VWguyBruce
VWguyBruce HalfDork
5/17/11 6:59 p.m.
My buddy broke the timing belt on his '02 Neon. Was a great running car before. New brakes, tires, shifter repaired and alignment. If I can get it for next to nothing is it worth my time? I was thinking about throwing a belt on there and trying to start it up. It broke seconds before he was pulling into his parking spot. What do you guys think?
Later, Bruce
Kendall_Jones
Kendall_Jones Reader
5/17/11 7:16 p.m.
If its an interference engine, it only takes milliseconds to bent the valves... KJ
Ranger50
Ranger50 HalfDork
5/17/11 7:22 p.m.
Take it apart, have the head and valves fixed, new gaskets and belt, and some time, you are back to a running car with only about $200 and 6 or so hours into it.
I'd jump all over it.
VWguyBruce
VWguyBruce HalfDork
5/17/11 9:31 p.m.
I think I'll bring it back to the house and look it over. My BMW is killing me in gas.
KATYB
KATYB Reader
5/17/11 9:56 p.m.
gonna make a bet that there are no bent valves....take off valve cover set motor 90 degree atdc and turn cam shaft a few times. make sure no binding and that all valves come all the way back up... after that. new belt and tensioner and enjoy.
triumph5
triumph5 Dork
5/17/11 9:58 p.m.
Didn't this publication goes through this about a year ago?
BoneYard_Racing
BoneYard_Racing Reader
5/17/11 10:25 p.m.
Usually a neon with any sort of timing failure is going to bend a few valves they are pretty cheap but tend to tear up the seats and guides during the machine work is what can get you. Depending on your location I do sohc neon timing belts for $325 and have good used engines for $400. It sounds like a good deal for anything under $500 second gen neons are pretty impressive cars for the price.
Travis_K
Travis_K SuperDork
5/18/11 7:26 a.m.
I would expect more like $400-$500 to fix it (if you get a junkyard head) but if its cheap enough thats still not bad.
Duke SuperDork
5/18/11 7:44 a.m.
Ranger50 wrote: Take it apart, have the head and valves fixed, new gaskets and belt, and some time, you are back to a running car with only about $200 and 6 or so hours into it. I'd jump all over it.
This. You should be able to pick up a complete head for $100-150. New gasket, T-belt, idler, and water pump, and it is good to go for another 100k.
dt7ZaIHv1lq6sBpHEkvRZfjs11nwJj9GIlKtXYlxG55GwwGAitDx0UMyapbu9sqi
