logdog
logdog GRM+ Memberand HalfDork
12/27/12 2:49 p.m.
Ive been through a few 12 volt tire pumps through the years. The current one has lasted about 4. Its a "heavy duty truck pump" that came from a parts store and was about 60 bucks. This style of pump is very handy for me and I even use it on the tractors. However, its dying (took 15 minutes to put 5psi in my truck) and I need a replacement. I know the 20 buck ones you find everywhere dont last long enough to fool with. Plus I need one that will put 60ish psi in a tire and the cheapies usually are not up to task.
The ARB and similar would be ideal but its hard to swallow a 500 price tag. Right now I am willing to spend up to 100. Does anybody have one they would recommend?
andrave
andrave Dork
12/27/12 2:55 p.m.
have you thought about just carrying a c02 tank?
honestly I haven't found anything that is portable and cheap that will fill a tire to 60 psi like my truck and trailer tires need. Most of the sub $60 ones will run all day and get hot and maybe bump the needle up to 55 after 15 mins. I tried one that couldn't keep the 45 psi in them already, it was actually running yet bleeding off psi.
mw
mw Dork
12/27/12 3:54 p.m.
Harbor freight sells a fairly big one that's direct drive and hooks directly to the battery. I have smallerwith complaints, but I'm not doing truck tires.
logdog
12/27/12 4:02 p.m.
andrave wrote: have you thought about just carrying a c02 tank?
Keeping a CO2 tank full would be more hassle than I would want to deal with. My luck would dictate a low tire at 10pm on a Sunday when the tank is dry
andrave
andrave Dork
12/27/12 8:39 p.m.
thats not really how they work, a tank would probably last you a year or more just using it to top off tires.
FpuqNxrbwgSiU19EHjmCnTBHFVka4ELhZOHaeiuekSJrn6ICGTI8jUblFLZ1oUTG
