Jensenman
Jensenman SuperDork
11/7/10 6:28 p.m.
I have hunted high and low, can't find a coilover conversion sleeve for a 2 1/4" diameter spring. Of course, 2 1/2" is everywhere but the smaller diameter is necessary to clear a remote reservoir cast as part of the shock. The shock currently has a cam type preload adjuster which can be slid off easily.
Anybody have any ideas?
Dr. Hess
Dr. Hess SuperDork
11/7/10 6:59 p.m.
Koni sells the parts for their coilovers to use 2.25" springs. Maybe they would work with what you are using, or you could make some up yourself on your lathe.
Keith
11/7/10 7:07 p.m.
Might be worth calling Ground Control, they may have an option for you.
Jensenman
Jensenman SuperDork
11/7/10 7:20 p.m.
Ah, it does seem Koni has that option (1.65" ID) if it will fit the shock body... I trust their lathe work a lot more than I trust mine.
Raze
Raze Dork
11/7/10 8:12 p.m.
What's your I/D? Southwest Speed sells 1 7/8" ID springs, guessing OD would be darn close to 2.25"...
Keith
11/7/10 8:17 p.m.
Springs are typically rated in ID. 2.25" is a bit less common than 2.5", but not too hard to find.
camaroz1985
camaroz1985 Reader
11/8/10 8:59 a.m.
Got my challenge car suspension pieces here.
A-1 Racing
orvPS3k5hq4Eu5okskgsOV7Wse3LcReheI5LvwhAbCtGRFF26uuEqHLfOV5xrayO
