear stand on the spools.  When I put the rear wheel on it pushed the bike forward, and the stand popped off the spools, bike almost came off the lift.  Ugh.  Managed to hold the bike, lower the lift, get out a floor jack, lift from the skid plate, get it back onto the stand, put it back onto the lift, properly support it, then put the rear wheel back on.
Gas in the tank, cycled the fuel pump a few times and it fired right up.  I still need to pull the Golan fuel filter and clean it, then mount the 701 LR radiator fan once the shroud comes in at the dealer.
docwyte
docwyte UltimaDork
12/4/24 10:00 a.m.
On another note, the trailer I just bought went off to its new home last night.  After measuring the trailer several times, plus multiple spots in my backyard I came to the reluctant conclusion that it just wasn't going to fit in my backyard.  I didn't want to spend more money modifying my backyard to have it sort of fit, then have to stumble around it everytime I mow the lawn, etc.  I didn't want to spend a bunch of money buying stuff to make it move around etc.  Lastly I didn't want to leave it in the garage where I had it, as it was taking up too much space, I wouldn't be able to park a car in front of it.
I posted it for what I bought it for and got buried in people wanting it.  Guess I should've asked for more but I didn't see the need to make money on it, just wanted it to go to a good home.  It went to a guy who came over with his twin 11 year old boys, who all ride.  Perfect.  I've still got the Ultimate MX Hauler hitch hauler, so I'll make due with that if I need to move my bike somewhere.
docwyte
docwyte UltimaDork
12/6/24 3:53 p.m.
Decided to try to mount another tool tube on the right side pannier racks.  I'd hesitated before because I was concerned on full compression that the rear brake caliper would hit the tool tube.
I've got it tucked up as much as I can, the rear fender keeps me from moving it up anymore.  I think it'll be ok, I'll have to ride and see.  The asymmetry between the left and right side tool tubes does bother me, but I'm just going to have to deal with it.  Left side tool tube has tire spoons, most of the Baja Designs tire tool and a few other small things.  I wanted to get the factory tool kit in the right side tube but it was too large to fit.  So the right side has my quantum fuel pump, spare fuel filter, the rest of the Baka Designs tire tool, some tire bead lube and a tube of Quik Steel.
Large tool kit, tubes, Slime pump and factory tool kit are in a Wolfman bag that I'll strap to the top rack.
docwyte
docwyte UltimaDork
12/21/24 6:12 p.m.
Got the call from my local dealer, my 701 LR fan shroud came in!  Woot!  They'd told me it wasn't going to show up until at least mid March, so it was a pleasant surprise to hear that it arrived.  I picked it up and checked it out with Spal fan I bought off Amazon.  Yup, perfect match.
Time to pull out the factory fan.  Seat off, Rade Garage tank out of the way so I can get to the fan plug
Next I take off both side plastics and stare at the stock fan/shroud.  Uhhh.....  Ok, looks like I need to loosen the radiator guards and radiator so I can swing them free to get the room to get the fan out.
There's one T30 torx bolt that holds the top of the fan shroud into place.  It's not in a good spot to get to at all!  I managed to get it out with a 4mm allen wrench.
And the stock fan and shroud comes out
And a comparison between the stock fan/shroud and the LR fan/shroud.  It's noticeably larger
I went to put the new assembly in and that's when I looked at the plug on the new fan.  Uh, what?  It's not the same as stock?!  I checked the part number, yup, I ordered the correct fan.  WTF?!  Went to Amazon where I ordered the fan, checked out my order.  Hmm, think I see the problem
That's the "weatherpack" plug that came on this fan.  I didn't think anything of it, it was the correct fan/part number.  Turns out you can buy this fan with several different wiring plugs on it.  Here's the stock plug
I debated cutting the plugs off both fans and wiring in the correct plug.  Then I went back onto Amazon, saw that I was still within the return window of the fan I bought and that I could buy the correct fan/wiring plug combo from Amazon too.  Ok, that's an easy decison to make.  I returned the wrong fan/wiring plug, bought the correct fan/plug and will install it all when it shows up.
What was also frustrating is you can't reuse the bolts that hold the stock fan onto the shroud, those are self tappers and they're too small for the LR setup.  I should've bought the bolts I needed from the dealer with the shroud, but I didn't even think about that.  Several trips to the hardware store got me the bolts I needed.  Why several trips you ask?  Well, because each of the three bolts needed are different lengths!
docwyte
docwyte UltimaDork
1/8/25 9:41 a.m.
Got the proper fan and installed it.  NOTE:  The fan mounts from the front of the shroud, NOT the back.
Once installed the fan does hit the hidden tool box, which I knew about.  You can force the tool box into place, or use a heat gun and mold it some.  I never used it and it gets in the way of air exiting the radiator, so I just left it off.
Next up is ordering a Cycra cycralite fender, which has vents in the bottom of it to allow air to get to the radiator.  They claim +33% more airflow to the radiator, which I believe given the stock fender blocks 50% of the radiator.  After that my cooling mods are done, as the bike will have the larger 701 long range fan, a lower temp fan switch and a vented front fender.
docwyte
docwyte UltimaDork
4/20/25 12:18 p.m.
I've been curious about the Faast Flex handle bars for awhile.  They're supposed to help with arm pump, fatigue and knock out vibrations.
I'd like a set, but not for thr nearly $500 they cost new.  Thankfully I found a lightly used set locally for $200.
I do need to get a few parts to make them work, the adapters from rmatvmc for my highway dirt bikes handguards, plus some different bar risers.
I've got 32mm risers now but the Faast bars are ~25mm taller than my stock bars.  I'd like a total of 2" or 53mm of rise.  The brp Scott's mount gives 15mm of rise, the bars add another 25mm, so I need to find a 12-15mm riser.  I think brp makes a 15mm riser.
I may install the bard with no risers just to see where they end up...
Once I get all the parts I'll do the install...
ZBeonTxLY9Ekg1PsF7Wrzu6VESqTHLzJjYShpgyx0EKO2luMTpF6my6dZsnuqaF1
