BrianC72gt
BrianC72gt GRM+ Memberand New Reader
4/8/19 3:15 p.m.
Here is an old, but still useful, tutorial for building a schedule 40 weld El turbo manifold.  I turbo'd my old miata following much of the info here:
http://www.sdsefi.com/techheader.htm
1SlowVW
1SlowVW Reader
4/8/19 3:51 p.m.
I used 1-3/4 ID weld elbows. Thick wall. I would have gone 2” but in some spots it would have been very tight.
I justified it to myself by saying there are spots in the stock truck manifolds that are much smaller than a smooth bent 1.75” and lots have people have made crazy power on stock manifolds.
ruhltodd
ruhltodd New Reader
4/15/19 10:38 a.m.
Made it to the shop for a little bit this weekend. Kind of uneventful, I finished mocking up the transmission crossmember, but didn't have enough time to weld it. Decided to save that for this week. I also started mocking up and taking measurements for the turbo hot side. I think these LS3 manifolds might work after all. I plan on running the exhaust tubing in front, under the oil pan and up to a merge. The area is pretty tight, but I took my measurements with the pitarm turned all the way right, just to make sure there is enough clearance for the steering still.
ruhltodd
ruhltodd New Reader
4/30/19 7:59 a.m.
Finished the turbo bracket and placement.
Hot side is 80% there.. need to finish some welding and placement for the wastegates. I would have finished the passenger side yesterday but someone forgot to grab the other 2.25" v-band sitting in my office.
ruhltodd
ruhltodd New Reader
6/2/19 6:25 p.m.
Been pretty bad at updating, but nothing too exciting. Just making progress on buttoning everything together. Started wiring the Holley Terminator X, installed a Holley Hi Ram, WARR throttle body. This will I'll be redoing all the fuel with 8an feed/returns and running a Magnafuel 4303 pump and Magnafuel boost referenced fuel pressure regulator.
Pretty nerve racking cutting into a nice painted fender.. I think of the 5 hours it took me, 4 of it was spent measuring. Measure once, cut twice.
ruhltodd
ruhltodd New Reader
6/6/19 8:35 a.m.
Decided to teach myself how to tig on this project. It's been a struggle (and still is.. I have the shakes pretty bad), however I find myself more excited to do it, and not as terrified anymore. I finished up my downpipe last night, welded the vband and bung for my wideband.
ruhltodd
ruhltodd New Reader
12/19/19 10:37 a.m.
Been a while since I've updated this, but I'm still chipping away. Let's see..
New wheels
Got it running and buttoned up.. ish
New seats..
Oh.. picked up another distraction for another time
Narrowed an 8.8 out of a 2011 vic with 3.27 LSD
New wheels mounted.. hated the stance so decided to fix it
AWSX1686
AWSX1686 GRM+ Memberand UltraDork
12/20/19 9:16 a.m.
Amazing!
ebelements
ebelements Reader
12/20/19 9:39 a.m.
I was absolutely unprepared for the pictures after the the one with the empty bed.
Patrick
12/20/19 9:57 a.m.
I'm concerned about your door bars being too low, otherwise everything looks sweet
Xzr1BQWd1VbG9t1e50Ng6TA8uw3vSN1GaQWRcW4t4LWAPwf2rDOSTowIXsHNoLRu
