Advance Adapters still sells bell-housings for Chev v-8 to Toyota trans. Probably a less expensive option than T-56, even with all the little bits.
I think the 3SGTE aluminum flywheels (Fidanza) and clutches will work on the 1UZ if you press off the steel ring gear and flip it over to accommodate the starter being in the valley (different mesh on the ring gear.)
$180 adapter, 1UZFE to W58:
http://seattle.craigslist.org/see/pts/3203502091.html
This, W58 transmission, 3SGTE flywheel (maybe), clutch, etc. and you're rocking.
Like this:
https://www.youtube.com/watch?v=KV7ENJvWAGc
In reply to turboswede:
You have to drill out the bolt holes on the 3sgte flywheel to make it fit the 1uz crank. You will also need to figure something out for the throwout bearing most people seem to go with the hydraulic TO similar to the t56. These is also the issue with the starter ring. You can press if off and flip it (I have never seem any more details than this) or put a bevel on the engine side of the ring to make the starter engage properly.
In reply to 92CelicaHalfTrac:
There is a guy that sells CAD files to cut your own for $25 and it seems the going rate for the machine work in steel is around $100 dollars. Just saying.
after listening to my LR4 scream to 5800rpm through the K&N FIPK and out through the Magnaflow catback this morning under a large overpass..... I have to vote for the LSx. Always. Every time. The sounds it made were just what I needed to hear after 4 months of fighting the 'vette and being 7:25am.
Bobzilla wrote: after listening to my LR4 scream to 5800rpm through the K&N FIPK and out through the Magnaflow catback this morning under a large overpass..... I have to vote for the LSx. Always. Every time. The sounds it made were just what I needed to hear after 4 months of fighting the 'vette and being 7:25am.
Did you get it back on the road?!
Oh, and while I don't doubt an LSx sounds awesome, a 1uzfe can sound pretty awesome too. They're both v8s so you've got a big leg up on a lot of other motors out there for sound.
dculberson wrote:Bobzilla wrote: after listening to my LR4 scream to 5800rpm through the K&N FIPK and out through the Magnaflow catback this morning under a large overpass..... I have to vote for the LSx. Always. Every time. The sounds it made were just what I needed to hear after 4 months of fighting the 'vette and being 7:25am.Did you get it back on the road?! Oh, and while I don't doubt an LSx sounds awesome, a 1uzfe can sound pretty awesome too. They're both v8s so you've got a big leg up on a lot of other motors out there for sound.
Nah he's talking about his Silverado.
And here's where i say something mildly amusing in a joking manner about the terms "5800rpm" and "screaming" being used in the same sentence.
The 1UZ was based on Toyota's CART/IRL design which explains why the bottom end has enough main bearing bolts to hold a suspension bridge up. The damn thing is way overbuilt for passenger car applications which explains why they are cheap in junkyards: no one ever has to replace them.
Curmudgeon wrote: The 1UZ was based on Toyota's CART/IRL design which explains why the bottom end has enough main bearing bolts to hold a suspension bridge up. The damn thing is way overbuilt for passenger car applications which explains why they are cheap in junkyards: no one ever has to replace them.
Stop typing these things. I'll go out and buy one to build/clean for... something later on at some point.
DO IT!! I have had the same thought. If you can get it megasquirted on a table then find any RWD chassis to make a home for it. Then add large turbos for fun!
92CelicaHalfTrac wrote:Curmudgeon wrote: The 1UZ was based on Toyota's CART/IRL design which explains why the bottom end has enough main bearing bolts to hold a suspension bridge up. The damn thing is way overbuilt for passenger car applications which explains why they are cheap in junkyards: no one ever has to replace them.Stop typing these things. I'll go out and buy one to build/clean for... something later on at some point.
I keep threatening to shove one in the Jensenator. That's why I have found all these links n' crap.
92CelicaHalfTrac wrote:dculberson wrote:Nah he's talking about his Silverado. And here's where i say something mildly amusing in a joking manner about the terms "5800rpm" and "screaming" being used in the same sentence.Bobzilla wrote: after listening to my LR4 scream to 5800rpm through the K&N FIPK and out through the Magnaflow catback this morning under a large overpass..... I have to vote for the LSx. Always. Every time. The sounds it made were just what I needed to hear after 4 months of fighting the 'vette and being 7:25am.Did you get it back on the road?! Oh, and while I don't doubt an LSx sounds awesome, a 1uzfe can sound pretty awesome too. They're both v8s so you've got a big leg up on a lot of other motors out there for sound.![]()
That's only because of the "big ugly" intake and ECU limiter. Throw on an LS6 intake and a nice cam/tune and it's a nice 7000rpm V8 that is durable, powerful and frugal.
And no, Barbie is still not right. Driver's head came off today:
Can you tell which one is not firing?
Bobzilla wrote:92CelicaHalfTrac wrote:That's only because of the "big ugly" intake and ECU limiter. Throw on an LS6 intake and a nice cam/tune and it's a nice 7000rpm V8 that is durable, powerful and frugal.dculberson wrote:Nah he's talking about his Silverado. And here's where i say something mildly amusing in a joking manner about the terms "5800rpm" and "screaming" being used in the same sentence.Bobzilla wrote: after listening to my LR4 scream to 5800rpm through the K&N FIPK and out through the Magnaflow catback this morning under a large overpass..... I have to vote for the LSx. Always. Every time. The sounds it made were just what I needed to hear after 4 months of fighting the 'vette and being 7:25am.Did you get it back on the road?! Oh, and while I don't doubt an LSx sounds awesome, a 1uzfe can sound pretty awesome too. They're both v8s so you've got a big leg up on a lot of other motors out there for sound.![]()
Get on that, then.
Not for the truck.... but is in on my "to do list" of engines to stuff into something fun.
Maybe I should snag one and stuff it into a B-body? Cage, monster meats, cam'd 4.8 with a FAST intake and 90mm T/B and tuned to turn to 7500rpms or so.... that could be fun.
The other think to look for are wrecked lexus, around here you can buy a hit in the back running driving for 1k or less. I have evil thoughts after measuring the engine bay of the BiTurbo......
So.... How much nitrous can it handle?
Ranger50,
The bottom end is very stout, but the rods got thinner (weaker) as the engine was developed. The strongest rods are the first 4 years or so (upto 95). There are planty of COMMENTS that the stock bottom end will hold 600HP, but that has not been documented as a fact. Looking at the bottom end, I would think it could handle a fair shot of nitrous...
Curmudgeon,
This engine was not developed from the CART engine! I know the Toyota CART engine was good (personal experience), but the Lexus engine was designed for production cars. There is a V12 variant out there (1GZ - 5.0L). The 3UZ (4.3L V8) was the bassis for the Toyota/Lexus Daytona Prototype engine. That was built to make nearly 600HP. They did later open that engine up to nearly 5.0L.
Fun fact that could probably cross to the OHV vs OHC thread is that the Toyota CART engine, in its final form could rev to 18000 on steel valve springs and was raced with the rev limiter at 17k for a few events. Man I loved that engine...!
